Local Time 23:51 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite SPI client
isochronic
Posted: 02:57am 09 Aug 2017
Is the Micromite suite likely to include a SPI client ability in future ?Edited by chronic 2017-08-10
Posted: 03:25am 09 Aug 2017
Do you mean slave?
No, I have never heard of that need.
Posted: 05:51am 09 Aug 2017
I thought of making some modules that could be used as a SPI device but after testing that for a while i preferred to use I2C instead. In all MY cases I2C is fast enough and also has the bonus of only using two pins.
isochronic
Posted: 12:44pm 09 Aug 2017
Yes sorry I meant slave, just asking as it has a promise
at increasing connectivity. I have an arduino slave working but
it is a bit limited .
Posted: 11:48pm 09 Aug 2017
  chronic said   Yes sorry I meant slave, just asking as it has a promise
because of the (potential) speeds involved, I am guessing the hardware would have to support this mode. I don't have access to the datasheet atm but it would be a very tall order to emulate 10MHz bus in software. That said, I agree it would definitely add another feather to the uM's cap - I currently have no use for it but in multi-micromite devices it would open up a new world of de-centralised control. I have done this on a very small scale using CSub Serial ports but SPI is cleaner
