Local Time 07:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pi-cromite
jman
Posted: 10:47pm 08 May 2017
Hi
Now that we have MMBasic on the Pi I was wondering if one the Linux gurus could assist?
I have a some data acquired via the serial port that MMBasic can handle and creates a file with the desired content. I would like to overlay this files contents on static image using the Pi's standard video interface (composite in my case). The file will change every few minutes so I assume the static image will need to be refreshed and the file contents redisplayed.
I have seen FIM but the text overlay is to rigid and you cannot place the text were you want. (And the text bit looks real ugly) FIM
So in a nutshell does anybody know how to do this or at least point me in the correct direction.
Many thanks
Jman
atmega8
Posted: 06:46am 09 May 2017
rddtools?
jman
Posted: 09:18am 09 May 2017
Thanks for the reply could you post a link to rddtools I used DR Google but the results were not promising
Jman
atmega8
Posted: 10:16am 09 May 2017
Is your google broken ?
Rddtool link
and
MRTG
visualization for every kind of dataEdited by atmega8 2017-05-10
