Local Time 07:00 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : verifying contents using pickit3
kkoppert
Posted: 07:45pm 05 May 2017
I keep burning the hexfile for MMBASIC 5.03.02 into a pic32mx170256B using a pickit3 and mpipe. I turn verify on and power the device from the tool. The result is
The following memory areas(s) will be verified:
program memory: start address = 0x0, end address = 0x3ffff
boot config memory
configuration memory
program memory
Address: 1d000400 Expected Value: ffffffff Received Value: ffff0000
Verify failed
2017-05-06 17:32:24 +1200 - Verify failed
Is this expected?
Posted: 07:48pm 05 May 2017
It happens with some configurations and is nothing to worry about.
Posted: 08:08pm 05 May 2017
This is correct - and the MicroMite will work correctly
My understanding is that things happen inside a MicroMite after the very first power-up after flashing. This effectively changes 'memory/flash contents' and therefore, the verification will fail as 'things are different'.
If you were to save the contents of the MicroMite as a hex file (i.e. after it has done its initial 'memory/flash' alteration) then load & verify this file then it will pass
WW
Posted: 08:10pm 05 May 2017
Hi Kk,
This is because when the PIC programming is finished RESEST is released and on first power up MMBasic changes a few memory locations (I am not sure what but it causes a verify fail)
To do a verify...
Click on settings
Select RELEASE from Reset
Select HOLD in RESET
Then program your chip, it should verify OK.
Even though the default is hold in reset it actually requires selecting release first then selecting hold again.
Kind Regards,
Phil23
Posted: 01:46am 07 May 2017
  bigmik said  To do a verify...
Click on settings
That info is really worth adding to numerous places of reference.
Had me bluffed in the early days as to why the error.
New ATT, Never used a Pickit3, or PIC's at all, so was a bit miffed by the error, but worked on when they proved themselves to be correctly programed.
