Local Time 00:42 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ILI9163 SPI LCD driver for 28-pin?
Posted: 03:54am 12 Apr 2017
Hi there.
I can't remember if there was a driver ever written for this controller or not.
matherp?
EDIT: I know that the MM+ supports this controller natively, but can you get a loadable C-Function kind of driver to make this controller work on the 28-pin MM2 chip?Edited by Grogster 2017-04-13
Posted: 05:55am 12 Apr 2017
Yes this is supported on the 28-pin MM via a CFunction driver.
The driver is in the Micromite firmware download.
Look under: Embedded C Modules\ILI9163 LCD
Posted: 07:01am 12 Apr 2017
The current version of the driver only supports 128x128 resolution. Shouldn't be difficult to change to 160x128 but won't work properly "out of the box"
Posted: 12:36pm 12 Apr 2017
@ Geoff - thanks. Crikey. How did I miss seeing that?!(rhetorical!)
@ matherp: You've been reading my other posts. IF I decide to use a 160x128 touch LCD from BuyDisplay, would you be able to change the driver to support that resolution then? No need to do it now, as I am still unsure if I am going to do it that way or not.....
