Forum Index : Microcontroller and PC projects : MMExtreme 5.04.05 - Manual
| panky Guru Joined: 02/10/2012 Location: AustraliaPosts: 1134 |
@matherp Peter, Could you post the latest copy of your manual covering 5.04.05 for the Extreme please - I can't find anything later than 5.3.11 Thanks, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11902 |
If I've used the "Fruit of the Shed" wiki correctly and assuming it is OK to post there the latest version is there now Look under the attachments dropdown The manual is also available from Geoff's site here |
Thanks Peter, Cheers, Doug. ... almost all of the Maximites, the MicromMites, the MM Extremes, the ArmMites, the PicoMite and loving it! |
| CaptainBoing Guru Joined: 07/09/2016 Location: United KingdomPosts: 2171 |
you did and your are most welcome |
