Local Time 07:11 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : XModem file transfers.
Phil23
Posted: 10:25am 08 May 2017
  Phil23 said  Regarding downloading files from SD cards....
  TassyJim said   The XMODEM commands on the uM+ don't currently support transferring files, only the program in memory.
So, only the eXtreme at this time.
So just further to this Jim, I can do this:-
Load this code to the MM+
  Quote   OPEN "testlog.txt" FOR RANDOM AS #1
FOR i = 1 To LOF(#1)
SEEK #1, i
PRINT INPUT$(1, #1);
NEXT i
CLOSE #1
Start a Capture file in the MMedit terminal.
Run the code above.
Stop the Capture file.
[/quote]
Still looking for a solution to this & wondering if anyone has ever wrote a BASIC routine for XModem Sending.
Either MMbasic or any Basic would do.
Thinking is I could have a Function or Sub that performed an XModem transfer, tha could address the issue.
Have searched about here, but not seeing the right results this far.
Phil.
Phil23
Posted: 11:04am 08 May 2017
Just found this 30 year old code example for QBasic.
Seems it supports:-
Both Send and Receive functions.
Supports AT Command set controls for RS-232/PTSN Modems.
3 Modes, Checksum, CRC & XModem 1k.
BPS Transfer Rate Calculation.
300 code lines with comments stripped.
Don't need most of it's functions:-
Receive Mode - Not really.
Modem Support - Not at all.
3 different modes (but advice on which is most appropriate).
Transfer rate calculations - Not needed.
Does this look like the appropriate starting point for something to simply retrieve files from the SD card via an XModem transfer in Teraterm?
Feedback & advice appreciated before I make an attempt.
Phil.
[Code]
'call xmodem:end 'test mode
sub XMODEM static
'* EBBS-PC xmodem module copyright 1987 by Ed Parry - started 871107 *
' Handles xmodem checksum & xmodem/crc-ccitt
' Read "XMODEM.DAT" file for passed/shared variables
' Read : port, baud$, name$, start.time!, filename$, mode$, xm, local.mode
' Defs :
' port = active rs232 port
' baud$ = baud rate IE:0300, 1200, 2400, etc.
' name$ = User's name (Currently not in use)
' start.time! = Value of TIMER when user 1st logged on
' filename$ = Name of file to transfer
' mode$ = send or receive mode
' xm = xmodem protocol indicator (1 - 3) - Checksum, CRC, 1k
' local.mode = local or remote - if remote then dropped carrier aborts
' Send "XMODEM.DAT" file for passed/shared vars
' Send : abort, time.on, xfer.time
' Defs:
' abort = abort status - either true (-1) or false (0)
' time.on = time.of actual transfer
' xfer.time = Actual effective xfer time (So EBBS can calc BPS Rate)
' Pass abort status (true/false), time.on, effective xfer rate (BPS & %)
'* INITIALIZE ALL SYSTEM VARIABLES - MISC EBBS SETUP *
'INIT.VARS:' Set-up and init
defint a-z
up$="871126":au$="Ed Parry":ve$="v1.0"
locate 15,1
dim xm$(2),crctb(256):r$=chr$(13):rl$=r$+chr$(10)
s$=space$(1):q$=chr$(34):true=-1:false=0
offset=0:start.time!=timer:cdm=128:abort=false
null$=chr$(0):soh$=chr$(1):eot$=chr$(4)
ack$=chr$(6):nak$=chr$(21):can$=chr$(24):pad$=chr$(26)
xm$(1)="Xmodem":xm$(2)="Xmodem/CRC":bs=128:crc$=null$+null$
test.mode=false 'set to true for local testing and mods
'LOAD.CONFIG.VARIABLES: ' Load variables here!
if test.mode then ' Define for desired settings
port=2:baud$="1200":name$="System Operater"
filename$="c:\ebbs\NEWUSERS.MSG"
mode$="send":xm=2
local.mode=true
goto SETUP.CFG.VARS
end if
open "XMODEM.INP" for input as # 2
if oops=53 then close #2:print"XMODEM.DAT file not found":_
abort=true:goto EXIT.MODULE
input#2,port,baud$,name$,start.time!,filename$,mode$,xm,local.mode
close # 2
SETUP.CFG.VARS:
if port=1 then msr=&h3fe:mcr=&h3fc:lsr=&h3fd
if port=2 then msr=&h2fe:mcr=&h2fc:lsr=&h2fd
if xm=1 then chking$="CHECKSUM ":xoffset=4:_
else chking$="CRC/CCITT":xoffset=5
if mode$="send" then send=true:recv=false:else recv=true:send=false
'READ.CRC.TABLE:
for i=0 to 255:read crctb(i):next:restore
data 0,4129,8258,12387,16516,20645,24774,28903
data -32504,-28375,-24246,-20117,-15988,-11859,-7730,-3601
data 4657,528,12915,8786,21173,17044,29431,25302
data -27847,-31976,-19589,-23718,-11331,-15460,-3073,-7202
data 9314,13379,1056,5121,25830,29895,17572,21637
data -23190,-19125,-31448,-27383,-6674,-2609,-14932,-10867
data 13907,9842,5649,1584,30423,26358,22165,18100
data -18597,-22662,-26855,-30920,-2081,-6146,-10339,-14404
data 18628,22757,26758,30887,2112,6241,10242,14371
data -13876,-9747,-5746,-1617,-30392,-26263,-22262,-18133
data 23285,19156,31415,27286,6769,2640,14899,10770
data -9219,-13348,-1089,-5218,-25735,-29864,-17605,-21734
data 27814,31879,19684,23749,11298,15363,3168,7233
data -4690,-625,-12820,-8755,-21206,-17141,-29336,-25271
data 32407,28342,24277,20212,15891,11826,7761,3696
data -97,-4162,-8227,-12292,-16613,-20678,-24743,-28808
data -28280,-32343,-20022,-24085,-12020,-16083,-3762,-7825
data 4224,161,12482,8419,20484,16421,28742,24679
data -31815,-27752,-23557,-19494,-15555,-11492,-7297,-3234
data 689,4752,8947,13010,16949,21012,25207,29270
data -18966,-23093,-27224,-31351,-2706,-6833,-10964,-15091
data 13538,9411,5280,1153,29798,25671,21540,17413
data -22565,-18438,-30823,-26696,-6305,-2178,-14563,-10436
data 9939,14066,1681,5808,26199,30326,17941,22068
data -9908,-13971,-1778,-5841,-26168,-30231,-18038,-22101
data 22596,18533,30726,26663,6336,2273,14466,10403
data -13443,-9380,-5313,-1250,-29703,-25640,-21573,-17510
data 19061,23124,27191,31254,2801,6864,10931,14994
data -722,-4849,-8852,-12979,-16982,-21109,-25112,-29239
data 31782,27655,23652,19525,15522,11395,7392,3265
data -4321,-194,-12451,-8324,-20581,-16454,-28711,-24584
data 28183,32310,20053,24180,11923,16050,3793,7920
'* Reset modem and goto xfer file *
'INIT.MODEM:
close:out mcr,inp(mcr) or 1 'force modem to keep DTR high
open "com"+mid$(str$(port),2)+":"+baud$+",n,8,1,DS0,CS0" as # 1
if not test.mode or (inp(msr) and cdm) then goto IM1
print "Press ENTER":while inkey$ <> r$:wend
print#1,"AT E0 Q1 M0 A":call SLEEP(7.0)
IM1: gosub CLEAR.BUFS
if send then goto SEND.FILE
if recv then goto RECV.FILE
'* Xmodem Module Sub-Routines (Alphabetized) *
CHECK.ABORT:' Check for a CAN$ (aborted xfer)
if a$=can$ then status$="Remote abort"
if b$=can$ then status$="Local abort"
if a$ = can$ or b$ = can$ then abort=true
return
CHECK.CARRIER:' Keep an eye on the carrier
carrier = true
if local.mode or (inp(msr) and cdm) then return
if (inp(msr) and cdm) <> cdm then call SLEEP(.5)
if (inp(msr) and cdm) <> cdm then carrier=false
return
CLEAR.BUFS:' Clear keyboard and RS232 input buffers
call SLEEP(.1):while not eof(1):a$=input$(loc(1),1):wend
while inkey$ > "":a$=inkey$:wend
return
CONVERT.TIMER:' Use timer to maintain and calc online time
if start.time! > timer then offset! = 86400 - start.time!:_
start.time! = 0
time.on = (timer - start.time!) + offset!
return
CALC.CRC:' Calculates CRC for xfer recv block
crc$=null$+null$:for p=1 to bs
crc$=mki$(crctb(asc(left$(crc$,1)) xor_
asc(mid$(dat$,p,1))) xor cvi(null$+right$(crc$,1)))
crc$=right$(crc$,1)+left$(crc$,1):next
return
CALC.RECV.CRC:' Calculates CRC for xfer send block
if len(block$) < 4 or len(block$) > bs+3 then return
asc(right$(block$,1))) xor cvi(null$+right$(crc$,1)))
return
GET.BYTE:' Checks keyboard AND modem for a byte
a$="":if not eof(1) then a$=input$(1,1)
b$=inkey$:return
READ.BLOCK:' Read in a block from disk - send file
get#2:if loc(2) < filesize! then return
block$=left$(bloc$,lof(2) mod bs)
bloc$=block$+string$(bs - len(block$),pad$)
done=true
return
RECV.BLOCK:' Reads in a modem block - recv file
while not eof(1) and loc(1) > 0
block$=block$+input$(1,1):gosub CALC.RECV.CRC:wend
if len(block$) >= bs+xoffset then return
gosub CHECK.CARRIER:if not carrier then_
status$="Lost Carrier":goto ABORTED.XFER
call SLEEP(.1):if not eof(1) then goto RECV.BLOCK
return
SEND.NAK:' Sends init nak
if nak = 6 then xm=1 ' drop to checksum
if xm = 1 then print#1,nak$; ' init checksum
if xm = 2 then print#1,"C";:nak=nak+1 ' init CRC
return
TIMEOUT:' Check carrier & timeouts during xfer
gosub CONVERT.TIMER:tim.out=false:er=false
if val(sec$) <> time.on mod 60 then
gosub UPDATE.TIME.ON:gosub CHECK.CARRIER:gosub XMIT.DATA
if not carrier then status$="Lost carrier":abort=true
end if
if time.on > it+9 then
er$="Timeout":er=true:bad.blocks=bad.blocks+1:timeout=timeout+1
gosub XMIT.DATA:tim.out=true
if timeout = 10 then status$="Timeout abort":abort=true
gosub CONVERT.TIMER:it=time.on
end if
return
UPDATE.TIME.ON:' Prints elapsed time
row=csrlin:col=pos(0):view print 1 to 2
gosub CONVERT.TIMER:locate 1,72:min$=mid$(str$(int(time.on/60)),2)
sec$=mid$(str$(time.on mod 60),2):if len(sec$) = 1 then sec$="0"+sec$
print min$":"sec$:view print 3 to 24
locate row,col
return
XMIT.DATA:' Update xfer info
print "Error Checking : "chking$
if len(crc$)=1 then crc$=null$+crc$
print "CRC/Checksum : "hex$(cvi(right$(crc$,1)+left$(crc$,1)))s$s$s$
if send then sr$="Sent :":else sr$="Received :"
print "Bytes "sr$;bytes!
print "Good Blocks :"block-1
print "Errors :"bad.blocks
if er then er$=er$+" in block"+str$(block)
print "Last Error : "er$;;space$(78-pos(0)):er=false
print "Status : "status$;space$(78-pos(0))
gosub CONVERT.TIMER:et=time.on-start.xfer
min=int(et/60):sec=et mod 60
if min <> 1 then m$="mins":else m$="min"
if sec <> 1 then se$="secs":else se$="sec"
print "Elapsed Time :"min;m$;sec;se$;space$(5)
locate 16,1
return
XMIT.WAIT:' Waits til xmit buffer is clear
while inp(lsr)=0:wend
return
'* Xmodem Send Routine *
SEND.FILE:' 1st set-up
oops=0:open filename$ for random access read as # 2 len=bs
if oops=53 then goto ABORTED.XFER
field #2,bs as bloc$:last.block=false
total.blocks=int(lof(2)/bs)+1
filesize!=(lof(2)/bs):counter!=1
print:block=1:bytes!=0:bad.blocks=0
er$="None":done=false:status$="Waiting for initial handshake"
gosub XMIT.DATA:b$="":gosub CONVERT.TIMER
timeout=0:it=time.on:start.xfer=time.on
SEND1: gosub GET.BYTE ' check for init nak or "C"
if a$=nak$ then chking$="CHECKSUM ":_
xm=1:goto SEND5 ' CHKSUM init
if a$="C" then chking$="CRC/CCITT":_
xm=2:goto SEND5 ' CRC init
gosub CHECK.ABORT:if abort then goto ABORTED.XFER
gosub TIMEOUT:if abort then goto ABORTED.XFER
goto SEND1
SEND5: gosub XMIT.DATA:gosub CONVERT.TIMER
start.xfer=time.on:er=false:gosub READ.BLOCK:dat$=bloc$
gosub CALC.CRC
SEND2: gosub CLEAR.BUFS:status$="Sending block"
x2$=chr$(block and 255):x3$=chr$(255 - (255 and block))
if xm=1 then 'checksum
chksum=0:for i=1 to bs:chksum=chksum+asc(mid$(block$,i,1))
next:chksum=chksum and 255:block1$=soh$+x2$+x3$+bloc$+chr$(chksum)
crc$=chr$(chksum)
goto SEND3
end if
' CRC
block1$=soh$+x2$+x3$+bloc$+crc$
SEND3: gosub XMIT.DATA:print#1,block1$;
if done then last.block=true:goto SEND4
if a$ <> nak$ then gosub READ.BLOCK:dat$=bloc$:gosub CALC.CRC
gosub CONVERT.TIMER:it=time.on:timeout=0
SEND4: gosub GET.BYTE
if a$=nak$ then status$="Resending block":_
bad.blocks=bad.blocks+1:er=true:er$="NAK":goto SEND3
if a$=ack$ then
block=block+1:bytes!=bytes!+bs:er=false:status$="Received ACK"
gosub XMIT.DATA:if last.block then goto SENEX
goto SEND2
end if
goto SEND4
SENEX: print#1,eot$;:gosub CONVERT.TIMER:it=time.on:timeout=0
SENX1: status$="Sending EOT":gosub XMIT.DATA
gosub GET.BYTE
if a$=ack$ then abort=false:status$="Transfer Complete":_
goto EXIT.MODULE
if a$=nak$ then print#1,eot$;:goto SENX1
goto SENX1
'* Xmodem Receive Routine *
RECV.FILE:' Set-up and init vars
oops=0:open filename$ for output as # 2
er$="none":done=false:status$="Sending initial handshake"
timeout=0:it=time.on:start.xfer=time.on:seq.err=0:nak=0
gosub CLEAR.BUFS:gosub SEND.NAK:in.row=0
RECV1: gosub GET.BYTE:if a$=soh$ then_
block$=a$:start.xfer=time.on:goto RECV5
if tim.out then gosub SEND.NAK
goto RECV1
RECV5: gosub CONVERT.TIMER:it=time.on:timeout=0
RECTO: gosub XMIT.DATA
if not eof(1) and b$="" then status$="Receiving block":_
gosub XMIT.DATA:crc$=null$+null$:gosub RECV.BLOCK:er=false
b$=inkey$:if b$ = can$ then status$="Local abort":goto ABORTED.XFER
x1$=left$(block$,1):x2$=mid$(block$,2,1):x3$=mid$(block$,3,1)
if x1$ = can$ then status$="Remote abort":goto ABORTED.XFER
if x1$ = eot$ then status$="Received EOT":goto RECV3
if (x1$ <> soh$) then er=true:er$="Incorrect SOH":goto RCER
if x2$=null$ and x3$=chr$(255) then if block=1 then_
status$="Sending 0 block ACK":print#1,ack$;:block$="":goto RECV5
if x2$ <> chr$(block and 255) then er=true:_
er$="Block out of sequence":goto RCER
if x3$ <> chr$(255 - (255 and block)) then_
er=true:er$="Compliment out of sequence":goto RCER
if x2$ = chr$((block-1) and 255) then_
er=true:er$="Duplicate block":goto RCER
dat$=mid$(block$,4,bs)
rcrc$=mid$(block$,132,2):if xm=1 then chk$=right$(block$,1)
if len(block$) < bs+xoffset then er=true:er$="Short Block"
if len(block$) > bs+xoffset then er=true:er$="Long Block"
RCER: if not er and xm=1 then
chksum=0:for i=1 to bs:chksum=chksum+asc(mid$(dat$,i,1))
next:chksum=chksum and 255:crc$=chr$(chksum)
if chk$ <> chr$(chksum) then er=true:er$="Bad checksum"
end if
if not er and xm=2 then_
if rcrc$ <> crc$ then er=true:er$="Bad CRC checksum"
if er then
bad.blocks=bad.blocks+1:in.row=in.row+1
if in.row = 10 then er$="10 consecutive errors":_
status$="Aborting transfer":goto ABORTED.XFER
status$="Sending NAK for block"+str$(block)
gosub XMIT.DATA:gosub CLEAR.BUFS:print#1,nak$;
end if
block=block+1:print#2,dat$;:bytes!=bytes!+bs:in.row=0:block$=""
status$="Sending ACK":gosub CLEAR.BUFS:print#1,ack$;
goto RECV5
RECV3: print#1,ack$;:gosub XMIT.DATA:status$="Transfer complete"
abort=false:goto EXIT.MODULE
'* Wrap it up and exit! *
ABORTED.XFER:
close #2:gosub CLEAR.BUFS:abort=true
print#1,string$(2,can$); ' send 2 CAN$(celled)
EXIT.MODULE:' Clean up and return to EBBS
gosub CONVERT.TIMER:xfer.time=time.on-start.xfer
gosub CLEAR.BUFS:gosub XMIT.DATA:close #2
open "XMODEM.OUT" for output as #2
print#2,abort;rl$;xfer.time:locate 23,1:close #2
close #1:out mcr,inp(mcr) or 1 'force modem to keep DTR high
end sub
[/code]
Posted: 11:20am 08 May 2017
If you do a Google search for "XMODEM Protocol Overview" you will get a description from the person who wrote the protocol back in 1982
If you forget the CRC mode and the 1k mode things get easier to do.
Phil23
Posted: 11:46am 08 May 2017
  TassyJim said   If you do a Google search for "XMODEM Protocol Overview" you will get a description from the person who wrote the protocol back in 1982
Thanks Jim,
I'm treading water that's on my depth limit, but searching a lot.
So MMedit? You are using the Checksum method?
Definitely don't need the others. One will do.
Another alternative would be if some of the C Guru's on here could look into the possibility of compiling a Custom C-Function to address the task.
Can @matherp or any of the others talented in the C programming comment on the feasibility of using something like this C source example to provide MM Plus users with a basic ability to download files from their SD cards.
Phil.
Edit,
I don't really understand that code, but presume there's more to it, Ie this stuff...
[Code]+#include <stdio.h>
+#include <stdlib.h>
Etc.[/code]
Edited by Phil23 2017-05-09
Posted: 09:33pm 08 May 2017
Phil,
I have made a start for you but my hot water cistern just filled the house with smoke so it might take me a while to get the smoke back in.
This bit of code extracts the file 128 bytes at a time and adds the headers and checksum ready to send
It still needs code to wait for the start request and handle NAC and ACK etc.
For now, it prints everything without waiting.
  Quote   OPTION EXPLICIT
DIM myfile$="fm2.bas"
DIM soh$ = CHR$(1)
DIM er
er = sendXM(myfile$)
IF er = 0 THEN
PRINT "sent OK"
ELSE
PRINT "ERROR!!!"
ENDIF
END
FUNCTION sendXM(filename$)
LOCAL n, r, lineofdata$
IF areweready() = 1 THEN
OPEN filename$ FOR INPUT AS #2
DO WHILE EOF(#2) = 0
n = (n +
1) AND &hFF
lineofdata$=
INPUT$(128,#2)
IF LEN(lineofdata$)<128 THEN
lineofdata$ = lineofdata$ +
STRING$(128-LEN(lineofdata$),CHR$(0))
ENDIF
' soh$+" "+STR$(n,3)+" "+STR$(n XOR &hFF,3)+ " "+STR$(chksum(lineofdata$),3)+" "+lineofdata$
r = sendXMline(soh$+CHR$(n)+CHR$(n XOR &hFF)+lineofdata$+CHR$(chksum(lineofdata$)))
IF r <> 0 THEN EXIT DO
LOOP
CLOSE #2
sendXM = r
ELSE
sendXM = -
1 ' failed to start
ENDIF
END FUNCTION
FUNCTION chksum(txt$)
LOCAL n, ch$
chksum =
0
FOR n = 1 TO LEN(txt$)
ch$=
MID$(txt$,n,1)
chksum=chksum
XOR ASC(ch$)
NEXT n
END FUNCTION
FUNCTION sendXMline(txt$)
' we need to communicate with the receiving end and respond to ACK/NAK etc
PRINT txt$
sendXMline =
0 ' return error code for this line
END FUNCTION
FUNCTION areweready()
' wait for the start request - timeout needed
areweready = 1
END FUNCTION
That's as far as I will get for now.
Phil23
Posted: 07:10pm 14 May 2017
Thanks Jim,
Trying to understand it.
Have it on an E64 with a 200 line log file saved on the SD card.
When I run it, the data is written to the console, (as expected).
At this point in time, before anything is sent, I presume the Micromite code should be waiting for a command/string from Tera Term to say "Send me something", as indicated by the areweready function?
Phil.
Posted: 07:45pm 14 May 2017
-------- 5. DATA FLOW EXAMPLE INCLUDING ERROR RECOVERY
Here is a sample of the data flow, sending a 3-block message.
It includes the two most common line hits - a garbaged block,
and an <ack> reply getting garbaged. <xx> represents the
checksum byte.
SENDER RECIEVER
Times out after 10 seconds,
<--- <nak>
<soh> 01 FE -data- <xx> --->
<--- <ack>
<soh> 02 FD -data- <xx> ---> (data gets line hit)
<--- <nak>
<--- <ack>
<soh> 03 FC -data- <xx> --->
(ack gets garbaged) <--- <ack>
<--- <ack>
<eot> --->
<--- <ack>
The areweready() function waits for a <NAK> then it sends the first 128 bytes.
If the receiver sends an <ACK>, the next packet is sent.
If the receiver sends a <NAK>, the same packet is sent again.
After the last packet <EOT> is sent.
To abort either end can send three or more <CAN>s
I'm in holiday mode now (going to see what rotten herring tastes like) so I won't have anything to play with for a month or so.
Rather than full XMODEM, you could send your data a line at a time with the checksum added. chksum() works for any length data.
The receiving end does a chksum() to each line and compares.
Phil23
Posted: 08:05pm 14 May 2017
Thanks Jim,
I might give the line at a time idea a go; bit out of my depth with the XMODEM, but can probably do a line by line for the moment & just capture the text.
Spent the last 1/2 hour trying to setup a timeout & receive the NAK (Chr$(21), correct), but not getting it right.
Dunno about the Herring???, but I've got some great New Zealand Oysters here.
Enjoy your time away.
Phil.
Phil23
Posted: 11:54am 16 May 2017
Just wrote this, which should be workable with the code Jim wrote.
It's only reading lines for testing purposes, but still...
Wait's indefinitely for a NAK at this stage...
When it sets Resp$ to an ACK to get the first block sent.
Then waits for an ACK or NAK, then either sends the next block, or resends the current one.
It will need to handle other things like Cancel, to many retries, timeout etc.
Any additional help would be appreciated, & I think a few others might fine it useful for retrieving files from SD cards via Tera Term.
  Quote   Dim ACK$="a", NAK$="n"
Print "Waiting for a NAK to Start (n)"
do
Resp$=
Inkey$
if Resp$=NAK$ Then Exit do
Loop
Print "Starting"
OPEN "templog.txt" FOR Input AS #1
Resp$=ACK$
'Waits for eithe an "a" or "n" to simulate ACK of NAK
do
if Resp$=ACK$ Then
Blk%=Blk%+
1
Line Input #1,LineRead$
if LineRead$="" Then Exit do
LineSend$=
"Block_" + Str$(Blk%,3,0,"0") + " " + LineRead$
Print LineSend$
Else if Resp$=NAK$ Then
Print LineSend$
End if
Resp$=
Inkey$
Loop
Close #1
Print "Finished"
On a tangent, a colleague has pointed me towards some of Someone else's Micromite xModem C Code source.
Can this be easily implemented into a custom cFunction which would provide an xmodem send capability for the MM+.
I'd presume the main thing you would need to pass to it would be the file name to be sent & the function would handle the rest & wait for the receiver to interact.
Can anyone with C talents comment on the feasibility?
Phil.
Edited by Phil23 2017-05-17
Posted: 02:33pm 16 May 2017
I am currently working on V5.4 which has the ability to save a file to the SD card within a program. I don't have a finish date yet but it will not be long (weeks rather than months).
Posted: 08:15pm 19 May 2017
Phil,
while you wait for V5.4,
you might like to try this
  Quote   option explicit
dim myfile$="fm2.bas"
dim soh$=CHR$(1),stx$=CHR$(2),eot$=CHR$(4),ack$=CHR$(18),nak$=CHR$(21),can$=CHR$(24)
dim er, g$
dim log$
input g$
g$ =
ucase$(g$)
if g$ = "XM" then
if er = 0 then
print "sent OK"
else
print "ERROR!!! "+str$(er)
endif
endif
END
r = areweready()
sendXM = r
if r = 0 then
OPEN filename$ FOR input AS #2
n = (n +
1) AND &hFF
lineofdata$=
INPUT$(128,#2)
if LEN(lineofdata$)<128 then
endif
log$= log$+
str$(r)
if r <> 0 then exit DO
LOOP
CLOSE #2
if r = 8 then
sendXM = r
else
sendXM = r
' 1 = failed to start
endif
endif
END FUNCTION
LOCAL n, ch$
chksum =
0
ch$=
MID$(txt$,n,1)
chksum=chksum
XOR ASC(ch$)
NEXT n
END FUNCTION
LOCAL k$, n, starttime
sendXMline = 9
starttime =
timer
k$ =
INPUT$(255,#0) ' flush input buffer
print txt$
' k$ = input$(255,#0)
pause 100
DO
k$ =
INPUT$(1,#0)
if k$ = ack$ then
sendXMline =
0 ' received the ack
exit DO
endif
if k$ = nak$ then
k$ =
INPUT$(255,#0)' flush input buffer
print txt$
pause 100
endif
if k$ = can$ then
pause 100
k$ =
INPUT$(2,#0)
if k$ = can$+can$ then
sendXMline =
8 ' received 3 cancels
exit DO
endif
endif
if timer - starttime > 10000 then ' timeout waiting for ack
sendXMline = crashout()
endif
LOOP
END FUNCTION
LOCAL k$, starttime
areweready =
9
starttime = timer
DO
k$ =
INPUT$(1,#0)
if k$<>"" then print ASC(k$)
if k$ = nak$ then
print "NAK"
areweready =
0 ' received the start request
exit DO
endif
if timer - starttime > 20000 then ' timeout waiting for start
areweready = crashout()
print "timeout"
exit DO
endif
LOOP
END FUNCTION
FUNCTION alldone()
LOCAL k$, starttime
'terminate the transfer
alldone = 9
starttime =
timer
DO
k$ =
print eot$
pause 100
k$ =
INPUT$(1,#0)
if k$ = ack$ then
alldone =
0
exit DO
endif
alldone = 7
exit DO
endif
LOOP
END FUNCTION
FUNCTION crashout()
' terminate due to error
print can$+can$+can$
crashout =
6
END FUNCTION
I have added the flow control bits to the first code I presented.
I can't test it with teraterm for now but it seemed to work OK with some simulating I did.
There is a lot of timing to get right for smooth flow and testing over a local network is different to the real world.
Phil23
Posted: 11:36am 20 May 2017
Thanks Jim,
It's not initially working in Tera Term, Exiting with error 8.
It's a little hard to debug when you can't add debug lines to output to console.
All I tested with was a bare E64 hanging off the USB port, but will add HC-12 on Com1 a bit later so I can spit some debug print lines out to a separate instance of Teraterm. Have a USB HC-12 that useful for monitoring what's flying about amongst the little collection of other HC-12's
Or 2nd though, might grab an E100 & add a few lines to put the debug output on the LCD.
Phil.
Phil23
Posted: 12:12pm 20 May 2017
Teraterm Debug mode ?
Has anyone used it? Doesn't seem to work for me despite this in my ini file....
[code]; Display all characters (debug mode)
Debug=on
; Debug mode type which can be selected by user.
; on|all = All types
; off|none = Disabled debug mode
; normal = usual teraterm debug mode
; hex = hex output
; noout = disable output completely
DebugModes=all[/code]
Just seems to ignore "Shift+Esc".
