Local Time 08:25 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Multiple LCD panels on single Micromite
Posted: 03:26am 07 Aug 2017
I have a requirement for driving two LCD panels from a single micromite (I need wide not big). I have no requirement for touch or gadgets on the screen, just display space. They will be mounted behind a piece of smoked perspex to hide the gap between the panels.
I have a proof of concept working here
The reset to both panels are pulled HI and the CS pins are handled in the code, not by MMBasic.
Keen to hear any comments/warnings.
Posted: 04:29am 07 Aug 2017
Neat idea.
Posted: 06:37am 07 Aug 2017
Good idea.
I would use a single LS138 or use half of a LS139.
This will save one chip, which can be a lot on a PCB.
If you choose a LS139 you would be able to use maximum 4 LCD's and you still have the other half available to for instance connect 4 other SPI device like SD cards.
Edited by MicroBlocks 2017-08-08
Posted: 07:25am 07 Aug 2017
yes a proper selector would reduce the chip count for the CS reverse mux... I was trying to do it from spare gates.
I was surprised how little aggro this gave me. It would be a degree more complex if you wanted touch input. I was thinking of using pages to handle the on-screen gadgets etc... will play with this later but for now I just need display space and this fits the bill.
I think it opens up a range of possibilities, the use of a single '154 would give 16 displays! It has to be one of the simplest solutions to a "display wall" yet! The bezel round the displays would get in the way a bit, but much less than old school
GoodToGo!
Posted: 03:13pm 07 Aug 2017
I like it!
Nathan
Posted: 03:05pm 22 Aug 2017
  CaptainBoing said   I have a requirement for driving two LCD panels from a single micromite (I need wide not big). I have no requirement for touch or gadgets on the screen, just display space. They will be mounted behind a piece of smoked perspex to hide the gap between the panels.
Hi please take a look into the following folder:
Micromite_Firmware 5.04.05
Embedded C Modules\ST7735 LCD\Driver with Transparency
dispLoad.bas
dualDisplay.bas
dispDriverSPI_R0-pdf
there is an implementation for 28 and 44 pin available.
It supports ST7735 and ILI9341 up to two displays (mixture possible)
Nathan
Posted: 11:05pm 22 Aug 2017
Thanks Nathan - that is really interesting. I hadn't seen it before as I was still using 5.04.04 documentation so the embedded C modules weren't there - downloaded x.x.05 from Geoff's site.
Interested to see that the 7735 driver will work with the 9341 with a connection tweak.
Will play
cheers
Nathan
Posted: 09:27am 23 Aug 2017
it is a little bit more komplex.
Both displays requires different initialization sequences and
interface handling. Also the display size is different so
during switching between the displays some additional things have
to be done. The driver is doing it under the hood.
The driver has also an C-API so that the maintenance/support function
can call the main driver. So you can include only the C-Functions,
which are required for your program.
required:
main driver is: dispDriverSPI_SI (dispLoad.bas -> instructions in the file)
on demand:
c-api functions are:
description in --> dualDisplay.bas
dSetDisplay(num) 0,1 to select the display
dSetOri(num) 1,2,3,4 to set orientation (text rotate for example)
description in --> move.bas
dCopyVRam2Array( array,x,y,width,heigth) copy area of tft into array
dCopyArray2VRamXY( array,x,y) copy array data at screen positio
dSetSyncMagicNum(num) only ili9341 sync output do reduce flicker
dRestoreCopyDrawArea(rem mode=0, sourceArray, backupArray, x, y, sync=0,1)
restore old background ->
save new background at x,y ->
draw new source Array at x,y(if valid)
dCopyArray2VRam(array,sync) copy the background array back
dSetOri(num) look at dualDisplay.bas
I have some more functions, which I did not opened, yet.
dDefineWriteRegion(x1,y1,x2,y2) set drawing window
dWriteRGB2VRAM(bitMapRGBarray,bitMapLength) write rgb data to screen
dSyncXY(x,y) sync to screen ili9341 only
Nathan
