Local Time 23:51 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for DOS new console color scheme
Posted: 05:10am 03 Aug 2017
Microsoft announced a change to the color scheme that is used in the Console.
This will greatly improve the readability of many background/foreground combinations.
link here: https://blogs.msdn.microsoft.com/commandline/2017/08/02/updating-the-windows-console-colors/
You can even change the color palette! for even more choices.Edited by MicroBlocks 2017-08-04
BobD
Posted: 11:40am 03 Aug 2017
  MicroBlocks said   Microsoft announced a change to the color scheme that is used in the Console.
There seems to be a bit more than that. In your link above there is a link to more info on colours.
One of the blogs at the above link has this item
[quote]FWIW though; we’re in a state of transition: Now that the Windows Console supports most VT/ANSI sequences[/quote]
He is referring to later builds of Win 10. I did some checking and this capability was recently introduced.
For those people with a fully updated Win 10, MMBasic for DOS may be able to issue ANSI sequences that work. I haven't tested it so far as I don't run MMB for DOS. I may try in several days when I get back home.
I recall that there was a recent thread which talked about cursor positioning etc. This may negate the need for this development unless you're still running backward versions of Windows.
