Local Time 00:41 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS18B20 and the CGCOLORMAX
jincamty
Posted: 02:29pm 15 Apr 2017
Hi Guys,
Long time lurker and revisiting an old display project using the CGCOLORMAX2
and a VGA lcd.
Can someone please give me a code example to use two or more DS18B20 sensors.
They can use separate pins.
I am getting confused with different commands.
I think I'm using ver 4.5 (but don't know how to find out)
DS18B20()
TEMPR
Is it a matter of connecting them to an analog input and doing some maths
or is there more to it?
Also is there somewhere where I can find really basic code examples as building
blocks?
I have googled my fingers off and can only find arduino related stuff.
Cheers Cameron Carter
Posted: 02:54pm 15 Apr 2017
PRINT MM.VER
will give you the version number
Being a CGCOLORMAX2 it is very likely V4.5
To read the DS18B20, page 10 of the V4.5 manual has examples.
You have to remember to refer to the manual for your version of MMBasic. There have been afew changes that will jump up and bite you if you try and use the wrong version of the commands. (The maximite will be unharmed by the experience)
Have you seen the MMBasic Library.
http://geoffg.net/Downloads/Maximite/MMBasic%20Library.zip
It has a lot of older programs that are suitable for the Maximites.
Posted: 06:53pm 15 Apr 2017
  jincamty said  Is it a matter of connecting them to an analog input and doing some maths
blocks?
Hi there.
Welcome aboard.
First, you need to decide if you want your 18B20 sensors to be powered externally or via parasitic power. External power is an external 3v3 power, parasitic power is when the 18B20 sensor bleeds off the power it needs to operate, from the I/O pin it is connected to.
Assuming either one(see standard manual, page 25), all you have to do, is issue the command - simple as that - no conversion to do or any maths at all. The figure returned will be the temperature in degrees Celsius.
So, for example:
PRINT "Temperature is: " TEMPR(3)
...will request the temperature from an 18B20 sensor connected to pin-3.
This takes about 200mS to return, but it should come back with a figure on the console, representing the temperature in 'C.
TEMPR START is a command used to start reading the temperature in the background, but this only currently works on ONE sensor at a time, so you can't TEMPR START another sensor, till the first one has been read.
Again, see page 25 of the current standard manual.
Good luck, and do post back if you have any problems.
Everyone here is friendly.
As to simple programming examples, I think that your best bet would be the Silicon Chip articles on programming the Micromite. They are written for the lamen/laywomen, and are a good starting point. These were published in Silicon Chip magazine in Febuary, March and April 2017 issues.
jincamty
Posted: 08:50pm 15 Apr 2017
Hi, Thanks Jim and Grogster.
I managed to get it working toady.
The version I had was ver 4.0. I managed to upgrade to Ver 4.5 but when I type
Print MM.Ver it shows 4.05. Is that correct?
The TEMPR( ) doesn't seem to exist in Ver 4.05
Print "Water " DS18B20(15) seems to work.
The sensors I am using are three wire sealed units (red,white,black)
I assumed Red=5v, Black=ground, White=out, (I/O pin 15)
Nothing happened until I connected a 4k7 resistor between +5v and out.(Pin 15).
Silicon chip magazine was what got me into this stuff, starting with the Picaxe chips.
Cheers Cam.
Posted: 09:20pm 15 Apr 2017
Yes indeed, SC and the PICAXE series of articles, was where it started with me too!
