Local Time 07:53 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX/RPI/DOS - interplanetary injection
cdeagle
Posted: 08:57am 20 Jul 2017
This post describes a MMBASIC program that solves one of my favorite problems in geometry and orbital mechanics. The program is named hyper1.bas and tackles the problem of interplanetary injection from a circular Earth orbit. The numerical method is due to Professor Richard Battin.
The solution of this problem provides an initial estimate of the delta-v and energy required to transfer a spacecraft onto an interplanetary trajectory (perhaps to Mars) from a circular orbit about the Earth. It also provides the approximate geometry of the possible Earth departure hyperbolas.
Here's a typical user interaction and program output ...
Interplanetary Injection from a Circular Earth Park Orbit
please input the altitude of the circular Earth park orbit (kilometers)
? 185.32
please input the orbital inclination of the Earth park orbit (degrees)
(0 <= inclination <= 180)
? 28.5
please input the C3 of the departure hyperbola (kilometers^2/second^2)
(C3 > 0)
? 9.28
please input the right ascension of the outgoing asymptote (degrees)
(0 <= right ascension <= 360)
? 352.59
please input the declination of the outgoing asymptote (degrees)
? 2.27
departure hyperbola characteristics
c3 9.2800 kilometers^2/second^2
asymptote right ascension 352.590000 degrees
asymptote declination 2.270000 degrees
orbital elements and state vector of park orbit at injection - opportunity #1
semimajor axis 6563.4600 kilometers
eccentricity 0.0000000000
orbital inclination 28.5000 degrees
argument of perigee 0.0000 degrees
RAAN 176.7767 degrees
true anomaly 25.0750 degrees
position vector x-component -6.072921967203e+03 kilometers
position vector y-component -2.106409915567e+03 kilometers
position vector z-component 1.327276617537e+03 kilometers
position vector magnitude 6.563460000000e+03 kilometers
velocity vector x-component 2.948684715564e+00 kilometers/second
velocity vector y-component -6.379019476975e+00 kilometers/second
velocity vector z-component 3.368026111924e+00 kilometers/second
velocity vector magnitude 7.792960344441e+00 kilometers/second
orbital elements and state vector of hyperbola at injection - opportunity #1
semimajor axis -42952.6338 kilometers
eccentricity 1.1528069276
argument of perigee 25.0750 degrees
RAAN -3.2233 degrees
true anomaly 0.0000 degrees
velocity vector x-component 4.326441938393e+00 kilometers/second
velocity vector y-component -9.359582340336e+00 kilometers/second
velocity vector z-component 4.941718367961e+00 kilometers/second
velocity vector magnitude 1.143417954468e+01 kilometers/second
injection delta-v vector and magnitude - opportunity #1
x-component of delta-v 1377.757223 meters/second
y-component of delta-v -2980.562863 meters/second
z-component of delta-v 1573.692256 meters/second
delta-v magnitude 3641.219200 meters/second
orbital elements and state vector of park orbit at injection - opportunity #2
RAAN 348.4033 degrees
true anomaly 214.5981 degrees
position vector x-component -5.950846004649e+03 kilometers
position vector y-component -2.122286481036e+03 kilometers
position vector z-component -1.778296683053e+03 kilometers
velocity vector x-component 3.201396629997e+00 kilometers/second
velocity vector y-component -6.411885875654e+00 kilometers/second
velocity vector z-component -3.060883869907e+00 kilometers/second
orbital elements and state vector of hyperbola at injection - opportunity #2
argument of perigee 34.5981 degrees
RAAN -11.5967 degrees
true anomaly 360.0000 degrees
velocity vector x-component 4.697232148402e+00 kilometers/second
velocity vector y-component -9.407805388687e+00 kilometers/second
velocity vector z-component -4.491065549808e+00 kilometers/second
injection delta-v vector and magnitude - opportunity #2
x-component of delta-v 1495.835518 meters/second
y-component of delta-v -2995.919513 meters/second
z-component of delta-v -1430.181680 meters/second
Here's a link to a PDF file of the MATLAB version with illustrations of the orbital geometry.
2017-07-20_185149_hyper1_matlab.pdf
Here's the MMBASIC source code.
' hyper1.bas July 20, 2017
' Battin's method for single impulse coplanar hyperbolic
' injection from a circular Earth park orbit
' MMBASIC for MMX, Raspberry Pi and DOS
option default float
option base 1
dim pv(3), shat(3), rhat1(3), rhat2(3)
dim rpo1(3), vpo1(3), oev_po1(6)
dim rpo2(3), vpo2(3), oev_po2(6)
dim rhyper1(3), vhyper1(3), oev_hyper1(6)
dim rhyper2(3), vhyper2(3), oev_hyper2(6)
dim deltav1(3), deltav2(3)
' angular conversion factors
const pi2 = 2.0 * pi, rtd = 180.0 / pi, dtr = pi / 180.0
' gravitational constant of the Earth (kilometers^3/second^2)
const mu = 398600.4415
' equatorial radius of the Earth (kilometers)
const req = 6378.14
' request user inputs
print " "
print "Interplanetary Injection from a Circular Earth Park Orbit"
print "---------------------------------------------------------"
print " "
do
print " "
print "please input the altitude of the circular Earth park orbit (kilometers)"
input alt
if (alt > 0.0) then exit do
loop
do
print " "
print "please input the orbital inclination of the Earth park orbit (degrees)"
print "(0 <= inclination <= 180)"
input orbinc
if (orbinc >= 0.0 and orbinc <= 180.0) then exit do
loop
do
print " "
print "please input the C3 of the departure hyperbola (kilometers^2/second^2)"
print "(C3 > 0)"
input c3
if (c3 > 0.0) then exit do
loop
do
print " "
print "please input the right ascension of the outgoing asymptote (degrees)"
print "(0 <= right ascension <= 360)"
input rasc
if (rasc >= 0.0 and rasc <= 360.0) then exit do
loop
do
print " "
print "please input the declination of the outgoing asymptote (degrees)"
input decl
if (abs(decl) <= 90.0) then exit do
loop
if (abs(decl) >= orbinc) then
print " "
print "*********************************************************************"
print "Please note: this program is valid for |DLA| < park orbit inclination"
end
end if
' geocentric radius of park orbit (kilometers)
rpmag = req + alt
' convert angular elements to radians
xinc = orbinc * dtr
decl_asy = decl * dtr
rasc_asy = rasc * dtr
' v-infinity (km/sec)
vinf = sqr(c3)
' unit vector along the Earth's spin axis
pv(1) = 0.0
pv(2) = 0.0
pv(3) = 1.0
cdecl_asy = cos(decl_asy)
sdecl_asy = sin(decl_asy)
crasc_asy = cos(rasc_asy)
srasc_asy = sin(rasc_asy)
' compute unit asymptote vector
shat(1) = cdecl_asy * crasc_asy
shat(2) = cdecl_asy * srasc_asy
shat(3) = sdecl_asy
' beta = angle between unit asymptote vector and spin axis
beta = acos(vdot(pv(), shat()))
sum1 = acos(cos(beta) / sin(xinc))
' alpha = angle between unit asymptote vector and position vector
alpha = asin(1.0 / (1.0 + rpmag * vinf * vinf / mu))
' tangential injection
' injection argument of latitude #1
arglat1 = modulo(sum1 - alpha)
' injection argument of latitude #2
arglat2 = modulo(-sum1 - alpha)
' injection raan #1
raan1 = modulo(rasc_asy + pi + asin(cotan(beta) / tan(xinc)))
' injection raan #2
raan2 = modulo(rasc_asy + 2.0 * pi - asin(cotan(beta) / tan(xinc)))
' opportunity #1 - park orbit state vector and orbital elements
oev_po1(1) = rpmag
oev_po1(2) = 0.0
oev_po1(3) = xinc
oev_po1(4) = 0.0
oev_po1(5) = raan1
oev_po1(6) = arglat1
orb2eci(oev_po1(), rpo1(), vpo1())
uvector(rpo1(), rhat1())
ctheta = vdot(shat(), rhat1())
d = sqr(mu / ((1.0 + ctheta) * rpmag) + vinf * vinf / 4.0)
' velocity vector of hyperbola at injection
for i% = 1 to 3
vhyper1(i%) = (d + 0.5 * vinf) * shat(i%) + (d - 0.5 * vinf) * rhat1(i%)
next i%
' injection delta-v vector
for i% = 1 to 3
deltav1(i%) = vhyper1(i%) - vpo1(i%)
rhyper1(i%) = rpo1(i%)
next i%
eci2orb(rhyper1(), vhyper1(), oev_hyper1())
print " "
print " "
print "departure hyperbola characteristics"
print "-----------------------------------"
print " "
print "c3 ", str$(c3, 0, 4) + " kilometers^2/second^2"
print " "
print "asymptote right ascension ", str$(rtd * rasc_asy, 0, 6) + " degrees"
print " "
print "asymptote declination ", str$(rtd * decl_asy, 0, 6) + " degrees"
print " "
print "orbital elements and state vector of park orbit at injection - opportunity #1"
print "-----------------------------------------------------------------------------"
print " "
oeprint(oev_po1())
svprint(rpo1(), vpo1())
print " "
print "orbital elements and state vector of hyperbola at injection - opportunity #1"
print "----------------------------------------------------------------------------"
print " "
oeprint(oev_hyper1())
svprint(rhyper1(), vhyper1())
print " "
print "injection delta-v vector and magnitude - opportunity #1"
print "-------------------------------------------------------"
print " "
print "x-component of delta-v ", str$(1000.0 * deltav1(1), 0, 6) + " meters/second"
print " "
print "y-component of delta-v ", str$(1000.0 * deltav1(2), 0, 6) + " meters/second"
print " "
print "z-component of delta-v ", str$(1000.0 * deltav1(3), 0, 6) + " meters/second"
print " "
print "delta-v magnitude ", str$(1000.0 * vecmag(deltav1()), 0, 6) + " meters/second"
print " "
' opportunity #2 - park orbit state vector
oev_po2(1) = rpmag
oev_po2(2) = 0.0
oev_po2(3) = xinc
oev_po2(4) = 0.0
oev_po2(5) = raan2
oev_po2(6) = arglat2
orb2eci(oev_po2(), rpo2(), vpo2())
uvector(rpo2(), rhat2())
ctheta = vdot(shat(), rhat2())
for i% = 1 to 3
vhyper2(i%) = (d + 0.5 * vinf) * shat(i%) + (d - 0.5 * vinf) * rhat2(i%)
next i%
for i% = 1 to 3
deltav2(i%) = vhyper2(i%) - vpo2(i%)
rhyper2(i%) = rpo2(i%)
next i%
eci2orb(rhyper2(), vhyper2(), oev_hyper2())
print " "
print "orbital elements and state vector of park orbit at injection - opportunity #2"
print " "
oeprint(oev_po2())
svprint(rpo2(), vpo2())
print " "
print "orbital elements and state vector of hyperbola at injection - opportunity #2"
print " "
oeprint(oev_hyper2())
svprint(rhyper2(), vhyper2())
print " "
print "injection delta-v vector and magnitude - opportunity #2"
print " "
print "x-component of delta-v ", str$(1000.0 * deltav2(1), 0, 6) + " meters/second"
print " "
print "y-component of delta-v ", str$(1000.0 * deltav2(2), 0, 6) + " meters/second"
print " "
print "z-component of delta-v ", str$(1000.0 * deltav2(3), 0, 6) + " meters/second"
print " "
print "delta-v magnitude " str$(1000.0 * vecmag(deltav2()), 0, 6) + " meters/second"
print " "
end
sub eci2orb(r(), v(), oev())
' convert eci state vector to classical orbital elements
' input
' r() = eci position vector (kilometers)
' v() = eci velocity vector (kilometers/second)
' output
' oev(1) = semimajor axis (kilometers)
' oev(2) = orbital eccentricity (non-dimensional)
' (0 <= eccentricity < 1)
' oev(3) = orbital inclination (radians)
' (0 <= inclination <= pi)
' oev(4) = argument of perigee (radians)
' (0 <= argument of perigee <= 2 pi)
' oev(5) = right ascension of ascending node (radians)
' (0 <= raan <= 2 pi)
' oev(6) = true anomaly (radians)
' (0 <= true anomaly <= 2 pi)
local rmag, vmag, sma, p, q, const1
local h, xk, x1, y1, eccm, inc, xlambdat
local raan, argper, tanom
local rhat(3), vhat(3), hhat(3), vtmp(3), ecc(3)
local hv(3), fhat(3), ghat(3)
' position and velocity magnitude
rmag = vecmag(r())
vmag = vecmag(v())
' position and velocity unit vectors
uvector(r(), rhat())
uvector(v(), vhat())
' angular momentum vectors
vcross(r(), v(), hv())
uvector(hv(), hhat())
' eccentricity vector
for i% = 1 to 3
vtmp(i%) = v(i%) / mu
next i%
vcross(vtmp(), hv(), ecc())
for i% = 1 to 3
ecc(i%) = ecc(i%) - rhat(i%)
next i%
' semimajor axis
sma = 1.0 / (2.0 / rmag - vmag^2 / mu)
' keplerian period
if (sma > 0.0) then
period = pi2 / sqr(mu / sma^3)
else
period = 0.0
end if
p = hhat(1) / (1.0 + hhat(3))
q = -hhat(2) / (1.0 + hhat(3))
const1 = 1.0 / (1.0 + p^2 + q^2)
fhat(1) = const1 * (1.0 - p^2 + q^2)
fhat(2) = const1 * 2.0 * p * q
fhat(3) = -const1 * 2.0 * p
ghat(1) = const1 * 2.0 * p * q
ghat(2) = const1 * (1.0 + p^2 - q^2)
ghat(3) = const1 * 2.0 * q
h = vdot(ecc(), ghat())
xk = vdot(ecc(), fhat())
x1 = vdot(r(), fhat())
y1 = vdot(r(), ghat())
' orbital eccentricity
eccm = sqr(h * h + xk * xk)
' orbital inclination
inc = 2.0 * atn(sqr(p * p + q * q))
' true longitude
xlambdat = atan3(y1, x1)
' check for equatorial orbit
if (inc > 1.0e-10) then
raan = atan3(p, q)
else
raan = 0.0
end if
' check for circular orbit
if (eccm > 1.0e-10) then
argper = modulo(atan3(h, xk) - raan)
else
argper = 0.0
end if
' true anomaly
tanom = modulo(xlambdat - raan - argper)
oev(1) = sma
oev(2) = eccm
oev(3) = inc
oev(4) = argper
oev(5) = raan
oev(6) = tanom
end sub
sub orb2eci(oev(), r(), v())
' convert orbital elements to state vector subroutine
' input
' (0 <= oev(3) <= pi)
' (0 <= oev(4) <= 2 pi)
' oev(5) = right ascension of ascending node or
' east longitude of ascending node (radians)
' (0 <= oev(5) <= 2 pi)
' (0 <= oev(6) <= 2 pi)
' output
' r() = geocentric, equatorial position vector (kilometers)
' v() = geocentric, equatorial velocity vector (kilometers/second)
' special notes
' (1) eci coordinates if oev(5) = raan
' (2) ecf coordinates if oev(5) = east longitude
' (3) valid for elliptic and hyperbolic orbits
local sma, ecc, inc, argper, nangle, tanom
local slr, rm, arglat, sarglat, carglat
local sinc, cinc, snangle, cnangle, c1, c2, c3
' "unload" orbital elements array
sma = oev(1)
ecc = oev(2)
inc = oev(3)
argper = oev(4)
nangle = oev(5)
tanom = oev(6)
' semiparameter
slr = sma * (1.0 - ecc * ecc)
' radius magnitude
rm = slr / (1.0 + ecc * cos(tanom))
' argument of latitude
arglat = argper + tanom
sarglat = sin(arglat)
carglat = cos(arglat)
sinc = sin(inc)
cinc = cos(inc)
snangle = sin(nangle)
cnangle = cos(nangle)
c1 = sqr(mu / slr)
c2 = ecc * cos(argper) + carglat
c3 = ecc * sin(argper) + sarglat
' x, y and z components of the position vector
r(1) = rm * (cnangle * carglat - snangle * cinc * sarglat)
r(2) = rm * (snangle * carglat + cinc * sarglat * cnangle)
r(3) = rm * sinc * sarglat
' x, y and z components of the velocity vector
v(1) = -c1 * (cnangle * c3 + snangle * cinc * c2)
v(2) = -c1 * (snangle * c3 - cnangle * cinc * c2)
v(3) = c1 * c2 * sinc
end sub
sub svprint(r(), v())
' print position and velocity vectors subroutine
local rmag, vmag
print "position vector x-component ", str$(r(1), 0, -12) + " kilometers"
print "position vector y-component ", str$(r(2), 0, -12) + " kilometers"
print "position vector z-component ", str$(r(3), 0, -12) + " kilometers"
rmag = vecmag(r())
print " "
print "position vector magnitude ", str$(rmag, 0, -12) + " kilometers"
print " "
print "velocity vector x-component ", str$(v(1), 0, -12) + " kilometers/second"
print "velocity vector y-component ", str$(v(2), 0, -12) + " kilometers/second"
print "velocity vector z-component ", str$(v(3), 0, -12) + " kilometers/second"
vmag = vecmag(v())
print " "
print "velocity vector magnitude ", str$(vmag, 0, -12) + " kilometers/second"
end sub
sub oeprint(oev())
' print classical orbital elements subroutine
print "semimajor axis ", str$(oev(1), 0, 4) + " kilometers"
print "eccentricity ", str$(oev(2), 0, 10)
print "orbital inclination ", str$(rtd * oev(3), 0, 4) + " degrees"
print "argument of perigee ", str$(rtd * oev(4), 0, 4) + " degrees"
print "RAAN ", str$(rtd * oev(5), 0, 4) + " degrees"
print "true anomaly ", str$(rtd * oev(6), 0, 4) + " degrees"
print " "
end sub
function modulo(x) as float
' modulo 2 pi function
local a
a = x - pi2 * fix(x / pi2)
if (a < 0.0) then
a = a + pi2
end if
modulo = a
end function
function atan3(a, b) as float
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' atan3 = angle (0 =< atan3 <= 2 * pi; radians)
local c
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
function vecmag(a()) as float
' vector magnitude function
' input
' { a } = column vector ( 3 rows by 1 column )
' output
' vecmag = scalar magnitude of vector { a }
vecmag = sqr(a(1) * a(1) + a(2) * a(2) + a(3) * a(3))
end function
sub uvector (a(), b())
' unit vector subroutine
' input
' a = column vector (3 rows by 1 column)
' output
' b = unit vector (3 rows by 1 column)
local i%, amag
amag = vecmag(a())
for i% = 1 to 3
if (amag <> 0.0) then
b(i%) = a(i%) / amag
else
b(i%) = 0.0
end if
next i%
end sub
sub vcross(a(), b(), c())
' vector cross product subroutine
' { c } = { a } x { b }
' input
' { a } = vector a ( 3 rows by 1 column )
' { b } = vector b ( 3 rows by 1 column )
' output
' { c } = { a } x { b } ( 3 rows by 1 column )
c(1) = a(2) * b(3) - a(3) * b(2)
c(2) = a(3) * b(1) - a(1) * b(3)
c(3) = a(1) * b(2) - a(2) * b(1)
end sub
function vdot(a(), b()) as float
' vector dot product function
' c = { a } dot { b }
' input
' n% = number of rows
' { a } = column vector with n rows
' { b } = column vector with n rows
' output
' vdot = dot product of { a } and { b }
local i%, c = 0.0
for i% = 1 to 3
c = c + a(i%) * b(i%)
next i%
vdot = c
end function
function cotan(x) as float
' cotangent function
' x is input value
cotan(x) = 1.0 / tan(x)
end function
vegipete
Posted: 11:15am 21 Jul 2017
Ah, the remarkable march of technology. A few dollars worth of computer can calculate this sort of thing now. How many tons of computer at what cost at what power consumption did NASA need to do this 50 years ago?
