Local Time 00:42 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - Mars closest approach
cdeagle
Posted: 12:24am 09 Apr 2017
This post is an MMBASIC computer program called ca2mars.bas that can be used to predict close approach conditions between the Earth and Mars. This application uses the inner planet ephemeris posted earlier and one-dimensional minimization to calculate close approach conditions.
Here's a typical user interaction with the program and the computed results for a 1200 day search starting January 1, 2016.
closest approach between the Earth and Mars
please input the calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 1,1,2016
please input the number of days to search
? 1200
searching for close approach conditions ...
time and conditions at Earth-Mars close approach
calendar date May 30 2016
UTC time 21 hours 32 minutes 59.01 seconds
UTC julian day 2457539.39790518
geocentric distance 0.5032055307 AU
75278475.8873 kilometers
calendar date July 31 2018
UTC time 7 hours 54 minutes 28.67 seconds
UTC julian day 2458330.82949848
geocentric distance 0.3849508807 AU
57587832.0516 kilometers
calendar date October 6 2020
UTC time 14 hours 20 minutes 47.82 seconds
UTC julian day 2459129.09777570
geocentric distance 0.4149076997 AU
62069308.4095 kilometers
Here's the MMBASIC source code.
' program ca2mars.bas April 9, 2017
' predict close approach between Earth and Mars
' MMBASIC eXtreme version
option default float
option base 1
const pi2 = 2.0 * pi, pidiv2 = 0.5 * pi, rtd = 180.0 / pi, dtr = pi / 180.0
' astronomical unit (kilometers)
const aunit = 149597870.691
dim jdleap(28), leapsec(28)
dim sl(50), sr(50), sa(50), sb(50), cl(184), al(184), bl(184)
dim jdtdbi, cmonth, cday, cyear, month$(12)
' read sun and planet data
read_data
' begin simulation
print " "
print "closest approach between the Earth and Mars"
print "==========================================="
' request initial calendar date (month, day, year)
getdate(cmonth, cday, cyear)
' initial utc julian day
julian(cmonth, cday, cyear, jdutc)
' compute initial tdb julian date
utc2tdb(jdutc, jdtdb)
jdtdbi = jdtdb
' request search duration (days)
print " "
print "please input the number of days to search"
input ndays
print " "
print "searching for close approach conditions ..."
print " "
' define search parameters
ti = 0.0
tf = ndays
tisaved = ti
dt = 10.0
dtsml = 0.1
' find closest approach conditions
ca_event(ti, tf, dt, dtsml)
end
sub ca_event (ti, tf, dt, dtsml)
' predict closest approach events
' input
' ti = initial simulation time
' tf = final simulation time
' dt = step size used for bounding minima
' dtsml = small step size used to determine whether
' the function is increasing or decreasing
LOCAL tolm
local fmin1, tmin1
LOCAL ftemp, df, dflft
local el, er
LOCAL t, ft
local iter1%, iter2%, iter3%
' initialization
tolm = 1.0e-10
df = 1.0
for iter1% = 1 to 1000
' find where function first starts decreasing
for iter2% = 1 to 1000
if (df <= 0.0) then
exit for
end if
t = t + dt
ca_func(t, ft)
ca_func(t- dtsml, ftemp)
df = ft - ftemp
next iter2%
' function decreasing - find where function
' first starts increasing
for iter3% = 1 to 1000
el = t
dflft = df
t = t + dt
ca_func(t, ft)
ca_func(t - dtsml, ftemp)
df = ft - ftemp
if (df > 0.0) then exit for
next iter3%
er = t
' calculate minimum using Brent's method
minima(el, er, tolm, tmin1, fmin1)
el = er
' print current conditions
ca_print(tmin1)
if (t >= tf) then exit for
next iter1%
end sub
sub ca_print(topt)
' print close approach conditions
LOCAL jdutc, jdtdb, rpg(3), rph(3), rasc, decl
print " "
print "time and conditions at Earth-Mars close approach"
print "================================================"
print " "
' TDB julian day
jdtdb = jdtdbi + topt
' compute and display UTC julian date
tdb2utc(jdtdb, jdutc)
jd2str(jdutc)
PRINT " "
print "UTC julian day ", str$(jdutc, 0, 8)
PRINT " "
ephem(4, jdtdb, rpg(), rph(), rasc, decl)
print "geocentric distance ", str$(vecmag(rpg()), 0, 10), " AU"
print " ", str$(aunit * vecmag(rpg()), 0, 4), " kilometers"
print " "
END sub
sub ca_func(x, fx)
' closest approach objective function subroutine
local jdtdb, rpg(3), rph(3), rasc, decl
' current tdb julian day
jdtdb = jdtdbi + x
' compute mars ephemeris
' objective function - scalar magnitude of Earth-to-Mars distance
fx = vecmag(rpg())
end sub
sub minima(a, b, tolm, xmin, fmin)
' one-dimensional minimization
' Brent's method
' input
' a = initial x search value
' b = final x search value
' tolm = convergence criterion
' output
' xmin = minimum x value
' note
' user-defined objective subroutine
' coded as ca_func(x, fx)
' remember: a maximum is simply a minimum
' with a negative attitude!
' machine epsilon
LOCAL epsm = 2.23e-16
' golden number
LOCAL c = 0.38196601125
LOCAL d, e
LOCAL t2, p, q
local r, u, fu
LOCAL x, xm, w
local v, fx, fw
LOCAL tol1, fv
x = a + c * (b - a)
w = x
v = w
e = 0.0
p = 0.0
q = 0.0
r = 0.0
ca_func(x, fx)
fw = fx
fv = fw
for iter% = 1 to 100
if (iter% > 50) then
print ("error in function minima!")
print ("(more than 50 iterations)")
end if
xm = 0.5 * (a + b)
tol1 = tolm * abs(x) + epsm
t2 = 2.0 * tol1
if (abs(x - xm) <= (t2 - 0.5 * (b - a))) then
xmin = x
fmin = fx
exit sub
end if
if (abs(e) > tol1) then
r = (x - w) * (fx - fv)
q = (x - v) * (fx - fw)
p = (x - v) * q - (x - w) * r
q = 2.0 * (q - r)
if (q > 0.0) then
p = -p
end if
q = abs(q)
r = e
e = d
end if
if ((abs(p) >= abs(0.5 * q * r)) or (p <= q * (a - x)) or (p >= q * (b - x))) then
if (x >= xm) then
e = a - x
else
e = b - x
end if
d = c * e
else
d = p / q
u = x + d
if ((u - a) < t2) or ((b - u) < t2) then
d = sgn(xm - x) * tol1
end if
end if
if (abs(d) >= tol1) then
u = x + d
else
u = x + sgn(d) * tol1
end if
ca_func(u, fu)
if (fu <= fx) then
if (u >= x) then
a = x
else
b = x
end if
v = w
fv = fw
w = x
fw = fx
x = u
fx = fu
else
if (u < x) then
a = u
else
b = u
end if
if ((fu <= fw) Or (w = x)) then
v = w
fv = fw
w = u
fw = fu
elseif ((fu <= fv) Or (v = x) Or (v = w)) then
v = u
fv = fu
end if
end if
next iter%
end sub
sub realroot(x1, x2, tol, xroot, froot)
' real root of a single non-linear function subroutine
' input
' x1 = lower bound of search interval
' x2 = upper bound of search interval
' tol = convergence criter%ia
' output
' xroot = real root of f(x) = 0
' froot = function value
' note: requires sub jdfunc
local eps, a, b, c, d, e, fa, fb, fcc, tol1
local xm, p, q, r, s, xmin, tmp
eps = 2.23e-16
e = 0.0
a = x1
b = x2
jdfunc(a, fa)
jdfunc(b, fb)
fcc = fb
for iter% = 1 to 50
if (fb * fcc > 0.0) then
c = a
fcc = fa
d = b - a
e = d
end if
if (abs(fcc) < abs(fb)) then
a = b
b = c
c = a
fa = fb
fb = fcc
fcc = fa
end if
tol1 = 2.0 * eps * abs(b) + 0.5 * tol
xm = 0.5 * (c - b)
if (abs(xm) <= tol1 or fb = 0) then exit for
if (abs(e) >= tol1 and abs(fa) > abs(fb)) then
s = fb / fa
if (a = c) then
p = 2.0 * xm * s
q = 1.0 - s
else
q = fa / fcc
r = fb / fcc
p = s * (2.0 * xm * q * (q - r) - (b - a) * (r - 1.0))
q = (q - 1.0) * (r - 1.0) * (s - 1.0)
end if
if (p > 0) then q = -q
p = abs(p)
xmin = abs(e * q)
tmp = 3.0 * xm * q - abs(tol1 * q)
if (xmin < tmp) then xmin = tmp
if (2.0 * p < xmin) then
e = d
d = p / q
else
d = xm
e = d
end if
else
d = xm
e = d
end if
a = b
fa = fb
if (abs(d) > tol1) then
b = b + d
else
b = b + sgn(xm) * tol1
end if
jdfunc(b, fb)
next iter%
froot = fb
xroot = b
end sub
sub ephem(ibody%, jdtdb, rpg(), rph(), rasc, decl)
' sun and inner planet ephemeris subroutine
' input
' ibody% = celestial body index
' jdtdb = tdb julian day
' output
' rpg() = geocentric position vector (au)
' rph() = heliocentric position vector (au)
' rasc = geocentric right ascension (radians)
' decl = geocentric declination (radians)
local rsun(3)
local dls, drs, gl, gb, pl, pb, pr, alon, alat
' compute coordinates of the sun
sun(jdtdb, dls, drs, rasun, decsun, rsun())
gl = dls
' compute coordinates of the planet
select case ibody%
case 1
' mercury(jdtdb, pl, pb, pr)
case 2
' venus(jdtdb, pl, pb, pr)
case 3
' sun/earth
for i% = 1 to 3
rph(i%) = -rsun(i%)
rpg(i%) = 0.0
next i%
rasc = rasun
decl = decsun
exit sub
case 4
mars(jdtdb, pl, pb, pr)
end select
' compute geocentric mean coordinates
latlong(dls, drs, pl, pb, pr, gl, gb, rpgm)
' apparent geocentric equatorial right ascension and declination
abernu(jdtdb, 4, gl, gb, alon, alat, rasc, decl)
' compute geocentric equatorial unit position vector of planet
rpg(1) = rpgm * cos(rasc) * cos(decl)
rpg(2) = rpgm * sin(rasc) * cos(decl)
rpg(3) = rpgm * sin(decl)
' compute geocentric equatorial position vector
for i% = 1 to 3
rph(i%) = rpg(i%) - rsun(i%)
next i%
end sub
sub latlong(sl, sr, pl, pb, pr, gl, gb, rpgm)
' geocentric mean coordinates subroutine
local xs, ys, xp, yp, zp, x, y, z
' heliocentric ecliptic position of the sun
xs = sr * cos(sl)
ys = sr * sin(sl)
' heliocentric ecliptic position of planet
xp = pr * cos(pb) * cos(pl)
yp = pr * cos(pb) * sin(pl)
zp = pr * sin(pb)
' geocentric ecliptic position of planet
x = xp + xs
y = yp + ys
z = zp
' mean geocentric longitude of planet (radians)
gl = atan3(y, x)
' mean geocentric latitude of planet (radians)
gb = atan2(z, sqr(x^2 + y^2))
' geocentric distance of planet
rpgm = sqr(x * x + y * y + z * z)
end sub
sub abernu(jdtdb, ibody%, gl, gb, alon, alat, rasc, decl)
' aberration and nutation corrections subroutine
local u, a1, a2, dpsi, deps, epsi
local xce, xse, xcl, xsl, xcb, xsb
' fundamental time argument
u = (jdtdb - 2451545.0) / 3652500.0
select case ibody%
case 1
' mercury
alon = gl + 0.0000001 * (-1261.0 + 1485.0 * cos(2.649 + 198048.273 * u))
alon = alon + 0.0000001 * (305.0 * cos(5.71 + 458927.03 * u) + 230.0 * cos(5.3 + 396096.55 * u))
alat = gb + 0.000019 * cos(0.42 + 260879.41 * u)
case 2
' venus
alon = gl + 0.0000001 * (-1304.0 + 1016.0 * cos(1.423 + 39302.097 * u))
alon = alon + 0.0000001 * (224.0 * cos(2.85 + 78604.19 * u) + 98.0 * cos(4.27 + 117906.29 * u))
alat = gb
case 3
' earth
alon = gl + 0.0000001 * (-993.0 + 17.0 * cos(3.1 + 62830.14 * u))
alat = 0.0
case 4
' mars
alon = gl + 0.0000001 * (-1052.0 + 877.0 * cos(1.834 + 29424.634 * u))
alon = alon + 0.0000001 * (187.0 * cos(3.67 + 58849.27 * u) + 84.0 * cos(3.49 + 33405.34 * u))
alat = gb
end select
' nutation corrections
a1 = 2.18 + u * (-3375.7 + u * 0.36)
a2 = 3.51 + u * (125666.39 + u * 0.1)
dpsi = 0.0000001 * (-834.0 * sin(a1) - 64.0 * sin(a2))
deps = 0.0000001 * u * (-226938.0 + u * (-75.0 + u * (96926.0 + u * (-2491.0 - u * 12104.0))))
epsi = 0.0000001 * (4090928.0 + 446.0 * cos(a1) + 28.0 * cos(a2)) + deps
alon = modulo(alon + dpsi)
' compute right ascension and declination (radians)
xce = cos(epsi)
xse = sin(epsi)
xcl = cos(alon)
xsl = sin(alon)
xcb = cos(alat)
xsb = sin(alat)
decl = asin(xce * xsb + xse * xcb * xsl)
rasc = atan3(-xse * xsb + xce * xcb * xsl, xcb * xcl)
end sub
sub mars(jdtdb, pl, pb, pr)
' computation of the heliocentric coordinates of mars
local u, h1, h2, h3, w1, w3, w2
local t5, t6, t7, t8, t9, t10, t11
' longitude
pl = 0.0
for i% = 89 to 148
pl = pl + cl(i%) * sin(al(i%) + bl(i%) * u)
next i%
pl = pl * 0.0000001 + 6.2458611 + 33408.5620646 * u
h1 = 0.000001 * (186563.7 + u * (18135.0 + u * (-1332.0 + u * (-704.0 + u * (-65.0 - u * 89.0)))))
t5 = 290.0 + u * 100.0
w1 = 0.337967 + u * (33405.348759 + 0.000001 * u * (31676.0 - u * (7354.0 - u * (1143.0 - u * t5))))
pl = modulo(pl + h1 * sin(w1))
' latitude
pb = 0.0
for i% = 149 to 155
pb = pb + cl(i%) * sin(al(i%) + bl(i%) * u)
next i%
t6 = 5310.0 - u * 1050.0
h1 = u * (-10277.0 + u * (24272.0 + u * (-2420.0 + u * (-10850.0 + u * (3880.0 + u * t6)))))
h1 = 0.0000001 * (319714.0 + h1)
w1 = u * (0.048 + u * (-0.04831 + u * (0.01402 + u * (0.029 + u * (-0.0073 - u * 0.0112)))))
w1 = 5.339102 + u * (33407.21879 + w1)
t7 = 220.0 + u * 270.0
h2 = 0.0000001 * (29803.0 + u * (1904.0 + u * (1865.0 + u * (-60.0 + u * (-950.0 + u * t7)))))
w2 = 5.67694 + u * (66812.5668 + u * (0.08030001 + u * (-0.0536.0 + u * (0.0147 + u * 0.028))))
h3 = 0.0000001 * (3137.0 + u * (472.0 + u * (111.0 + u * 70.0)))
w3 = 6.0173 + u * (100217.928 + u * (0.093 + u * (-8.6e-02 + u * 0.037)))
pb = pb * 0.0000001 + h1 * sin(w1) + h2 * sin(w2) + h3 * sin(w3)
' radius
pr = 0.0
for i% = 156 to 184
pr = pr + cl(i%) * cos(al(i%) + bl(i%) * u)
next i%
pr = pr * 0.0000001 + 1.529856
t8 = -153.0 - u * 73.0
h1 = 0.000001 * (141849.5 + u * (13651.8 + u * (-1230.0 + u * (-378.0 + u * (187.0 + u * t8)))))
t9 = 83.0 - u * 48.0
w1 = 3.479698 + u * (33405.34956 + 0.00001 * (u * (3066.9 + u * (-909.0 + u * (223.0 + u * t9)))))
t10 = -12.0 + u * 99.0
h2 = 0.000001 * (6607.8 + u * (1272.8 + u * (-53.0 + u * (-46.0 + u * (14.0 + u * t10)))))
t11 = 0.0012 + u * 0.002
w2 = 3.81781 + u * (66810.6991 + u * (0.0613 + u * (-0.0182 + u * (0.0044 + u * t11))))
pr = pr + h1 * cos(w1) + h2 * cos(w2)
end sub
sub sun(jdtdb, dl, dr, rasc, decl, rsun())
' precision ephemeris of the Sun
' input
' jdtdb = julian ephemeris day
' output
' dl = ecliptic longitude of the sun (radians)
' (0 <= dl <= 2 pi)
' dr = geocentric distance of the sun (AU)
' rasc = right ascension of the Sun (radians)
' (0 <= rasc <= 2 pi)
' decl = declination of the Sun (radians)
' (-pi/2 <= decl <= pi/2)
' rsun() = geocentric position vector of the sun
local u, a1, a2, psi, deps, meps, eps, seps, ceps
local w, srl, crl, srb, crb, sra, cra
' compute nutation in longitude
' compute nutation in obliquity
deps = 0.0000001 * u * (-226938 + u * (-75 + u * (96926 + u * (-2491 - u * 12104))))
meps = 0.0000001 * (4090928.0 + 446.0 * cos(a1) + 28.0 * cos(a2))
eps = meps + deps
obliq = eps
seps = sin(eps)
ceps = cos(eps)
dl = 0.0
dr = 0.0
for i% = 1 to 50
w = sa(i%) + sb(i%) * u
dl = dl + sl(i%) * sin(w)
if (sr(i%) <> 0.0) then
dr = dr + sr(i%) * cos(w)
end if
next i%
dl = modulo(dl * 0.0000001 + 4.9353929 + 62833.196168 * u)
dr = dr * 0.0000001 + 1.0001026
rlsun = modulo(dl + 0.0000001 * (-993.0 + 17.0 * cos(3.1 + 62830.14 * u)) + psi)
rb = 0.0
' compute geocentric declination and right ascension
crl = cos(rlsun)
srl = sin(rlsun)
crb = cos(rb)
srb = sin(rb)
decl = asin(ceps * srb + seps * crb * srl)
sra = -seps * srb + ceps * crb * srl
cra = crb * crl
rasc = atan3(sra, cra)
' geocentric equatorial position vector of the Sun (kilometers)
rsun(1) = dr * cos(rasc) * cos(decl)
rsun(2) = dr * sin(rasc) * cos(decl)
rsun(3) = dr * sin(decl)
end sub
sub julian(month, day, year, jday)
' Gregorian date to julian day subroutine
' input
' month = calendar month
' day = calendar day
' year = calendar year (all four digits)
' output
' jday = julian day
' special notes
' (1) calendar year must include all digits
' (2) will report October 5, 1582 to October 14, 1582
' as invalid calendar dates and exit
local a, b, c, m, y
y = year
m = month
b = 0.0
c = 0.0
if (m <= 2.0) then
y = y - 1.0
m = m + 12.0
end if
if (y < 0.0) then c = -0.75
if (year < 1582.0) then
' null
elseif (year > 1582.0) then
a = fix(y / 100.0)
b = 2.0 - a + fix(a / 4.0)
elseif (month < 10.0) then
' null
elseif (month > 10.0) then
a = fix(y / 100.0)
elseif (day <= 4.0) then
' null
elseif (day > 14.0) then
a = fix(y / 100.0)
else
print "this date does not exist!!"
exit
end if
jday = fix(365.25 * y + c) + fix(30.6001 * (m + 1.0)) + day + b + 1720994.5
end sub
sub gdate (jday, month, day, year)
' Julian day to Gregorian date subroutine
' input
' jday = julian day
' output
local a, b, c, d, e, f, z, alpha
z = fix(jday + 0.5)
f = jday + 0.5 - z
if (z < 2299161) then
a = z
else
alpha = fix((z - 1867216.25) / 36524.25)
a = z + 1.0 + alpha - fix(alpha / 4.0)
end if
b = a + 1524.0
c = fix((b - 122.1) / 365.25)
d = fix(365.25 * c)
e = fix((b - d) / 30.6001)
day = b - d - fix(30.6001 * e) + f
if (e < 13.5) then
month = e - 1.0
else
month = e - 13.0
end if
if (month > 2.5) then
year = c - 4716.0
else
year = c - 4715.0
end if
end sub
sub utc2tdb (jdutc, jdtdb)
' convert UTC julian date to TDB julian date
' input
' jdutc = UTC julian day
' output
' jdtdb = TDB julian day
' Reference Frames in Astronomy and Geophysics
' J. Kovalevsky et al., 1989, pp. 439-442
local corr, jdtt, t, leapsecond
' find current number of leap seconds
findleap(jdutc, leapsecond)
' compute TDT julian date
corr = (leapsecond + 32.184) / 86400.0
jdtt = jdutc + corr
' time argument for correction
t = (jdtt - 2451545.0) / 36525.0
' compute correction in microseconds
corr = 1656.675 * sin(dtr * (35999.3729 * t + 357.5287))
corr = corr + 22.418 * sin(dtr * (32964.467 * t + 246.199))
corr = corr + 13.84 * sin(dtr * (71998.746 * t + 355.057))
corr = corr + 4.77 * sin(dtr * ( 3034.906 * t + 25.463))
corr = corr + 4.677 * sin(dtr * (34777.259 * t + 230.394))
corr = corr + 10.216 * t * sin(dtr * (35999.373 * t + 243.451))
corr = corr + 0.171 * t * sin(dtr * (71998.746 * t + 240.98 ))
corr = corr + 0.027 * t * sin(dtr * ( 1222.114 * t + 194.661))
corr = corr + 0.027 * t * sin(dtr * ( 3034.906 * t + 336.061))
corr = corr + 0.026 * t * sin(dtr * ( -20.186 * t + 9.382))
corr = corr + 0.007 * t * sin(dtr * (29929.562 * t + 264.911))
corr = corr + 0.006 * t * sin(dtr * ( 150.678 * t + 59.775))
corr = corr + 0.005 * t * sin(dtr * ( 9037.513 * t + 256.025))
corr = corr + 0.043 * t * sin(dtr * (35999.373 * t + 151.121))
' convert corrections to days
corr = 0.000001 * corr / 86400.0
' TDB julian date
jdtdb = jdtt + corr
end sub
sub tdb2utc (jdtdb, jdutc)
' convert TDB julian day to UTC julian day subroutine
' input
' output
local x1, x2, xroot, froot
jdsaved = jdtdb
' set lower and upper bounds
x1 = jdsaved - 0.1
x2 = jdsaved + 0.1
' solve for UTC julian day using Brent's method
realroot(x1, x2, 1.0e-8, xroot, froot)
jdutc = xroot
end sub
sub jdfunc (jdin, fx)
' objective function for tdb2utc
' input
' jdin = current value for UTC julian day
' output
' fx = delta julian day
local jdwrk
utc2tdb(jdin, jdwrk)
fx = jdwrk - jdsaved
end sub
sub jd2str(jdutc)
' convert julian day to calendar date and UTC time
gdate (jdutc, cmonth, day, year)
print "calendar date ", month$(cmonth); " ", STR$(int(day)); " "; str$(year)
print " "
thr0 = 24.0 * (day - int(day))
thr = int(thr0)
tmin0 = 60.0 * (thr0 - thr)
tmin = int(tmin0)
tsec = 60.0 * (tmin0 - tmin)
' fix seconds and minutes for rollover
if (tsec >= 60.0) then
tsec = 0.0
tmin = tmin + 1.0
end if
' fix minutes for rollover
if (tmin >= 60.0) then
tmin = 0.0
thr = thr + 1.0
end if
print "UTC time ", str$(thr) + " hours " + str$(tmin) + " minutes " + str$(tsec, 0, 2) + " seconds"
end sub
sub findleap(jday, leapsecond)
' find number of leap seconds for utc julian day
' input
' jday = utc julian day
' input via global
' jdleap = array of utc julian dates
' leapsec = array of leap seconds
' output
' leapsecond = number of leap seconds
if (jday <= jdleap(1)) then
' date is <= 1972; set to first data element
leapsecond = leapsec(1)
exit sub
end if
if (jday >= jdleap(28)) then
' date is >= end of current data
' set to last data element
leapsecond = leapsec(28)
exit sub
end if
' find data within table
for i% = 1 to 27
if (jday >= jdleap(i%) and jday < jdleap(i% + 1)) then
leapsecond = leapsec(i%)
exit sub
end if
next i%
end sub
function modulo(x) as float
' modulo 2 pi function
local a
a = x - pi2 * fix(x / pi2)
if (a < 0.0) then
a = a + pi2
end if
modulo = a
end function
function atan3(a, b) as float
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' atan3 = angle (0 =< atan3 <= 2 * pi; radians)
local c
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
sub read_data
' read sun and planet data subroutine
for i% = 1 to 50
read sl(i%), sr(i%), sa(i%), sb(i%)
next i%
for i% = 1 to 184
read cl(i%), al(i%), bl(i%)
next i%
' data for the sun - longitude and radius vector
data 403406, 0, 4.721964, 1.621043
data 195207, -97597, 5.937458, 62830.348067
data 119433, -59715, 1.115589, 62830.821524
data 112392, -56188, 5.781616, 62829.634302
data 3891, -1556, 5.5474 , 125660.5691
data 2819, -1126, 1.5120 , 125660.9845
data 1721, -861, 4.1897 , 62832.4766
data 0, 941, 1.163 , 0.813
data 660, -264, 5.415 , 125659.310
data 350, -163, 4.315 , 57533.850
data 334, 0, 4.553 , -33.931
data 314, 309, 5.198 , 777137.715
data 268, -158, 5.989 , 78604.191
data 242, 0, 2.911 , 5.412
data 234, -54, 1.423 , 39302.098
data 158, 0, 0.061 , -34.861
data 132, -93, 2.317 , 115067.698
data 129, -20, 3.193 , 15774.337
data 114, 0, 2.828 , 5296.670
data 99, -47, 0.52 , 58849.27
data 93, 0, 4.65 , 5296.11
data 86, 0, 4.35 , -3980.70
data 78, -33, 2.75 , 52237.69
data 72, -32, 4.50 , 55076.47
data 68, 0, 3.23 , 261.08
data 64, -10, 1.22 , 15773.85
data 46, -16, 0.14 , 188491.03
data 38, 0, 3.44 , -7756.55
data 37, 0, 4.37 , 264.89
data 32, -24, 1.14 , 117906.27
data 29, -13, 2.84 , 55075.75
data 28, 0, 5.96 , -7961.39
data 27, -9, 5.09 , 188489.81
data 27, 0, 1.72 , 2132.19
data 25, -17, 2.56 , 109771.03
data 24, -11, 1.92 , 54868.56
data 21, 0, 0.09 , 25443.93
data 21, 31, 5.98 , -55731.43
data 20, -10, 4.03 , 60697.74
data 18, 0, 4.27 , 2132.79
data 17, -12, 0.79 , 109771.63
data 14, 0, 4.24 , -7752.82
data 13, -5, 2.01 , 188491.91
data 13, 0, 2.65 , 207.81
data 13, 0, 4.98 , 29424.63
data 12, 0, 0.93 , -7.99
data 10, 0, 2.21 , 46941.14
data 10, 0, 3.59 , -68.29
data 10, 0, 1.50 , 21463.25
data 10, -9, 2.55 , 157208.40
' data for mercury - heliocentric longitude, latitude and radius vector
data 510728, 6.09670 , 521757.52364 , 404847, 4.72189, 1.62027
data 91048, 2.8946 , 782636.2744 , 30594, 4.1535 , 521758.6270
data 15769, 5.8003 , 1043515.073 , 13726, 0.4656 , 521756.9570
data 11582, 1.0266 , 782637.2016 , 7633, 3.517 , 521759.335
data 5247, 0.418 , 782638.007 , 4001, 3.993 , 1043516.352
data 3299, 2.791 , 1304393.680 , 3212, 0.209 , 1043514.724
data 1690, 2.067 , 1304394.627 , 1482, 6.174 , 1304395.168
data 1233, 3.606 , 782635.409 , 1152, 5.856 , 1565272.646
data 845, 2.63 , 1043516.88 , 654, 3.40 , 1565273.50
data 359, 2.66 , 1826151.56 , 356, 3.08 , 11094.77
data 257, 6.27 , 1826152.20 , 246, 2.89 , 5.41
data 180, 5.67 , 56613.61 , 159, 4.57 , 250285.49
data 137, 6.17 , 271973.50
data 680303, 3.82625 , 260879.17693 , 538354, 3.30009, 260879.66625
data 176935, 3.74070 , 0.40005 , 143323, 0.58073, 521757.92658
data 105214, 0.0545 , 521758.44880 , 91011, 3.3915 , 0.9954
data 47427, 1.9266 , 260878.2610 , 41669, 3.5084 , 782636.7624
data 19826, 3.1539 , 782637.4813 , 12963, 0.2455 , 1043515.6610
data 8233, 4.886 , 521756.972 , 6399, 0.358 , 782637.769
data 3196, 3.253 , 1304394.380 , 1536, 4.824 , 1043516.451
data 824, 0.04 , 1565273.15 , 819, 1.84 , 782635.45
data 324, 1.60 , 1304395.53 , 201, 2.92 , 1826151.86
data 780141, 6.202782, 260878.753962, 78942, 2.98062, 521757.50830
data 12000, 6.0391 , 782636.2640 , 9839, 4.8422 , 260879.3808
data 2355, 5.062 , 0.734 , 2019, 2.898 , 1043514.987
data 1974, 1.588 , 521758.140 , 1859, 0.805 , 260877.716
data 426, 4.601 , 782636.915 , 397, 5.976 , 1304393.735
data 382, 3.86 , 521756.47 , 306, 1.87 , 1043515.34
data 102, 0.62 , 782635.28 , 92, 2.60 , 1565272.52
' data for venus - heliocentric longitude, latitude and radius vector
data 423015, 4.722173, 1.600752, 548 , 5.987 , 78604.195
data 346, 4.27 , 117906.29 , 253 , 2.95 , 5.37
data 237, 4.56 , 39302.10 , 181 , 0.05 , 15774.33
data 153, 2.14 , 306400.25 , 144 , 5.73 , 96835.94
data 99, 0.09 , 261.08 , 98 , 6.18 , 306399.50
data 89, 4.34 , 15773.85 , 85 , 2.86 , 94378.51
data 69, 2.85 , 5296.67 , 56 , 5.71 , 1915.95
data 55, 1.23 , 264.89 , 55 , 2.85 , 7756.55
data 50, 5.69 , 157208.38 , 48 , 4.62 , 5296.12
data 43, 5.16 , 193671.89 , 39 , 0.85 , 94377.98
data 590350, 1.759897, 102133.735253, 34737, 3.17478, 102133.01934
data 13104, 0.2705 , 2.0678 , 12910, 3.7446 , 102134.2721
data 8591, 3.7878 , 1.5631 , 7015, 3.3730 , 2.2248
data 2101, 2.828 , 0.361 , 163, 2.85 , 78604.20
data 138, 1.13 , 117906.29 , 50, 2.59 , 96835.94
data 37, 1.42 , 39302.10
' data for mars - heliocentric longitude, latitude and radius vector
data 424067, 4.725053, 1.599646 , 117053, 0.92177, 66810.71641
data 31286, 5.17451 , 66811.55202 , 10248, 1.3885 , 100216.0920
data 4933, 1.4302 , 66813.4604 , 4130, 5.4976 , 100216.8648
data 2605, 1.382 , -33.896 , 1334, 3.104 , -34.791
data 1232, 2.420 , 28109.218 , 1180, 2.148 , 133621.421
data 959, 4.404 , 22813.140 , 827, 6.053 , 133621.745
data 778, 4.910 , 56218.431 , 692, 1.881 , 100218.894
data 667, 1.267 , -3980.684 , 416, 1.799 , 29424.634
data 354, 3.146 , 25443.942 , 341, 1.005 , 66815.503
data 339, 1.420 , 33371.351 , 310, 0.916 , -33439.371
data 294, 2.57 , 1915.95 , 260, 2.69 , -7961.45
data 245, 3.70 , 33370.81 , 242, 2.94 , 5.41
data 198, 2.78 , 5296.69 , 182, 3.09 , -33440.09
data 167, 4.28 , 17516.29 , 153, 2.72 , 61514.60
data 148, 5.27 , 22812.71 , 141, 4.51 , 21463.18
data 128, 1.06 , 100220.45 , 126, 5.19 , 50921.57
data 105, 0.77 , 5296.06 , 103, 5.26 , 89623.78
data 86, 3.97 , 29140.97 , 81, 5.38 , 1559.53
data 72, 0.90 , -37386.05 , 71, 5.23 , 10592.20
data 66, 2.06 , 31273.21 , 64, 4.49 , 84327.58
data 63, 1.43 , 167027.36 , 60, 1.77 , 133625.34
data 55, 4.02 , -7.37 , 55, 6.05 , 17482.57
data 47, 4.23 , -11942.07 , 45, 1.23 , 1914.57
data 43, 6.24 , -3981.49 , 43, 2.12 , 62829.99
data 42, 2.07 , 2131.89 , 38, 4.90 , -7962.27
data 36, 0.02 , 17514.95 , 33, 2.37 , 167026.02
data 31, 4.65 , 25443.27 , 31, 2.57 , 66776.76
data 30, 1.19 , -66844.78 , 30, 6.06 , 35321.38
data 30, 4.35 , 62546.28 , 29, 5.79 , 207.81
data 28, 1.17 , 13501.91 , 28, 2.09 , -31489.48
data 32962, 1.67255 , 1.77247 , 9705, 3.5531 , 0.9198
data 367, 0.353 , 133623.307 , 101, 4.74 , 133624.11
data 44, 0.94 , 33373.21 , 44, 2.83 , -33441.23
data 40, 0.42 , 167028.67
data 27946, 4.8846 , 0.4677 , 5147, 4.5968 , 100216.0535
data 2196, 2.568 , 100216.663 , 811, 5.560 , 28109.218
data 749, 1.772 , 56218.430 , 559, 5.112 , 133621.486
data 503, 1.272 , 22813.139 , 332, 2.701 , 133621.941
data 258, 4.56 , 33371.35 , 248, 4.93 , 29424.63
data 236, 0.92 , -33439.37 , 231, 0.09 , 25443.93
data 186, 0.56 , 33370.81 , 138, 3.09 , -33440.09
data 117, 2.11 , 50921.57 , 110, 1.27 , -3980.70
data 99, 5.84 , 61514.59 , 90, 4.41 , 5296.11
data 90, 5.64 , 167026.95 , 81, 2.10 , 10592.24
data 80, 2.83 , -7961.39 , 74, 1.50 , 21463.25
data 73, 1.25 , 84327.62 , 71, 2.86 , 167027.21
data 69, 2.10 , 22812.70 , 69, 2.13 , 89623.77
data 63, 1.29 , 17516.40 , 57, 0.83 , 29140.97
data 53, 0.90 , -37386.04
' calendar months
month$(1) = "January"
month$(2) = "February"
month$(3) = "March"
month$(4) = "April"
month$(5) = "May"
month$(6) = "June"
month$(7) = "July"
month$(8) = "August"
month$(9) = "September"
month$(10) = "October"
month$(11) = "November"
month$(12) = "December"
' read leap second data
for i% = 1 to 28
read jdleap(i%), leapsec(i%)
next i%
data 2441317.5, 10.0
data 2441499.5, 11.0
data 2441683.5, 12.0
data 2442048.5, 13.0
data 2442413.5, 14.0
data 2442778.5, 15.0
data 2443144.5, 16.0
data 2443509.5, 17.0
data 2443874.5, 18.0
data 2444239.5, 19.0
data 2444786.5, 20.0
data 2445151.5, 21.0
data 2445516.5, 22.0
data 2446247.5, 23.0
data 2447161.5, 24.0
data 2447892.5, 25.0
data 2448257.5, 26.0
data 2448804.5, 27.0
data 2449169.5, 28.0
data 2449534.5, 29.0
data 2450083.5, 30.0
data 2450630.5, 31.0
data 2451179.5, 32.0
data 2453736.5, 33.0
data 2454832.5, 34.0
DATA 2456109.5, 35.0
data 2457204.5, 36.0
data 2457754.5, 37.0
end sub
function vecmag(a())
' vector magnitude function
' input
' { a } = column vector ( 3 rows by 1 column )
' output
' vecmag = scalar magnitude of vector { a }
vecmag = sqr(a(1) * a(1) + a(2) * a(2) + a(3) * a(3))
end function
sub getdate (month, day, year)
' request calendar date subroutine
do
print " "
print "please input the calendar date"
print " "
print "(month [1 - 12], day [1 - 31], year [yyyy])"
print "< for example, october 21, 1986 is input as 10,21,1986 >"
print "< b.c. dates are negative, a.d. dates are positive >"
print "< the day of the month may also include a decimal part >"
print " "
input month, day, year
loop until (month >= 1 and month <= 12) and (day >= 1 and day <= 31)
end sub
sub getutc (thr, tmin, tsec)
' request time subroutine
do
print " "
print "please input the UTC time"
print " "
print "(hours [0 - 24], minutes [0 - 60], seconds [0 - 60])"
print " "
input thr, tmin, tsec
loop until ((thr >= 0.0 and thr <= 24.0) and (tmin >= 0.0 and tmin <= 60.0) and (tsec >= 0.0 and tsec <= 60.0))
end sub
