Local Time 07:20 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Dumb RF 433MHz Module Code
GoodToGo!
Posted: 02:46pm 30 May 2017
Howdy All,
While waiting for my NRF24L01+ and HC-12's modules to arrive from the Land of the Great White Beef with Broccoli, I decided to have a tinker around with a few Dumb RF modules I have kicking around.
I've come to realise they are crap.
However after much research around the forums, I managed to un-crap them enough so they work alright.
The Transmitter Code:-
'Dumb RF Module example Transmitter code By GoodToGo! 31/05/17
'Transmitter code
option Explicit
dim STX$ as string = chr$(&h02) 'Start Byte
dim ETX$ as string = chr$(&h03) 'End Byte
dim Slice$ as string = "UUUUUUUUUUUUUUU" 'For RF module calibration
dim Message$ as string
dim Payload$ as string
dim i as integer
Message$ = "He sells seashells by the seashore"
Open "COM1:9600" as #1
Payload$ = Message$ + Chksum(Message$) 'Adds the checksum to the Message
do
print "Sending Payload"
for i = 1 to 4
Print #1, Slice$ + STX$ + Payload$ + ETX$
next i
pause 5000
loop
function Chksum(Message$) as string 'Creates Checksum of the Payload
local c as integer = 0
local b as integer = 0
local i as integer = len(Message$)
local a$ as string
do while (i) > 0
a$ = "&b"+bin$(asc(mid$(Message$,i,1)))
c = val(a$)
b = b xor c
i=i-1
loop
Chksum = chr$(b)
end function
And the Receiver Code:-
'Dumb RF Module example Receiver code by GoodToGo! 31/05/17
'Receiver Code
option explicit
const MaxMsgLength =50 'Change if your Message is going to be higher
dim Rcvdata$ as string
dim RxdMsg$ as string
dim RxdDataFlag as integer = 0
dim InvalidMsgFlag as integer = 0
dim ValidMsgFlag as integer = 0
dim Debug = 0 'Change to 1 for extra info to the Console
open "com1:9600" as #1
'Main Loop
do
'Stuff goes here
If InvalidMsgFlag then InvalidMessage
If ValidMsgFlag then PrintMessage
if loc(#1) > 10 then ChkBuffer
loop
sub ChkBuffer 'Received something
local Checksum$ as string = ""
RcvData$ = ""
RxdMsg$ = ""
pause 250 'Time to stack bytes in buffer
If Debug then print "Bytes in Buffer = " str$(loc(#1))
do
RcvData$ = RcvData$ + input$(1, #1) 'Get one byte from buffer
if right$(RcvData$, 1) = STX$ then 'Detected Start Byte
If Debug then print "Startbyte Detected"
exit do
endif
if len(RcvData$) > MaxMsgLength then 'No Start Byte detected
InvalidMsgFlag = 1
exit sub
endif
loop
RcvData$ = ""
RcvData$ = RcvData$ + INPUT$(1, #1) 'Increase D$ by one byte from buffer
IF right$(RcvData$, 1) = ETX$ THEN 'Detected End Byte
If Debug then print "Endbyte Detected"
if Debug then print "Message Length = " +str$(len(RcvData$))
if len(RcvData$) < 2 then 'Detected Start and End but message corrupt
InvalidMsgFlag = 4
exit sub
endif
exit do
endif
InvalidMsgFlag = 2 'No End Byte detected
Exit Sub
endif
Loop
RcvData$ = left$(RcvData$, len(RcvData$) - 1) 'Strip End Byte
Checksum$ = right$(RcvData$, 1) 'Get Checksum
RxdMsg$ = left$(RcvData$, len(RcvData$) - 1) 'Strip Checksum
if Checksum$ = Chksum(RxdMsg$) then 'Checksums match
ValidMsgFlag = 1 'We have a good message
exit sub
else
InvalidMsgFlag = 3 'Checksums don't match
endif
end sub
sub PrintMessage
Print "Message Received:- " + RxdMsg$
ValidMsgFlag = 0
end sub
sub InvalidMessage
Select case InvalidMsgFlag
case 1
If Debug then print "***No Start Byte Found***"
Case 2
if Debug then print "***No End Byte Found***"
case 3
if Debug then print "***Checksum Failed***"
case 4
if Debug then Print "***Incorrect Message Length***"
END SELECT
InvalidMsgFlag = 0
end sub
function Chksum(message$) as string 'Creates Checksum of the received Message
local i as integer = len(message$)
local a$ as string
do while (i) > 0
a$ = "&b" + bin$(asc(mid$(message$, i, 1)))
c = val(a$)
b = b xor c
i=i-1
loop
Chksum = chr$(b)
end function
I have the Transmitter code running on a MM+ LCD Backpack and the Receiver code running on a Grogster Explore 28.
Two CP2102 TTL-USB Converters connect both modules to the one laptop where I am running two instances of MMedit. (I know I could have just used USB cables intead...)
Works reasonable, especially with the (UGLY) simple checksum routine I cobbled together. I had to send the data 4 times at once to have the best chance of successful reception at 9600 baud. Dropping the baud to 2400 improves the reception without need for multiple sends.
Hope the above routines can assist anyone out there, or conversely, if there are ways to improve the above, please do!
Cheers,
GTG!
drkl
Posted: 06:52pm 30 May 2017
Hello,
Thank you for your published code, but which kind of dumb modules are using?
drkl
Posted: 07:22pm 30 May 2017
Yes, 'Dumb' RF modules do not have ANY processing in them at all.
I find that the Radiometrix dumb-RF module pairs are VERY reliable - even better then the ones with processors on-board most of the time. This is probably cos the Radiometrix ones being designed in the UK, are designed to more of a commercial application market then the hobbyist market.
The Radiometix ones are not cheap either, but the 'You get what you pay for' rule does apply to their modules, as it does to many other things. The Radiometix modules are also fully approved too, which makes integrating them into a commercial product a breeze, as they are already certified for use.
But I digress.....
With 'Dumb' RF modules, you MUST take full control of exactly how the link operates, not just the data you want, but any checking or syncing of the link.
The string of 'U' characters is 10101010 in binary, or 85 decimal, or 55 hex.
The constant alternating 1's and 0's sync the data-slicer in the receiver, effectively eliminating the standard background noise that the receiver will output as random rubbish, so that when the first byte of the actual wanted message arrives at the receiver, the connected data-filter chip can then see the wanted message.
I still use the 8-pin PICAXE chip as a data-filter connected to the 'Dumb' receiver, and it sits and waits for the qualifier and message, and just goes around in loops like that.
I have had extraordinary success with just using 10-15 'U' sync bytes at the start of any message, a qualifier and payload. I generally get a 99% success rate across a 'Dumb' link like that, and with transmitter node re-tries, this effectively comes up to a 100% success rate.
No good for streaming lots of data, but if you only need to send small data packets, then a decent quality 'Dumb' module is the bees-knees IMHO, and I tend to prefer these over smart-modules.
I also like the 'Dumb' modules, as you can have a very slow over-the-air baud-rate, which increases the reliability even more. Smart-modules will tend to accept a certain baud-rate, but the actual over-the-air baud-rate will be very high to keep the on-air duty-cycle as low as possible. But the higher the baud-rate over-the-air, the better the receiver sensitivity has to be to keep up with the higher baud-rate and not miss any data.
Posted: 07:45pm 30 May 2017
  GoodToGo! said
... I decided to have a tinker around with a few Dumb RF modules I have kicking around.
However after much research around the forums, I managed to un-crap them enough so they work alright...
Hi GTG.
Roman Black did a lot of work with these and although the work is primarily aimed at specific PIC code, it is a very valuable resource that I have referred to a lot working with these.
Cheap RF Modules Made Easy
worth pointing out that they seem to come in two common flavours 315MHz and 433MHz which may or may not be licensed for a particular country (unlicensed 315MHz is not permitted in UK) - and they are DIRTY!!! They have really poor separation and can bleed over a wide band of "channels". Even at legal frequencies you might get a knock at the door if you use them for long "on" periods in urban areas.
That said, they are really good for quick and dirty and once you have developed a protocol for handling data, why not? I used a two Rx/Tx pairs to provide a cross-town link (about 450m with external stubby antennas) for a customer to pass orders between his shop and workshop and it is still working really well six years later. Small packets and not terribly frequent at 2400 (edit: it was 1200, just checked) baud. It functions as a transparent pass through with a couple of USB-Serial adapters I built with some custom VB on either side to provide the protocol and encryption (please do the encryption - start as you mean to go on for the "IoT" panic). It just works
hth
Edited by CaptainBoing 2017-06-01
Phil23
Posted: 09:40pm 30 May 2017
  GoodToGo! said  Works reasonable, especially with the (UGLY) simple checksum routine I cobbled together. I had to send the data 4 times at once to have the best chance of successful reception at 9600 baud. Dropping the baud to 2400 improves the reception without need for multiple sends.
Hi GTG,
I'm using HC-12's really successfully at 9600.
Regards the "Ugly Checksum"....
Didn't try & understand it but this is what I'm using.
No my creation, it came via TassyJim, who's pretty good on that sort of stuff.
  Quote  report$= "The Quick Brown Fox Jumps Over the Lazy Dog"
sendit$= crc$(report$)
PRINT report$
PRINT sendit$
PRINT checkcrc(sendit$) ' should be OK (1)
PRINT ("The Quick Brown Fox Jumps over the LazyDog*11") ' should give an error (0)
PRINT checkcrc("The Quick Brown Fox Jumps over the LazyzDog*F6") ' should give an error (0)
FUNCTION crc$(txt$)
LOCAL chksum
FOR n = 1 TO LEN(txt$)
chksum=chksum
XOR ASC(MID$(report$,n,1))
NEXT n
crc$=txt$+
"*"+HEX$(chksum,2)
END FUNCTION
FUNCTION checkcrc(txt$)
LOCAL chksum
FOR n = 1 TO LEN(txt$)-3
chksum=chksum
NEXT n
IF RIGHT$(txt$,3) = "*"+HEX$(chksum,2) THEN ' crc match
checkcrc = 1
ENDIF
END FUNCTION
It's in a post somewhere & I think he said it's the XModem Checksum.
Phil.
Edit:- I Must have fiddled the print lines testing stuff; they don't match.
Edited by Phil23 2017-06-01
GoodToGo!
Posted: 01:34am 31 May 2017
@Captain Boing,
I had two different pairs of Dumb RF modules here. The T/X module of one is appears kaput, and the R/X module of the other isn't much better. So I've only got one mixed pair that seem to work happily together. I might throw some more Aussie pesos at a few more seeing as they are so cheap. Thanks for the encryption link, interesting!
@ Grogster, the UUUUUUUUUU's I got from one of your earlier posts. It works a treat. I tried between 10 and 15 before settling on 15 as effective. Expect me to pester you if I have trouble with the HC-12's.....
@Phil, I like that checksum routine you posted, more neater and simpler solution to the crap one I came with, albeit along similar lines....
@drkl the modules are similar to this one
Cheers!
GTG!
Posted: 05:14am 31 May 2017
Pester all you like.
Happy to help if I can.
