Local Time 00:04 12 Nov 2026 Privacy Policy
Forum Index : PCB Manufacturing : DiY PCB
Posted: 01:58am 07 Feb 2019
Hi All,
I often watch Bigclive.com video clips for some technical based entertainment..
I have just watched this DiY Security light Clip and I was amazed at the method Clive used to create what I consider excellent PCBs.
The clip goes for about 43minutes but the PCB making is from about 6m30 to around the 18min mark..
Anyway I was quite impressed with this.
Kind Regards,
Chopperp
Posted: 01:04pm 09 Feb 2019
Certainly uses interesting methods. I'll need to watch the video a few more times to get used to his accent & try to understand what he says in places.
Good idea just using a smaller piece of the expensive film taped to a sheet of paper. I've done a similar thing with photo paper that won't pull through the printer.
Thanks.
Brian
ChopperP
