Local Time 00:45 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : does anyone else get this?
Posted: 04:06am 06 Jul 2017
Hello all.
MMBasic 5.04.04 MM '170 28 pin
getting odd behaviour from ON ERROR SKIP ...
On error skip 1 ' test 1
Print "1 worked"
On error skip: ' test 2
Print "2 worked"
On error skip ' test 3
Print "3 worked"
I usually test stuff like this on more than one platform before squeaking but I only have one on at the moment and working remotely
Edited by CaptainBoing 2017-07-07
Posted: 04:44am 06 Jul 2017
is the same in 5.04.05. the problem seems to be that ON ERROR SKIP is interpreting the comment as part of the command.
On ERROR SKIP ' this is a comment
Print "worked"
> run
[1] On ERROR SKIP ' this is a comment
Error: Syntax
rob :-)
Posted: 04:49am 06 Jul 2017
Cheers Robert - it's an easy avoid, just wanted the headsup
It doesn't always seem to happen though - I have tried to pin it down a bit. I even tweaked a bit of 5.2 code to have a skip of 1 because it was failing - I put it down to no default anymore but there does seem to be a wrinkle.
moving the comment to the next line it all works ok and if you enter the line in direct mode (at the > prompt) it doesn't mind the comment. oddEdited by CaptainBoing 2017-07-07
