Local Time 08:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CP2102 vs W10...
Posted: 03:58pm 22 Aug 2017
Anyone had any problems getting the CP2102 USB-Serial adaptor going in W10?
I have a W10 tablet now, but it refuses to install it.
It DOES see it, but says it needs drivers.
If you let it look on the net, it just sits there forever looking, but never downloads or installs anything - Three hours and nothing, so I cancelled it.
I thought that W10 supported this chip natively?
I will manually look for drivers, but I did not think I needed to with W10.
EDIT: Downloaded VCP driver from STLABS, and it is up and running fine. I don't quite know where I thought I did not need the driver came from....
This Grogster moment has been brought to you by Rictech Ltd. Edited by Grogster 2017-08-24
Posted: 04:27pm 22 Aug 2017
It worked straight off for me on Win10. No download required.
KeepIS
Posted: 04:53pm 22 Aug 2017
Same here, worked straight off - Win 10
Mike
Posted: 05:50pm 22 Aug 2017
If you have a tablet with a smaller then nine inch display you probably have the free version of windows 10 installed. This should be the full system but many manufacturers will strip out anything they think is not needed and then image that for all of their products. This will then free up lots of emmc storage which often is small to begin with.
They probably stripped out a bit more then would be good as the automatic finding of drivers works perfectly fine on a PC.
Edited by MicroBlocks 2017-08-24
Posted: 05:57pm 22 Aug 2017
Thanks guys. I was not dreaming then, when I thought that W10 knew about this one then. The tablet had W10 Home on it from new yes, but then the tablet wanted to update W10 to the new version, which it did, so I thought that in doing that....
Oh well - who cares.
It's working with a little prod from the appropriate driver.
GoodToGo!
Posted: 12:20am 23 Aug 2017
  Grogster said  This Grogster moment has been brought to you by Rictech Ltd.
Sounds like a Looney Tunes cartoon!
FWIW, I've had no issue running the CP2102's on W10. On a laptop. Not a tablet. I take tablets when I have a hangover.
GTG!
