Local Time 07:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Check if file is already open?
bobo2
Posted: 12:12pm 20 May 2017
What is the optimal way to check if file is already open?
I am logging data on the SD card, and have an open statement in the beginning of the logging function.
I need to check if the file is already open, otherwise I am getting an error when trying to open it again. What is the best way to check if file is already open?
Edit: I am using duinomite with MMBasic 4.5 Edited by bobo2 2017-05-21
Posted: 01:44pm 20 May 2017
Use OPTION ERROR CONTINUE then (after you tried opening the file) check MM.ERRNO.
bobo2
Posted: 11:32pm 22 May 2017
Thanks Geoff,
I tried that but the program still stops at the open statement.
I get the following error:
[283] Open logName$ For append As #6 Error: File number is already open
I had to make this work and work around it with a variable for the file name and one for holding status if the file is open.
Here is the relevant code (it is not pretty, but it seems to work)...
Sub LogValues
Local j
local logNewName$
local ds$
ds$ = date$
logNewName$ = right$(ds$,4)+mid$(ds$,4,2)+left$(ds$,2)+".log"
If (logNewName$ <> logFileName$) or isLogFileOpen = 0 then
' handle loggs that cross a day boundary
if isLogFileOpen = 1 Then
close #6
isLogFileOpen = 0
endif
logFileName$ = logNewName$
open logFileName$ for append as #6
if mm.errno = 0 then
isLogFileOpen = 1
Print #6,"OPENED_";DATE$;" ";TIME$
Else
isLogFileOpen = 0
endif
endif
print #6,date$","time$;
Print #6,","Format$(packV,"%4.1f");
Print #6,","Format$(modVHigh,"%3.1f");
Print #6,","Format$(modVAvg, "%3.1f");
Print #6,","Format$(modVLow, "%3.1f");
For j = 1 To 24
Print #6,","Format$(modData(j), "%3.1f");
Next j
For j = 1 To 4
Print #6,","Format$(tempData(j), "%2.0f");
Next j
print #6,","format$(PIN(21), "%4.3f");
' new line
print #6,""
End Sub
I am using an RTC module so the DATE$ and TIME$ are correct and useful for name of the log file.
Any advice to make the OPTION ERROR CONTINUE work would be highly appreciated!
Posted: 02:04am 23 May 2017
Did you check the performance when you open and close the file each time you need to log something. If it is fast enough that would be the easiest way.
[code]
Sub LogValues
ds$ = date$
LogFilename$ = right$(ds$,4)+mid$(ds$,4,2)+left$(ds$,2)+".log"
'rest of the data to be logged
close #6
End Sub
[/code]
Posted: 03:57am 23 May 2017
Yes, I had to use a flag for when the file handle is open, because I was getting exactly the same 'File is already open' error as you. Set the flag when the file is open, clear it when the handle is closed. Then have a do/loop that will WAIT till the flag is clear BEFORE you try to open the file again. This was suggested by other members here at the time, and it works a treat.
bobo2
Posted: 12:13am 24 May 2017
  MicroBlocks said   Did you check the performance when you open and close the file each time you need to log something. If it is fast enough that would be the easiest way.
[code]
Sub LogValues
ds$ = date$
close #6
End Sub
[/code]
I am logging every 1 second and after reading here and on other forums I am trying to avoid writing to the allocation table every second. From what I have read this is happening every time the file is closed.
This is on an electric vehicle, and a charge can take from 2 to 8 hours.
bobo2
Posted: 12:15am 24 May 2017
  Grogster said   Yes, I had to use a flag for when the file handle is open, because I was getting exactly the same 'File is already open' error as you. Set the flag when the file is open, clear it when the handle is closed. Then have a do/loop that will WAIT till the flag is clear BEFORE you try to open the file again. This was suggested by other members here at the time, and it works a treat.
Thanks for confirming this - it tried everything and thought that I was loosing it... but then snapped out of it and wrote the code above. It is not very elegant but seems to work.
