Local Time 07:53 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Declare CONST inside SUB?
Posted: 02:57pm 24 Jul 2017
Hi there.
I am trying to tidy up a program, and wanted to put all the CONST commands inside a sub, then call that, so you have three or four SUB's that are called at the top of the program, that setup all the system stuff.
Whenever I do this, it fails and none of the CONST take effect, so the system falls over. NONE of the CONST get declared, even though the SUB exits fine. All the Const inside the SUB.
If I revert back to the code where they are all declared at the top of the code(IE: not inside a sub), then everything works fine.
Can you not declare CONST inside a SUB? I thought you could do pretty much anything you wanted inside a SUB.....
Posted: 03:22pm 24 Jul 2017
The whole point about a CONST is that you collect them at the top of the program so they are not scattered around and it is a lot more maintainable.
If those values are only used in the subroutine itself then you have to consider using hardcoded values instead (if they never change (constant)) or use LOCAL variables at the top of the subroutine to hold those values.
Posted: 03:25pm 24 Jul 2017
it does sound like CONST is treated as a local command. as a workaround, you could tuck away the constants at the end of your code with a RETURN and the end of them, and then call that block of code with GOSUB.
rob :-)
Posted: 03:42pm 24 Jul 2017
Hello chaps.
I do not care, I just thought is was neater - to me.
Having said that, I am happy to leave them at the top of the code, I was just curious.
VK2MCT
Posted: 03:48pm 24 Jul 2017
Cludgy but works (Gosub would only be called once anyway),
const test1 = 1
goto listofconst:
resumemain:
print test1
print test2
end
listofconst:
const test2 = 2
goto resumemain:
John BEdited by VK2MCT 2017-07-26
flip
Posted: 05:10pm 24 Jul 2017
Within a procedure, if you're happy to keep scope limited to within the subroutine, (and the space will be restored when exiting) use
LOCAL AS STRING scName="Constant"
, and make sure you don't set the value anywhere in your procedure...note scName...sc=String Constant, and Name is the meaningful name.
(this is just one of thousands of methods...the other ideas are really good too)...just depends what your priorities are...
EDIT: sorry - re-read your question - I missed the point my point answers a slightly different question..
Phil
Edited by flip 2017-07-26
