Local Time 07:53 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SD Card help
jman
Posted: 11:50pm 08 Jul 2017
Hi
Could somebody post an example of the required synatx for the DIR$ function
"DIR$( fspec, type )
Will search an SD card for files and return the names of entries found."
And while we are at it is a there a simple way to check if an SD card is present?
Jman
Posted: 12:41am 09 Jul 2017
dir$ is a function that returns one filename at a time
type can be DIR, FILE, or ALL
fspec is a search string
so
a$=dir$("*.bas",FILE)
will return the first filename with the extension ".bas"
a$=dir$("*",DIR)
will return any sub directories
To get subsequent files/directories with the same search parameters use
a$=dir$()
if a$="" then end of matching files
  Quote  And while we are at it is a there a simple way to check if an SD card is present?
If the sdcard has a card detect pin enabled in the OPTION command then you can read this with a normal PIN(n) function, otherwise no
Edited by matherp 2017-07-10
jman
Posted: 09:41am 09 Jul 2017
Thank you Peter
That explains it perfectly.
Jman
