Local Time 06:48 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RTC temperature measurements
OA47
Posted: 05:58pm 01 May 2017
Can someone remind me how I can get the temp measurement from a DS3231. I remember doing it with a RTC GETREG but I cant find any references to it.
Thanks in advance
Graeme
BobD
Posted: 06:29pm 01 May 2017
Here is a bit of code from years back on the Maximite.
[code]
If RTCdata(17) < &h80 Then
Temperature = RTCdata(17) + (RTCdata(18) / 256)
Else
Temperature = -(((RTCdata(17) Xor &hFF) + 1) + (RTCdata(18) \ 256))
EndIf
t$=Format$(Temperature,"%+6.2f")
Print "Temperature is "; T$; " degrees Celsius"
[/code]
RTCData() is an array of the data from the DS3231 regs. So now you would use a Getreg to get the data. The temperature data is twos complement so needs some work to normalise it.
Edit: I can see a little bug in the code that escaped me all those years back. I used /256 and \256. I would suspect that \256 (integer divide) is required.
Edit again: There is a bit more to the code. I'm so rusty that I missed it. I've added the print formatting in the end of the code block. Someone may be able to help on how the print format worked. I think it is probably 6 digits to the left and 2 to the right of the point.Edited by BobD 2017-05-03
Posted: 07:56pm 01 May 2017
  Quote   RTC GETREG 17, rtc17
RTC GETREG 18, rtc18
IF v17 < &h80 THEN
Temperature = rtc17 + (rtc18 /
256)
ELSE
Temperature = -(((rtc17
XOR &hFF) + 1) + (rtc18 / 256))
ENDIF
PRINT temperature
Adapting Bobs code a bit
OA47
Posted: 08:26pm 01 May 2017
Thanks Jim, as you did, I managed to adapt Bobs code to work with RTC GETREG. Possibly a note to Geoffg to add this to the Micromite Manual.
Graeme
Posted: 08:43pm 01 May 2017
I had an error on line 4.
Only a problem if we get a frost tonight!
IF rtc17 < &h80 THEN
256)
ELSE
ENDIF
PRINT temperature
BobD
Posted: 09:41pm 01 May 2017
[quote] Only a problem if we get a frost tonight!
[/quote]
Ha ha, That may happen. It's cool.
OA47
Posted: 11:26am 02 May 2017
And it did!
-2.1 degrees this morning and a frost to boot.....
Graeme
Phil23
Posted: 11:38am 02 May 2017
  OA47 said   And it did!
Graeme
Hmmm,
I get 13.25°....
There's a DS18B20 clipped under the table it's on,
It's reading 11.94°
Another up at roof level, about 4m up, shielded by the eves,
It's showing 13.5°.
Phil
Posted: 01:29pm 02 May 2017
I didn't know the DS3231 had a built-in temperature sensor with output available (I knew it had one for temp compensation for the time). Ran this code and it read 24 a few centimeters away from a DS18B20 which read 25.
Thanks.
Lance
Posted: 09:11pm 02 May 2017
Ah the joys of the data sheet and lots of other goodies besides...
https://datasheets.maximintegrated.com/en/ds/DS3231.pdf page 11 (or &h0b if you prefer)
I use this to give me ambient temperature of enclosures (and in one to give me the cold junction temperature for a thermo-couple calculation) - its no good if you need a proper range but none of my test kit is in the cold
Edited by CaptainBoing 2017-05-04
