Local Time 22:56 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM IR problem
antf70
Posted: 11:06pm 01 Nov 2017
Hi All,
Is there a problem with IR interrupts when CHAINing programs on CMM firmware v4.5?
Posted: 03:22am 02 Nov 2017
I have not tested this but there could easily be an issue. Looking at the source the CHAIN command disables interrupts on I/O pins but not the IR interrupt. So you should specifically use IR CLOSE before invoking CHAIN.
