Local Time 00:04 12 Nov 2026 Privacy Policy
Forum Index : PCB Manufacturing : Comms and Analog Sensor
carlm
Posted: 08:45pm 03 Jan 2019
I have a project with a 44 pin Micromite Chip.
I also have a level sensor that uses a comm port.
I am after some code/guidance on how to proceed.
The net result will be the level will sit in a variable.
I assume that somehow I have to initially open the comm port and then
assign a Pin to the variable.
Thanks in advance
disco4now
Posted: 10:46pm 03 Jan 2019
Have a look at this thread. its about receiving data on a comm port and putting it into a variable.
You will need to know what speed it comes in at or try different speeds if unknown and understand how the message is formatted.
receiving from a comm port
Gerry
F4 H7FotSF4xGT
