Local Time 08:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Arrows
lew247
Posted: 06:31am 14 Sep 2017
Has anyone got any fonts or code for making arrows?
I've tried using fonttweak but failed
What I need is an arrow pointing up and one pointing down
Posted: 06:40am 14 Sep 2017
http://www.rinkydinkelectronics.com/r_fonts.php
About 2/3rds down "Various Symbols"
you'll need to download the font you want and convert it using the tools in the "Embedded Fonts" folder in the micromite Firmware distribution.
hthEdited by CaptainBoing 2017-09-15
lew247
Posted: 06:51am 14 Sep 2017
I did see that but didn't know how to use it
I've downloaded the font I need and converted it to .bas
but how do I select the arrows?
or tell the micromite I want to use the arrow pointing down in font #8
Posted: 09:11am 14 Sep 2017
it's the character number; CHR$(x).
I am guessing they start from 32 which is <space> and go up to 127 (32+95). Where the character you need occurs in the sequence depends on the fontpack you chose.
Let's assume it's character 100, to use it, switch to the font you want and then use CHR$(100) on the panel.
See the section "Using an LCD Panel" in the micromite manual, tells you how to work with different fonts.
Posted: 12:34pm 14 Sep 2017
The file "various_symbols.bas" in the Micromite zip file (under Embedded Fonts) is a conversion of the Rinky-Dink various symbols file and it has arrows plus a lot of other useful symbols.
lew247
Posted: 08:54pm 14 Sep 2017
Thanks Geoff
I'm trying to figure out how to call the various fonts
I've tried every combination of the following but I can't get the arrow to display or any other symbol, it only draws numbers
PRINT FONT 8 chr$(80) which "should" be the arrow facing upwards
This just prints 0 8PEdited by lew247 2017-09-16
Posted: 09:03pm 14 Sep 2017
You can't use fonts to print to the console, only GUIs
Look at the TEXT command
TEXT x, y, string$[,justification] [, font] [, scale][, c] [, bc]
You need something like:
Text 100,120,chr$(80),LT,8,1,rgb(red),rgb(black)
lew247
Posted: 09:46pm 14 Sep 2017
TassyJim you're a star
Last question can you assign a variable to a chr$ ?
for instance can I have something like the following or is there a better way to do it?
dim string ZA = chr$(79)
dim string ZB = chr$(80)
Text 100,120,ZA,LT,8,2,rgb(red),rgb(black)
Text 100,180,ZB(80),LT,8,2,rgb(red),rgb(black)
[quote] it doesn't work doing it this way but I'm probably making a stupid mistake[/quote]Edited by lew247 2017-09-16
Posted: 03:18am 15 Sep 2017
is fine but in your TEXT command you are trying to make ZB into an array with ZB(80)
The TEXT command should be:
Text 100,180,ZB,LT,8,2,rgb(red),rgb(black)
