Local Time 07:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : E100 Console to CON8
Phil23
Posted: 10:04pm 21 May 2017
Just wondering if I can wire the console output to Con8 on the E100?
More specifically, but basically paralleling it with Com3?
Could use Click 1 (Con4) to connect Pin 25 to 87 & Pin 26 to 89.
Would it work as long as I didn't open Com3 or assign pins 25 & 26?
Or any of the other click board pins for that matter.
Just got an ESP8266 & a HC-12 on the proto board connected to Con8 via a flat ribbon, but also need the console there, which is 2 loose wires.
Phil.
Posted: 12:48am 22 May 2017
Yes, it would work.
