Local Time 01:28 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : UMite Escape codes for VT100
jeffj
Posted: 09:31pm 24 Apr 2017
Attached are some escape codes I have extracted from various posts for use on a VT100 screen.
I was running some of these to try and understand them
I was using MMedit and quite a few worked ok but all of the lines borders etc would not work.Then none of them worked and I cannot understand what has happened.
I tried them on Teraterm and some of them worked as they did on on MMedit.
I put the latest software into the micromite and ran the same programme on another computer also using MMedit same result.
I am not using a VT100 screen but using the computer screen.
These codes are most confusing . There must be some guides on Syntax somewhere.
Your help would be greatly appreciated
Jeff
x=10
y=20
'EXAMPLE OF ESCAPE CODES
Main:
LOCATE X,Y
print "here";
down_ONE_LINE
LARGE'DOES NOT WORK
print "here";
BORDER 'DOES NOT WORK
DRAW_A_LINE 'DOES NOT WORK
DRAW_CIRCLE 'DOES NOT WORK
pause 5000
Clear_screen'Clear screen and put cursor @ row3 col 6
end
Sub Clear_screen
x=0 ' used as a counter value that is displayed on the console window
Print Chr$(27)+"[2J"+Chr$(27)+"[3;6H"; ' Escape codes to clear screen & move cursor to Row 3; Column 6
Print Str$(x); ' Print value of counter at cursor location (set above)
x=x+1 ' inc counter
Pause 333 ' delay a bit
Loop ' and repeat . . .
endsub
Sub down_ONE_LINE
PRINT CHR$(27)+"[<1>B" ' 10= no lines
end sub
SUB DRAW_A_LINE
'PRINT CHR$(27)+"[+Z1;<0>;<0>;<10>;<20>Z"
END SUB
Sub DRAW_CIRCLE
PRINT CHR$(27)+ "[Z4;240;144;100;Z";
END SUB
'SUB Clear_screen
PRINT CHR$(27)+"[f" : PRINT CHR$(27)+"[2J";'J=clear screen from cursor down f=move cusor to upper left
END SUB
LOCATE X,Y
SUB LOCATE X,Y
PRINT CHR$(27)+"["+STR$(X)+";"+STR$(Y)+"f";
END SUB
COLOR f,b
SUB COLOR f,b
PRINT CHR$(27)+"[0;"+STR$(f)+";"+STR$(b)+";1m";
END SUB
Sub MENU (T$)
WIPE
Print Chr$(27)+"[6m"; 'Select Jumbo font
Print Chr$(27)+"[7m"; 'Select Inverse Video
Print Chr$(27)+"[4m"; 'Select Underline mode
Print T$ 'Print menu title
STANDARD 'Select standard text mode(turn all text attributes off)
Print NL$ 'Blank line for space
LARGE 'Select Large font
End Sub
Sub WIPE
Print Chr$(27)+"c"; 'Reset terminal
Print Chr$(27)+"[2J"; 'Clear entire screen
Print Chr$(27)+"[H"; 'Cursor to top-left
End Sub
Sub BORDER
Print Chr$(27)+"[Z2;5;5;10;20Z"; 'Draw border box
End Sub
Sub LARGE
Print Chr$(27)+"[3m"; 'Large font
End Sub
Sub STANDARD
Print Chr$(27)+"[0m"; 'Standard font
End Sub
Posted: 11:00pm 24 Apr 2017
MMEdit only uses a subset of the VT100 controls.
It is intended for basic use only.
You may get better success from TeraTerm or Putty.
jeffj
Posted: 08:19pm 15 May 2017
Thanks Jim sorry for delayed reply
Yr mmedit is the bees knees I really like it.
As regards the escape codes . the only ones I really wanted was to position the cursor and clear the screen.
What I find odd is that if I programme using mmedit then switch to teraterm they work ok.
For the benefit of others with this problem I found that if I select "VT" in the chat window they work ok . Maybe that is what I should have been doing all along
regards Jeff
Phil23
Posted: 08:49pm 15 May 2017
That's it.
The VT button puts it into VT-100 mode.
the A is ASCII mode which does not recognise the esc codes, but is good to se what's being spat out.
The other code I use a lot is clear to end of line;
It helps tidy thing up if the buffer over runs.
Phil.
