Forum Index : Microcontroller and PC projects : cfgen to teraterm transfer
| crez Senior Member Joined: 24/10/2012 Location: AustraliaPosts: 157 |
Are there some 'magic' settings which allow copying and pasting from the output of cfgen to the micromite edit window under teraterm? I'm getting extra spaces at the beginning of lines that cause 'line too long' errors, and then it all goes haywire. David |
I think you need to remove any leading white space before pasting into teraterm. Easily done in MMEdit and Notepad++ Jim VK7JH MMedit |
