Local Time 07:54 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SetPin "OC"
palcal
Posted: 12:22pm 20 Jul 2017
From the manual:
  Quote  The "OC" option on the SETPIN command makes the output pin open collector.
However in the COMMANDS section there is no mention of its use. So do I use
SETPIN(pin),OC. If so can I use it with the command SETPIN(pin),0 on a 5v tolerant pin to sink 5v. from a reed relay that draws 10mA. If that is OK how do I return the pin to OFF do I use SETPIN(pin),OFF or SETPIN(PIN),1
Paul.Edited by palcal 2017-07-21
Posted: 01:41pm 20 Jul 2017
SETPIN(mypin),DOUT,OC to configure the pin
PIN(mypin) = 1 and PIN(mypin) = 0 to turn it on and off
SETPIN(mypin),OFF to return the pin to unconfigured state (high impedance).
palcal
Posted: 01:47pm 20 Jul 2017
Thanks Jim, I'll see if I can activate the relay.
Paul.
Phil23
Posted: 11:33am 21 Jul 2017
Hi Paul,
I'm driving a stack of relays which are all OC & Opto coupled, 5V & with 8 on one particular controller, they don't all end up on 5V pins, but have still all worked fine for over 18 months.
I configure my pins with a line like this, simply so the relays default to the off state.
[Code]SetPin(Fan1L),DOUT,OC : Pin(Fan1L)=1[/code]
Phil.
palcal
Posted: 11:23am 22 Jul 2017
Thanks for that Phil, I could no get mine to operate so I ordered a 3 volt relay.
I will test the relay first and have another try.
Paul.
Posted: 06:18pm 22 Jul 2017
Hi Paul,
Silly question. You are using a PULL-UP resistor on your OC pin aren't you?
Kind Regards,
EDIT***
You should also be driving the pin LOW to activate your relays (ie. supplying the GND not the Source)
MikEdited by bigmik 2017-07-24
centrex
Posted: 08:19pm 22 Jul 2017
Sorry Mick
If the relay is connected to plus 5 volts and the other side of the relay to the open collector pin, when the pin is pulled low the relay will operate.
Please don't forget the back emf diode across the relay coil or you could kill the chip.
Cliff
palcal
Posted: 10:52pm 22 Jul 2017
Thanks to all, I have the back emf diode in place and it is working OK now.
Paul.
@ Centrex
I think that is what Mick said.
