Forum Index : Microcontroller and PC projects : TEXT Justification
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2268 |
I'm wondering if I'm just having another Seniors moment, there appears to be a problem with the TEXT procedure. All justification appears to be back to front? (L,R B,T) Latest MMBasic release. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
Perhaps it should be called alignment. That would make more sense as justify generally means right and left aligned text. Geoff Geoff Graham - http://geoffg.net |
Thanks Geoff, it makes sense now that I'm thinking of text alignment with reference to the location. Mike. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
