Forum Index : Microcontroller and PC projects : NumberBox MMBasic 5.04.05
| Page 1 of 2 |
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2287 |
Question: SUB MM.KEYPRESS KREF AS INTEGER, CAPVal$ AS STRING IF CAPVal$ = "Ent" THEN IF VAL(CtrlVal(SampleTime)) <> 0 then LogPeriod = VAL(CtrlVal(SampleTime)) ELSE CtrlVal(SampleTime) = str$(LogPeriod) "All happy and control updated" <-------------------- CtrlVal(SampleTime) = LogPeriod "ERROR: Expecting a string" <--------------------- ENDIF ENDIF END SUB SUB SETUP() CtrlVal(SampleTime) = STR$(LogPeriod) "ERROR: Expecting a number" <------------------ CtrlVal(SampleTime) = LogPeriod "All happy and control updated" <----------------- END SUB Why does the same control want a number in one instance and a string in the other? Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
| flip Senior Member Joined: 18/07/2016 Location: AustraliaPosts: 137 |
Hi Mike, CtrlVal function/statement can return/set string or number...so can you check whether your SampleTime variable has a different value in the two bits of code OR if you're sure the value in SampleTime variable is NOT being altered in your code (i.e. is a constant), check whether you're creating a different type of control (one that is a text-based control rather than numeric or vice-versa) using the SAME control number EDIT or could it be the value entered (if NOT convertible to a valid number) is returned as a String? OR it needs to handle setting with exponential format (which may be a string...like 1E23 for example) Manual MM+ 5.4 page 30 shows NUMBERBOX takes text Haven't got one handy to test at the moment I will experiment too.. but I hope above quote will give you a clue... Regards, Phil |
Hi flip, thanks for replying, I always have: Option default none Option explicit The Numberbox is a GUI control in MMbasic Plus language. DIM INTEGER LogPeriod CONST SampleTime = 33 ' GUI reference I can set: LogPeriod = 10, this makes sure the number is valid and it is anyway as I placed a Debug print LogPeriod to check for that. GUI NUMBERBOX SampleTime, MM.HRes/40, MM.VRes/30, MM.HRes/5, M.VRes/4, RGB(WHITE), RGB(BLUE) In both cases the Value is SET correctly. String or Numeric. SUB MM.KEYPRESS is defined in MMBasic+ and is Procedure called to interact with any Numberbox control. It appears to me that the behaviour changes between the GUI control when it is accessed in the service procedure and when it accessed outside of that procedure? Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
On the subject of the NUMBERBOX. -------------------- CONST RXLED = 28 GUI SETUP 1 GUI LED RXLED,"", MM.VRes / 16, MM.VRes / 1.33, MM.VRes / 28, RGB(GREEN) PAGE 1 ------------------- If you have, for example, a GUI LED, and instead of just setting it on or off as in: --------------------- CtrlVal(RXLED) = 1 CtrlVal(RXLED) = 0 --------------------- You decide to read the state of the GUI LED and only turn it OFF if it's actually ON, this stop flickering of the GUI LED that is being reset in the program main loop, Serial input and LED = ON are being handled in an ISR: NOTE: Not shown is the code for an incremental counter to only reset the LED every X ms ------------------ DO IF GotData = TRUE then ProcessData() IF CtrlVal(RXLED) = 1 then CtrlVal(RXLED) = 0 LOOP --------------------- Now IF you use a NUMBEBOX GUI and the associated GUI KEYPAD opens, an error is raised. IF CtrlVal(RXLED) = 1 Error: Incompatible type in expression. It's easy to fix in code but something to watch for. EDIT: Going back to my first post: Something flip mentioned (I'm not doing it) but looking at the manual: QUOTE: The value of the control can set to a literal string (not an expression) starting with two hash characters. For example: CtrlVal(nnn) = "##Enter Number" Is this behaviour being invoked in MMbasic when it passes the ref# and caption$ by calling the MM.KEYPRESS subroutine? NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
palcal![]() Guru Joined: 12/10/2011 Location: AustraliaPosts: 2054 |
Back in January TassyJim said in answer to my question about GUI controls Don't know if that is still relevant or not, or whether it applies to your problem. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
Thanks for that info, it could be, in my case that subroutine is working perfectly once I understood what was happening and allowed for it. I have two GUI controls working through it and both now behave correctly. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1145 |
Not sure if this is related, but there appears to be a crossover effect between NumberBox and other GUIs, in this case GUI LED I can't see what I am doing wrong (quite possible) but interaction with the NumberBox appears to kill the GUI LED action. >print mm.ver 5.0405 > print mm.device$ Micromite eXtreme > list GUI numberbox #1,1,1,100,20,RGB(white),RGB(blue) GUI led #2,"Heartbeat",100,100,10,RGB(red) Do Pause 500 If CtrlVal(#2)=0 Then CtrlVal(#2) = 1 Else CtrlVal(#2) = 0 EndIf Loop > run ' heartbeat LED pulsing OK, so switching on and off ' must work OK. ' NumberBox displayed on screen OK - ' at this point I touch the NumberBox and the keypad appears ' I touch 0 then Ent and the program crashes with the following ' error message [6] If CtrlVal(#2)=0 Then Error: Incompatible types in expression > run ' same again but this time touching 0 then Ent [6] If CtrlVal(#2)=0 Then Error: Incompatible types in expression > Doug. Edit: Even though the program has crashed - see error message above, the NumberBox is still active. ie. even though I have a command prompt after the error message, touching the NumberBox brings up the keypad and entering numbers show up in the NumberBox. Question: Why is NumberBox still running in the background? Edit2: Added a GUI switch line to the above as #3 which works fine but continues to work after the crash so it appears that the touch handling code is still active even though the program has crashed. This not a real world problem as if the program has stopped, there is little point in touching any controls still on the screen but I would think that for tidyness sake, the touch handling interrupt should be paused while in command mode? Maybe not? Might be a usefull debug tool? This is independent of the crashing detailed at the top. D. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Hi Doug, That is one of the problems I described, if you don't read the LED state then you won't have a problem, just set the GUI led and it's ok, LED=1, pause 500, LED=0. It's reading the state that is causing the error. IMHO, the KEYPAD life time is an independent of your code crashing, it's code is still running waiting until you press Ent. EDIT: I think you answered your own question about keypad still running so ignore the last part. Mike. EDIT 2: I still read the GUI LED state in my code, however I set a flag before using a numberbox, that tells the GUI LED control code not to run until the "Ent" key is pressed for Numberbox that is open, at that point I reset the flag and everything is happy. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
The interesting thing is Mike, that without NumberBox active (ie. rem'ed out), the code to read the value and flip the led works fine - it seems to be it's interaction with NumberBox that causes the crash. I replaced the flip on/off code with a line CTRLVAL(#2) = 500 to do a 500mS on/off as per the manual and this works fine and is impervious to any NumberBox action. Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Yes I think I understand what you are getting at - However, it's not the Numberbox being active (AS IN DEFINED) but rather the action of touching the Numberbox which runs the MMBasic Keypad function. It's the keypad that's causing the problem in my case. When you assign a time-cycle value to the GUI LED, you are also removing the code you had to read the state of the GUI LED, that is the problem, comment out those Read lines and your original code should work - it did in mine, but as I said above I am using them again as I cant' assign a time value as a Radio RX led is totally random and I need to see when it's receiving, I could hard wire a LED but I want to use the 5" LCD to display it, and it does perfectly and in sync with the miniature radio transceiver physical LED, even the duration. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
You are right on the button Mike (no pun intended). If you use a TEXTBOX command, the result is the same with the same error message. Running a GUI SWITCH (which reacts to touch also) together with GUI LED instead of NUMBERBOX or TEXTBOX works fine with no error. The LED toggles and the switch reacts to touches as it should. If you have a GUI SWITCH in a loop toggling on and off with a GUI TEXTBOX enabled, that also crashes as soon as the TEXTBOX is touched bring up the keypad. Somewhere in the NUMBERBOX or TEXTBOX code, the ctrlval variable gets screwed up such that if you try to set the ctrlval of any other graphic entity such as the LED or SWITCH, they fail with the error message above in previous posts. Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Yes that's what I'm thinking, I didn't test it with a TEXTBOX as I assumed it would be the same, it also brings up a virtual keyboard and it calls same service procedure, but great to have it confirmed. I though for a while it was my code, I've got a over 1,500 lines and around 30 Procedures and Functions, properly considered small compared to some I've seen on the forum, but I've seen strange things happen from a totally unrelated (seemingly) hidden error in the code, especially with a few ISR's running and data coming in at very high rate. Hopefully Geoff can shine a light on it when he gets a chance. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
On thing I wanted to add: I have this code in the RX ISR: If ATN_ON = 0 Then ' Meter or Graph screen? CtrlVal(RXLED) = 1 Else CtrlVal(RXLED2) = 1 End If They are being switched off in the main DO loop, so not on and off in the same procedure or loop, so that is a difference I will try. The code is running continuously in the RX ISR, the only difference is that I have a few pages of different GUI screens, so the screens with the GUI LEDS are switched out and another page, either my Setup page or Graph select page is in focus, both use a Numberbox and both are being updated with data even when the Keypad is open, but data is written by a NON GUI TEXT procedure - because it's a lot faster than using a GUI TEXT Caption. That code turning RXLED2 on is always running (verified) and causes no problems, but if I were to read it's state before setting it (as I was before) the read of the GUI LED would crash the program. This seems to be different to what you are seeing as I can turn them on or off at any time, I just can't read the status. Mike. UPDATE: I can confirm that I can switch a GUI LED on and off in the same procedure and everything is perfect. In my case, the only problem I have is reading a GUI LED state "when" a NUMBERBOX or TEXTBOX opens - that is the only instance where it crashes. ________________________________ UPDATE2: IF you read a GUI LED state in MM.KEYPRESS subroutine it crashes with the same error, Error: Incompatible types in expression. Now this brings me FULL CIRCLE - If you change the code to: IF CTRLVAL(RXLED2) = "1" then do something ENDIF NO ERROR NO CRASH when changing it to a string value - BUT ONLY WHEN THE KEYPAD IS OPEN, otherwise it has to be numeric or it will again crash. Again, when MM.KEYPRESS is invoked when a KEYPAD opens, the GUI LED changes from a NUMERIC input to a STRING. As does the GUI NUMBER BOX - see first and previous posts. __________________________________ UPDATE 3: Finally the last on this: IF you set a flag when the KEYPAD opens, and this flag changes the GUI LED check value to a string, everything is happy. When you reset the flag after the KEYPAD close, and the GUI LED check value is changed to numeric, everything is happy. That's all the testing I'm going to do on it. Cheers. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
@KeepIS Mike, I'm pretty sure this is a bug so it's one for Geoff and Peter I think. Nice work on figuring out a work around. Cheers, Doug ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| paceman Guru Joined: 07/10/2011 Location: AustraliaPosts: 1329 |
Mike, It's a lot easier to look at posted code if in your post you use the little CODE box above the POST REPLY window. Clicking on it inserts (CODE)(/CODE) in your post, but actually with those four round brackets being square, not round. Those four square brackets signal the forum software to insert a 'code box' and anything you type or paste between the two sets of square brackets will not have its formatting changed by the forum software, for instance indents etc. are maintained. You can copy and paste your code between the brackets or just type between them. To go back to your 'normal' post just start typing after the closing square bracket. E.g the first bit of code in your top post will come out looking like: If ATN_ON = 0 Then ' Meter or Graph screen? CtrlVal(RXLED) = 1 Else CtrlVal(RXLED2) = 1 End If IMHO it's also more readable with single spacing like: If ATN_ON = 0 Then ' Meter or Graph screen? CtrlVal(RXLED) = 1 Else CtrlVal(RXLED2) = 1 End If Greg |
Thanks Greg, I was wondering about that but did not have the time to search for it. Another round to it that I could have ticked of the list - has I actually got a Roundtoit. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
| lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709 |
I've started "playing" with the GUI NUMBERBOX command but im not sure of something Can I make the box a specific size then write a number inside the box the number varying depending on the program for example wind speed so one minute it might display 0 and the next 37? Or is there a better way to do this? |
Lew, It is as simple as using the control defined for the NUMBERBOX a value - I use ref below eg. ctrlval(ref) = 200 Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
Thanks Doug, what if I have more than one box? is that the (ref) ? - the number of the box? |
I see Geoff has chimed on this on the second newer thread, so it will be good to have it sorted, like I said before, it's no big deal as my workaround is simple and effective, but down the track I know it will come back to bite someone new to programming. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
| Page 1 of 2 |
