Local Time 22:42 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PLAY WAV - PROGRAMM STOPS
rentner111
Posted: 12:10am 20 Jul 2017
Hi Geoff!
The implementation of "PLAY WAV" in the Basic of the PIC470 is a great thing.
Unfortunately the running program remains about one second before WAV end to the
WAV end hang. It does not matter if the announcement is long or short.
Here is a small demonstration program:
The announcement is started.
The LED flashes in the DO - LOOP.
About one second before WAV end, the LED stops flashing.
After WAV end, the LED flashes again.
Best greetings from Tyrol / Austria
Option autorun
LED = 1
Setpin LED, dout
PLAY WAV "TEST.WAV", WAVEND ()
do
Pin (LED) = 0 'LED flashing
Pause 50
pin (LED) = 1
Pause 50
loop
Sub WAVEN ()
Print "PLAY END"
End sub
end
Posted: 03:09am 20 Jul 2017
Well, I'm not Geoff, but.....
MMBASIC probably does not like the double-parenthesis.
I would drop that so your code just looks like:
Option autorun
LED = 1
Setpin LED, dout
do
Pause 50
pin (LED) = 1
Pause 50
loop
Sub WAVEND
Print "PLAY END"
End sub
end
[/Code]
Not tested, but I did do plenty of testing on the PLAY WAV command, and never had that hanging problem - I THINK it is coming from the fact that you are calling your sub from the PLAY WAV command, and MMBASIC is interpreting that as passing an array via the () syntax, so it tries to call WAVEND as a sub, but also tries to treat that as passing an array at the same time, and crashes.
I might have that wrong, but that is how I interpret it anyway. I would be very interested to know how you go if you remove the ().....
rentner111
Posted: 05:51am 20 Jul 2017
Hi Grogster!
Thanks for the answer.
I have tested the following program without ().
Option autorun on
LED = 1
Setpin LED, dout
PLAY WAV "alisauhr.WAV"
do
Pause 50
Pin (LED) = 1
Pause 50
loop
end
It is the same result. The length of the WAV file is 10 seconds.
The LED flashes until the 9th second.
From 9th to 10th no flashing of the LED.
Then the LED flashes again.
LED flashing means that the DO-LOOP is going through.
Thank you very much
Posted: 06:01am 20 Jul 2017
Try a different SD card and/or other wave file.
Posted: 05:16pm 20 Jul 2017
If you are saying that what you get is(in pseudo-code):
START {OK}
PLAY FILE {OK}
START BLINKING LED {OK}
FILE PLAYBACK ENDS {OK}
LED STOPS FLASHING FOR ONE SECOND OR SO THEN STARTS AGAIN {OK}
[/Code]
This may be normal - I never tested the time it takes for MMBASIC to return from playing a file in the background. matherp or Geoff would indeed be able to tell you if that is normal, but this short delay at the end of playback could, in fact, be normal.
Your code seems to halt at the end of playback(not your doing), but then resumes a second or so later, which may be unwanted, but normal. We'll wait and see what the guru's say.
rentner111
Posted: 09:50pm 20 Jul 2017
The program will actually stay for about 1100 msec.
If the WATCHDOG 1000 command is activated, a restart is carried out by the watchdog at the end of the PLAY WAV command.
Only at WATCHDOG> 1100 is no restart.
Best regards from Tyrol / Austria
Posted: 10:08pm 20 Jul 2017
Interesting......
I will bow out now, and watch to see if one of the guru's chime in with any ideas.
panky
Posted: 06:23pm 23 Jul 2017
Erwin,
Interesting and clever use of the WATCHDOG command for faultfinding.
Doug.
PicFan
Posted: 10:10pm 02 Aug 2017
Yes, the pause is unfortunately very disturbing if one wants to form sentences from individual words. The interrupt is also about 1 sec. delayed. For example, for a time announcement.
Wolfgang
Posted: 06:28am 07 Nov 2017
I've just fixed this for the Micromite eXtreme. I'll notify Geoff of the fix to include in a future release for the MM+ - it is the same code.
