Local Time 22:55 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pin rerved at startup error message
f2cf1g
Posted: 07:45am 19 Oct 2017
Hi forum. I am getting the error message:
Error: Pin 2 is reserved on startup
after entering this command line on the console prior to running an LCD test program:
OPTION LCDPANEL ILI9341,L,2,7,5
I am doing this in the context of a program which has previously run OK. Who or what has reserved this pin and for what? The firmware version is 5.04.05 on a 28 pin chip. Thanks.
Posted: 08:15am 19 Oct 2017
Hi there.
Type OPTION LIST and press ENTER.
This will show you what options are currently set, and you can then see what previously set option has reserved pin 2.
Once you see which one has reserved pin 2, OPTION DISABLE that one, to free up pin 2 again.
That SHOULD do it.
Phil23
Posted: 10:10am 19 Oct 2017
  Grogster said  Once you see which one has reserved pin 2, OPTION DISABLE that one, to free up pin 2 again.
Presume you are meaning either...
OPTION LCDPANEL DISABLE
or
OPTION TOUCH DISABLE
Once you've determined what's using pin 2.
Also, OPTION RESET reads as thought it would reset everything.
Cheers.Edited by Phil23 2017-10-20
f2cf1g
Posted: 11:52am 19 Oct 2017
Hi Grogster and Phil23
All has become clear now, many thanks. I don't know why I didn't come across this issue when I was developing the code nine months or so ago. Anyway, its all running as it used to, thanks again.
Roy
