Local Time 07:30 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 5.4.04 Strange behavior.
Phil23
Posted: 10:27pm 16 Jun 2017
Getting this on breaking to a prompt.
[Code]> print mm.ver
5.0404
> edit
> list
> run
> ? "Hello"
> Print mm.ver
>[/code]
It is unresponsive....
A few Ctrl-C's will get it back.
What I think has triggered it is a failed xmodem send.
Repeated attempts to download a log file failed at block 254.
File size was just over 34k.
Phil.
Phil23
Posted: 10:36pm 16 Jun 2017
Repeatable.
Xmodem send stops at block 254 32512 bytes.
Console output:
[Code]> xmodem send "testlog.txt"
,12:00:22, 17.19, 31.06, 24.37, 24.69, 28.44, 5.09,¸Error: Cancelled by remote
> print mm.ver
5.0404
> print mm.ver
> print mm.ver
> print mm.ver
>[/code]
Phil.
Running it on a CGMicro.
File size is 34345 bytes.Edited by Phil23 2017-06-18
