Local Time 16:58 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - Sun and inner planet ephemeris
cdeagle
Posted: 09:52am 08 Apr 2017
This post describes an MMBASIC double precision computer program called ephem1.bas that can be used to create an accurate ephemeris of the sun and inner planets (Mercury, Venus, Earth and Mars). A classical ephemeris consists of tables of sun and planet coordinates at periodic or special times or events.
This program provides the rectangular position vectors in both the heliocentric and geocentric coordinate systems. It also provides the Earth-centered-inertial (ECI) right ascension and declination of the sun and other planets.
Here's a typical user interaction with ephem1.bas. Notice that all components of position vectors are in the measure of astronomical units (1 AU = 149597870.691 kilometers).
please input the calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 4,8,2017
please input the UTC time
(hours [0 - 24], minutes [0 - 60], seconds [0 - 60])
? 12,38,0
calendar date April 8 2017
UTC time 12 hours 38 minutes -0.00 seconds
UTC Julian day 2457852.02638889
Mercury
right ascension 2.0902 hours
declination 16.0788 degrees
geocentric position vector and magnitude (au)
0.5910612117 0.3601222867 0.1994953608 0.7203053637
heliocentric position vector and magnitude (au)
-0.3564973767 0.0630215621 0.0707132033 0.3688664447
Venus
right ascension 23.7115 hours
declination 4.6409 degrees
0.3088187367 -0.0233674132 0.0251406296 0.3107202907
-0.6387398517 -0.3204681377 -0.1036415279 0.7221010957
Sun/Earth
right ascension 1.1606 hours
declination 7.3891 degrees
-0.9475585887 -0.2971007247 -0.1287821575 1.0013595570
Mars
right ascension 3.2296 hours
declination 18.4480 degrees
1.4313507217 1.6146954787 0.7198071077 2.2746711077
0.4837921337 1.3175947537 0.5910249507 1.5229646277
Here's a PDF document that illustrates several ephemeris algorithms.
2017-04-08_195205_ephemeris.pdf
The following is the MMBASIC source code listing for this computer program.
' program ephem1.bas April 8, 2017
' sun and inner planet ephemeris
' Special thanks to Pierre Bretagnon and Jean-Louis Simon
' for developing their eloquent planetary ephemeris.
' "Planetary Programs and Tables from -4000 to +2800"
option default float
option base 1
const pi2 = 2.0 * pi, pidiv2 = 0.5 * pi, rtd = 180.0 / pi, dtr = pi / 180.0
dim body$(4), month$(12)
dim rsun(3), rpg(3), rph(3), jdleap(28), leapsec(28)
dim sl(50), sr(50), sa(50), sb(50), cl(184), al(184), bl(184)
dim ibody%, utc_hr, utc_min, utc_sec, cmonth, cday, cyear
' read sun and planet data
read_data
' request epoch of interest
getdate (cmonth, cday, cyear)
' UTC julian day
julian(cmonth, cday, cyear, jdutc)
getutc(utc_hr, utc_min, utc_sec)
jdutc = jdutc + utc_hr / 24.0 + utc_min / 1440.0 + utc_sec / 86400.0
' TDB julian day
utc2tdb(jdutc, jdtdb)
print " "
print " "
jd2str(jdutc)
print " "
print "UTC Julian day ", str$(jdutc, 0, 8)
print " "
' calculate and display ephemeris for each ody
for ibody% = 1 to 4
ephem(ibody%, jdtdb, rpg(), rph(), rasc, decl)
print " "
print body$(ibody%)
print " "
print "right ascension ", str$(24.0 * (rasc / pi2), 0, 4), " hours"
print " "
print "declination ", str$(rtd * decl, 0, 4), " degrees"
print " "
if (ibody% <> 3) then
print "geocentric position vector and magnitude (au)"
print " "
print str$(rpg(1), 0, 10), " ", str$(rpg(2), 0, 10), " ", str$(rpg(3), 0, 10), " ", str$(vecmag(rpg()), 0, 10)
print " "
end if
print "heliocentric position vector and magnitude (au)"
print " "
print str$(rph(1), 0, 10), " ", str$(rph(2), 0, 10), " ", str$(rph(3), 0, 10), " ", str$(vecmag(rph()), 0, 10)
print " "
next ibody%
end
sub ephem(ibody%, jdtdb, rpg(), rph(), rasc, decl)
' sun and inner planet ephemeris subroutine
' input
' ibody% = celestial body index
' jdtdb = tdb julian day
' output
' rpg() = geocentric position vector (au)
' rph() = heliocentric position vector (au)
' rasc = geocentric right ascension (radians)
' decl = geocentric declination (radians)
local dls, drs, gl, gb, pl, pb, pr, alon, alat
' compute coordinates of the sun
sun(jdtdb, dls, drs, rasun, decsun, rsun())
gl = dls
' compute coordinates of the planet
select case ibody%
case 1
mercury(jdtdb, pl, pb, pr)
case 2
venus(jdtdb, pl, pb, pr)
case 3
' sun/earth
for i% = 1 to 3
rph(i%) = -rsun(i%)
rpg(i%) = 0.0
next i%
rasc = rasun
decl = decsun
exit sub
case 4
mars(jdtdb, pl, pb, pr)
end select
' compute geocentric mean coordinates
latlong(dls, drs, pl, pb, pr, gl, gb, rpgm)
' apparent geocentric equatorial right ascension and declination
abernu(jdtdb, ibody%, gl, gb, alon, alat, rasc, decl)
' compute geocentric equatorial unit position vector of planet
rpg(1) = rpgm * cos(rasc) * cos(decl)
rpg(2) = rpgm * sin(rasc) * cos(decl)
rpg(3) = rpgm * sin(decl)
' compute geocentric equatorial position vector
for i% = 1 to 3
rph(i%) = rpg(i%) - rsun(i%)
next i%
end sub
sub latlong(sl, sr, pl, pb, pr, gl, gb, rpgm)
' geocentric mean coordinates subroutine
local xs, ys, xp, yp, zp, x, y, z
' heliocentric ecliptic position of the sun
xs = sr * cos(sl)
ys = sr * sin(sl)
' heliocentric ecliptic position of planet
xp = pr * cos(pb) * cos(pl)
yp = pr * cos(pb) * sin(pl)
zp = pr * sin(pb)
' geocentric ecliptic position of planet
x = xp + xs
y = yp + ys
z = zp
' mean geocentric longitude of planet (radians)
gl = atan3(y, x)
' mean geocentric latitude of planet (radians)
gb = atan2(z, sqr(x^2 + y^2))
' geocentric distance of planet
rpgm = sqr(x * x + y * y + z * z)
end sub
sub abernu(jdtdb, ibody%, gl, gb, alon, alat, rasc, decl)
' aberration and nutation corrections subroutine
local u, a1, a2, dpsi, deps, epsi
local xce, xse, xcl, xsl, xcb, xsb
' fundamental time argument
u = (jdtdb - 2451545.0) / 3652500.0
select case ibody%
case 1
' mercury
alon = gl + 0.0000001 * (-1261.0 + 1485.0 * cos(2.649 + 198048.273 * u))
alon = alon + 0.0000001 * (305.0 * cos(5.71 + 458927.03 * u) + 230.0 * cos(5.3 + 396096.55 * u))
alat = gb + 0.000019 * cos(0.42 + 260879.41 * u)
case 2
' venus
alon = gl + 0.0000001 * (-1304.0 + 1016.0 * cos(1.423 + 39302.097 * u))
alon = alon + 0.0000001 * (224.0 * cos(2.85 + 78604.19 * u) + 98.0 * cos(4.27 + 117906.29 * u))
alat = gb
case 3
' earth
alon = gl + 0.0000001 * (-993.0 + 17.0 * cos(3.1 + 62830.14 * u))
alat = 0.0
case 4
' mars
alon = gl + 0.0000001 * (-1052.0 + 877.0 * cos(1.834 + 29424.634 * u))
alon = alon + 0.0000001 * (187.0 * cos(3.67 + 58849.27 * u) + 84.0 * cos(3.49 + 33405.34 * u))
alat = gb
end select
' nutation corrections
a1 = 2.18 + u * (-3375.7 + u * 0.36)
a2 = 3.51 + u * (125666.39 + u * 0.1)
dpsi = 0.0000001 * (-834.0 * sin(a1) - 64.0 * sin(a2))
deps = 0.0000001 * u * (-226938.0 + u * (-75.0 + u * (96926.0 + u * (-2491.0 - u * 12104.0))))
epsi = 0.0000001 * (4090928.0 + 446.0 * cos(a1) + 28.0 * cos(a2)) + deps
alon = modulo(alon + dpsi)
' compute right ascension and declination (radians)
xce = cos(epsi)
xse = sin(epsi)
xcl = cos(alon)
xsl = sin(alon)
xcb = cos(alat)
xsb = sin(alat)
decl = asin(xce * xsb + xse * xcb * xsl)
rasc = atan3(-xse * xsb + xce * xcb * xsl, xcb * xcl)
end sub
sub mercury(jdtdb, pl, pb, pr)
' computation of the heliocentric coordinates of mercury
local u, h1, w1
pl = 0.0
for i% = 1 to 25
pl = pl + cl(i%) * sin(al(i%) + bl(i%) * u)
next i%
pl = pl * 0.0000001 + 4.4429839 + u * 260881.4701279
h1 = 0.000001 * (409894.2 + u * (2435.0 + u * (-1408.0 + u * (114.0 + u * (233.0 - u * 88.0)))))
w1 = 3.053817 + u * (260878.756773 + u * (-0.001093 + u * (-9.3e-04 + u * (0.00043 + u * 0.00014))))
pl = modulo(pl + h1 * sin(w1))
pb = 0.0
for i% = 26 to 43
pb = pb + cl(i%) * sin(al(i%) + bl(i%) * u)
next i%
pb = pb * 0.0000001
pr = 0.0
for i% = 44 to 57
pr = pr + cl(i%) * cos(al(i%) + bl(i%) * u)
next i%
pr = pr * 0.0000001 + 0.395202
end sub
sub venus(jdtdb, pl, pb, pr)
' computation of the heliocentric coordinates of venus
local u, t1, h1, t2, w1, t3, h2, w2, t4
pl = 0.0
for i% = 58 to 77
next i%
pl = pl * 0.0000001 + 3.2184413 + u * 102135.2937764
t1 = -51.0 + u * 10.0
h1 = 0.000001 * (13539.7 + u * (-9570.0 + u * (1987.0 + u * (927.0 + u * (230.0 + u * t1)))))
t2 = 0.0017 + u * 0.0151
w1 = 0.88074 + u * (102132.84648 + u * (0.24082 + u * (0.1004 + u * (0.0355 - u * t2))))
t3 = -79.0 + u * 56.0
h2 = 0.000001 * (898.9 + u * (112.4 + u * (-170.0 + u * (113.0 + u * (34.0 + u * t3)))))
w2 = 0.5941 + u * (204267.313 + u * (0.014 + u * (0.123 + u * (-0.146 + u * 0.052))))
pl = modulo(pl + h1 * sin(w1) + h2 * sin(w2))
pb = 0.0
for i% = 78 to 83
next i%
h1 = 0.0000001 * (4011.0 + u * (-2713.0 + u * (490.0 + u * (290.0 + u * 90.0))))
w1 = 2.7182 + u * (204266.568 + u * (0.225 + u * (0.102 + u * 0.035)))
h2 = 0.0000001 * (101.0 + u * (26.0 - u * 64.0))
w2 = 2.66 + u * (306400.49 + u * 0.45)
pb = pb * 0.0000001 + h1 * sin(w1) + h2 * sin(w2)
pr = 0.0
for i% = 84 to 88
next i%
pr = pr * 0.0000001 + 0.7235481
h1 = 0.0000001 * (48982.0 + u * (-34549.0 + u * (7096.0 + u * (3360.0 + u * (890.0 - u * 210.0)))))
t4 = -0.0013 - u * 0.015
w1 = 4.02152 + u * (102132.84695 + u * (0.242 + u * (0.0994 + u * (0.0351 + u * t4))))
h2 = 0.0000001 * (166.0 + u * (-234.0 + u * 131.0))
w2 = 4.9 + u * (204265.69 + u * (0.48 + u * 0.2))
pr = pr + h1 * cos(w1) + h2 * cos(w2)
end sub
sub mars(jdtdb, pl, pb, pr)
' computation of the heliocentric coordinates of mars
local u, h1, h2, h3, w1, w3, w2
local t5, t6, t7, t8, t9, t10, t11
' longitude
pl = 0.0
for i% = 89 to 148
next i%
pl = pl * 0.0000001 + 6.2458611 + 33408.5620646 * u
h1 = 0.000001 * (186563.7 + u * (18135.0 + u * (-1332.0 + u * (-704.0 + u * (-65.0 - u * 89.0)))))
t5 = 290.0 + u * 100.0
w1 = 0.337967 + u * (33405.348759 + 0.000001 * u * (31676.0 - u * (7354.0 - u * (1143.0 - u * t5))))
' latitude
pb = 0.0
for i% = 149 to 155
next i%
t6 = 5310.0 - u * 1050.0
h1 = u * (-10277.0 + u * (24272.0 + u * (-2420.0 + u * (-10850.0 + u * (3880.0 + u * t6)))))
h1 = 0.0000001 * (319714.0 + h1)
w1 = u * (0.048 + u * (-0.04831 + u * (0.01402 + u * (0.029 + u * (-0.0073 - u * 0.0112)))))
w1 = 5.339102 + u * (33407.21879 + w1)
t7 = 220.0 + u * 270.0
h2 = 0.0000001 * (29803.0 + u * (1904.0 + u * (1865.0 + u * (-60.0 + u * (-950.0 + u * t7)))))
w2 = 5.67694 + u * (66812.5668 + u * (0.08030001 + u * (-0.0536.0 + u * (0.0147 + u * 0.028))))
h3 = 0.0000001 * (3137.0 + u * (472.0 + u * (111.0 + u * 70.0)))
w3 = 6.0173 + u * (100217.928 + u * (0.093 + u * (-8.6e-02 + u * 0.037)))
pb = pb * 0.0000001 + h1 * sin(w1) + h2 * sin(w2) + h3 * sin(w3)
' radius
pr = 0.0
for i% = 156 to 184
next i%
pr = pr * 0.0000001 + 1.529856
t8 = -153.0 - u * 73.0
h1 = 0.000001 * (141849.5 + u * (13651.8 + u * (-1230.0 + u * (-378.0 + u * (187.0 + u * t8)))))
t9 = 83.0 - u * 48.0
w1 = 3.479698 + u * (33405.34956 + 0.00001 * (u * (3066.9 + u * (-909.0 + u * (223.0 + u * t9)))))
t10 = -12.0 + u * 99.0
h2 = 0.000001 * (6607.8 + u * (1272.8 + u * (-53.0 + u * (-46.0 + u * (14.0 + u * t10)))))
t11 = 0.0012 + u * 0.002
w2 = 3.81781 + u * (66810.6991 + u * (0.0613 + u * (-0.0182 + u * (0.0044 + u * t11))))
end sub
sub sun(jdtdb, dl, dr, rasc, decl, rsun())
' precision ephemeris of the Sun
' input
' jdtdb = julian ephemeris day
' output
' dl = ecliptic longitude of the sun (radians)
' (0 <= dl <= 2 pi)
' dr = geocentric distance of the sun (AU)
' rasc = right ascension of the Sun (radians)
' (0 <= rasc <= 2 pi)
' decl = declination of the Sun (radians)
' (-pi/2 <= decl <= pi/2)
local u, a1, a2, psi, deps, meps, eps, seps, ceps
local w, srl, crl, srb, crb, sra, cra
' compute nutation in longitude
' compute nutation in obliquity
deps = 0.0000001 * u * (-226938 + u * (-75 + u * (96926 + u * (-2491 - u * 12104))))
meps = 0.0000001 * (4090928.0 + 446.0 * cos(a1) + 28.0 * cos(a2))
eps = meps + deps
obliq = eps
seps = sin(eps)
ceps = cos(eps)
dl = 0.0
dr = 0.0
for i% = 1 to 50
w = sa(i%) + sb(i%) * u
dl = dl + sl(i%) * sin(w)
if (sr(i%) <> 0.0) then
dr = dr + sr(i%) * cos(w)
end if
next i%
dl = modulo(dl * 0.0000001 + 4.9353929 + 62833.196168 * u)
dr = dr * 0.0000001 + 1.0001026
rlsun = modulo(dl + 0.0000001 * (-993.0 + 17.0 * cos(3.1 + 62830.14 * u)) + psi)
rb = 0.0
' compute geocentric declination and right ascension
crl = cos(rlsun)
srl = sin(rlsun)
crb = cos(rb)
srb = sin(rb)
decl = asin(ceps * srb + seps * crb * srl)
sra = -seps * srb + ceps * crb * srl
cra = crb * crl
rasc = atan3(sra, cra)
' geocentric equatorial position vector of the Sun (kilometers)
rsun(1) = dr * cos(rasc) * cos(decl)
rsun(2) = dr * sin(rasc) * cos(decl)
rsun(3) = dr * sin(decl)
end sub
sub julian(month, day, year, jday)
' Gregorian date to julian day subroutine
' input
' month = calendar month
' day = calendar day
' year = calendar year (all four digits)
' output
' jday = julian day
' special notes
' (1) calendar year must include all digits
' (2) will report October 5, 1582 to October 14, 1582
' as invalid calendar dates and exit
local a, b, c, m, y
y = year
m = month
b = 0.0
c = 0.0
if (m <= 2.0) then
y = y - 1.0
m = m + 12.0
end if
if (y < 0.0) then c = -0.75
if (year < 1582.0) then
' null
elseif (year > 1582.0) then
a = fix(y / 100.0)
b = 2.0 - a + fix(a / 4.0)
elseif (month < 10.0) then
' null
elseif (month > 10.0) then
a = fix(y / 100.0)
elseif (day <= 4.0) then
' null
elseif (day > 14.0) then
a = fix(y / 100.0)
else
print "this date does not exist!!"
exit
end if
jday = fix(365.25 * y + c) + fix(30.6001 * (m + 1.0)) + day + b + 1720994.5
end sub
sub gdate (jday, month, day, year)
' Julian day to Gregorian date subroutine
' input
' jday = julian day
' output
local a, b, c, d, e, f, z, alpha
z = fix(jday + 0.5)
f = jday + 0.5 - z
if (z < 2299161) then
a = z
else
alpha = fix((z - 1867216.25) / 36524.25)
a = z + 1.0 + alpha - fix(alpha / 4.0)
end if
b = a + 1524.0
c = fix((b - 122.1) / 365.25)
d = fix(365.25 * c)
e = fix((b - d) / 30.6001)
day = b - d - fix(30.6001 * e) + f
if (e < 13.5) then
month = e - 1.0
else
month = e - 13.0
end if
if (month > 2.5) then
year = c - 4716.0
else
year = c - 4715.0
end if
end sub
sub utc2tdb (jdutc, jdtdb)
' convert UTC julian date to TDB julian date
' input
' jdutc = UTC julian day
' output
' jdtdb = TDB julian day
' Reference Frames in Astronomy and Geophysics
' J. Kovalevsky et al., 1989, pp. 439-442
local corr, jdtt, t, leapsecond
' find current number of leap seconds
findleap(jdutc, leapsecond)
' compute TDT julian date
corr = (leapsecond + 32.184) / 86400.0
jdtt = jdutc + corr
' time argument for correction
t = (jdtt - 2451545.0) / 36525.0
' compute correction in microseconds
corr = 1656.675 * sin(dtr * (35999.3729 * t + 357.5287))
corr = corr + 22.418 * sin(dtr * (32964.467 * t + 246.199))
corr = corr + 13.84 * sin(dtr * (71998.746 * t + 355.057))
corr = corr + 4.77 * sin(dtr * ( 3034.906 * t + 25.463))
corr = corr + 4.677 * sin(dtr * (34777.259 * t + 230.394))
corr = corr + 10.216 * t * sin(dtr * (35999.373 * t + 243.451))
corr = corr + 0.171 * t * sin(dtr * (71998.746 * t + 240.98 ))
corr = corr + 0.027 * t * sin(dtr * ( 1222.114 * t + 194.661))
corr = corr + 0.027 * t * sin(dtr * ( 3034.906 * t + 336.061))
corr = corr + 0.026 * t * sin(dtr * ( -20.186 * t + 9.382))
corr = corr + 0.007 * t * sin(dtr * (29929.562 * t + 264.911))
corr = corr + 0.006 * t * sin(dtr * ( 150.678 * t + 59.775))
corr = corr + 0.005 * t * sin(dtr * ( 9037.513 * t + 256.025))
corr = corr + 0.043 * t * sin(dtr * (35999.373 * t + 151.121))
' convert corrections to days
corr = 0.000001 * corr / 86400.0
' TDB julian date
jdtdb = jdtt + corr
end sub
sub jd2str(jdutc)
' convert julian day to calendar date and UTC time
gdate (jdutc, cmonth, day, year)
print "calendar date ", month$(cmonth); " ", STR$(int(day)); " "; str$(year)
print " "
thr0 = 24.0 * (day - int(day))
thr = int(thr0)
tmin0 = 60.0 * (thr0 - thr)
tmin = int(tmin0)
tsec = 60.0 * (tmin0 - tmin)
' fix seconds and minutes for rollover
if (tsec >= 60.0) then
tsec = 0.0
tmin = tmin + 1.0
end if
' fix minutes for rollover
if (tmin >= 60.0) then
tmin = 0.0
thr = thr + 1.0
end if
print "UTC time ", str$(thr) + " hours " + str$(tmin) + " minutes " + str$(tsec, 0, 2) + " seconds"
end sub
sub findleap(jday, leapsecond)
' find number of leap seconds for utc julian day
' input
' jday = utc julian day
' input via global
' jdleap = array of utc julian dates
' leapsec = array of leap seconds
' output
' leapsecond = number of leap seconds
if (jday <= jdleap(1)) then
' date is <= 1972; set to first data element
leapsecond = leapsec(1)
exit sub
end if
if (jday >= jdleap(28)) then
' date is >= end of current data
' set to last data element
leapsecond = leapsec(28)
exit sub
end if
' find data within table
for i% = 1 to 27
if (jday >= jdleap(i%) and jday < jdleap(i% + 1)) then
leapsecond = leapsec(i%)
exit sub
end if
next i%
end sub
function modulo(x) as float
' modulo 2 pi function
local a
a = x - pi2 * fix(x / pi2)
if (a < 0.0) then
a = a + pi2
end if
modulo = a
end function
function atan3(a, b) as float
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' atan3 = angle (0 =< atan3 <= 2 * pi; radians)
local c
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
sub read_data
' read sun and planet data subroutine
for i% = 1 to 4
read body$(i%)
next i%
for i% = 1 to 50
read sl(i%), sr(i%), sa(i%), sb(i%)
next i%
for i% = 1 to 184
read cl(i%), al(i%), bl(i%)
next i%
data "Mercury","Venus","Sun/Earth","Mars"
' data for the sun - longitude and radius vector
data 403406, 0, 4.721964, 1.621043
data 195207, -97597, 5.937458, 62830.348067
data 119433, -59715, 1.115589, 62830.821524
data 112392, -56188, 5.781616, 62829.634302
data 3891, -1556, 5.5474 , 125660.5691
data 2819, -1126, 1.5120 , 125660.9845
data 1721, -861, 4.1897 , 62832.4766
data 0, 941, 1.163 , 0.813
data 660, -264, 5.415 , 125659.310
data 350, -163, 4.315 , 57533.850
data 334, 0, 4.553 , -33.931
data 314, 309, 5.198 , 777137.715
data 268, -158, 5.989 , 78604.191
data 242, 0, 2.911 , 5.412
data 234, -54, 1.423 , 39302.098
data 158, 0, 0.061 , -34.861
data 132, -93, 2.317 , 115067.698
data 129, -20, 3.193 , 15774.337
data 114, 0, 2.828 , 5296.670
data 99, -47, 0.52 , 58849.27
data 93, 0, 4.65 , 5296.11
data 86, 0, 4.35 , -3980.70
data 78, -33, 2.75 , 52237.69
data 72, -32, 4.50 , 55076.47
data 68, 0, 3.23 , 261.08
data 64, -10, 1.22 , 15773.85
data 46, -16, 0.14 , 188491.03
data 38, 0, 3.44 , -7756.55
data 37, 0, 4.37 , 264.89
data 32, -24, 1.14 , 117906.27
data 29, -13, 2.84 , 55075.75
data 28, 0, 5.96 , -7961.39
data 27, -9, 5.09 , 188489.81
data 27, 0, 1.72 , 2132.19
data 25, -17, 2.56 , 109771.03
data 24, -11, 1.92 , 54868.56
data 21, 0, 0.09 , 25443.93
data 21, 31, 5.98 , -55731.43
data 20, -10, 4.03 , 60697.74
data 18, 0, 4.27 , 2132.79
data 17, -12, 0.79 , 109771.63
data 14, 0, 4.24 , -7752.82
data 13, -5, 2.01 , 188491.91
data 13, 0, 2.65 , 207.81
data 13, 0, 4.98 , 29424.63
data 12, 0, 0.93 , -7.99
data 10, 0, 2.21 , 46941.14
data 10, 0, 3.59 , -68.29
data 10, 0, 1.50 , 21463.25
data 10, -9, 2.55 , 157208.40
' data for mercury - heliocentric longitude, latitude and radius vector
data 510728, 6.09670 , 521757.52364 , 404847, 4.72189, 1.62027
data 91048, 2.8946 , 782636.2744 , 30594, 4.1535 , 521758.6270
data 15769, 5.8003 , 1043515.073 , 13726, 0.4656 , 521756.9570
data 11582, 1.0266 , 782637.2016 , 7633, 3.517 , 521759.335
data 5247, 0.418 , 782638.007 , 4001, 3.993 , 1043516.352
data 3299, 2.791 , 1304393.680 , 3212, 0.209 , 1043514.724
data 1690, 2.067 , 1304394.627 , 1482, 6.174 , 1304395.168
data 1233, 3.606 , 782635.409 , 1152, 5.856 , 1565272.646
data 845, 2.63 , 1043516.88 , 654, 3.40 , 1565273.50
data 359, 2.66 , 1826151.56 , 356, 3.08 , 11094.77
data 257, 6.27 , 1826152.20 , 246, 2.89 , 5.41
data 180, 5.67 , 56613.61 , 159, 4.57 , 250285.49
data 137, 6.17 , 271973.50
data 680303, 3.82625 , 260879.17693 , 538354, 3.30009, 260879.66625
data 176935, 3.74070 , 0.40005 , 143323, 0.58073, 521757.92658
data 105214, 0.0545 , 521758.44880 , 91011, 3.3915 , 0.9954
data 47427, 1.9266 , 260878.2610 , 41669, 3.5084 , 782636.7624
data 19826, 3.1539 , 782637.4813 , 12963, 0.2455 , 1043515.6610
data 8233, 4.886 , 521756.972 , 6399, 0.358 , 782637.769
data 3196, 3.253 , 1304394.380 , 1536, 4.824 , 1043516.451
data 824, 0.04 , 1565273.15 , 819, 1.84 , 782635.45
data 324, 1.60 , 1304395.53 , 201, 2.92 , 1826151.86
data 780141, 6.202782, 260878.753962, 78942, 2.98062, 521757.50830
data 12000, 6.0391 , 782636.2640 , 9839, 4.8422 , 260879.3808
data 2355, 5.062 , 0.734 , 2019, 2.898 , 1043514.987
data 1974, 1.588 , 521758.140 , 1859, 0.805 , 260877.716
data 426, 4.601 , 782636.915 , 397, 5.976 , 1304393.735
data 382, 3.86 , 521756.47 , 306, 1.87 , 1043515.34
data 102, 0.62 , 782635.28 , 92, 2.60 , 1565272.52
' data for venus - heliocentric longitude, latitude and radius vector
data 423015, 4.722173, 1.600752, 548 , 5.987 , 78604.195
data 346, 4.27 , 117906.29 , 253 , 2.95 , 5.37
data 237, 4.56 , 39302.10 , 181 , 0.05 , 15774.33
data 153, 2.14 , 306400.25 , 144 , 5.73 , 96835.94
data 99, 0.09 , 261.08 , 98 , 6.18 , 306399.50
data 89, 4.34 , 15773.85 , 85 , 2.86 , 94378.51
data 69, 2.85 , 5296.67 , 56 , 5.71 , 1915.95
data 55, 1.23 , 264.89 , 55 , 2.85 , 7756.55
data 50, 5.69 , 157208.38 , 48 , 4.62 , 5296.12
data 43, 5.16 , 193671.89 , 39 , 0.85 , 94377.98
data 590350, 1.759897, 102133.735253, 34737, 3.17478, 102133.01934
data 13104, 0.2705 , 2.0678 , 12910, 3.7446 , 102134.2721
data 8591, 3.7878 , 1.5631 , 7015, 3.3730 , 2.2248
data 2101, 2.828 , 0.361 , 163, 2.85 , 78604.20
data 138, 1.13 , 117906.29 , 50, 2.59 , 96835.94
data 37, 1.42 , 39302.10
' data for mars - heliocentric longitude, latitude and radius vector
data 424067, 4.725053, 1.599646 , 117053, 0.92177, 66810.71641
data 31286, 5.17451 , 66811.55202 , 10248, 1.3885 , 100216.0920
data 4933, 1.4302 , 66813.4604 , 4130, 5.4976 , 100216.8648
data 2605, 1.382 , -33.896 , 1334, 3.104 , -34.791
data 1232, 2.420 , 28109.218 , 1180, 2.148 , 133621.421
data 959, 4.404 , 22813.140 , 827, 6.053 , 133621.745
data 778, 4.910 , 56218.431 , 692, 1.881 , 100218.894
data 667, 1.267 , -3980.684 , 416, 1.799 , 29424.634
data 354, 3.146 , 25443.942 , 341, 1.005 , 66815.503
data 339, 1.420 , 33371.351 , 310, 0.916 , -33439.371
data 294, 2.57 , 1915.95 , 260, 2.69 , -7961.45
data 245, 3.70 , 33370.81 , 242, 2.94 , 5.41
data 198, 2.78 , 5296.69 , 182, 3.09 , -33440.09
data 167, 4.28 , 17516.29 , 153, 2.72 , 61514.60
data 148, 5.27 , 22812.71 , 141, 4.51 , 21463.18
data 128, 1.06 , 100220.45 , 126, 5.19 , 50921.57
data 105, 0.77 , 5296.06 , 103, 5.26 , 89623.78
data 86, 3.97 , 29140.97 , 81, 5.38 , 1559.53
data 72, 0.90 , -37386.05 , 71, 5.23 , 10592.20
data 66, 2.06 , 31273.21 , 64, 4.49 , 84327.58
data 63, 1.43 , 167027.36 , 60, 1.77 , 133625.34
data 55, 4.02 , -7.37 , 55, 6.05 , 17482.57
data 47, 4.23 , -11942.07 , 45, 1.23 , 1914.57
data 43, 6.24 , -3981.49 , 43, 2.12 , 62829.99
data 42, 2.07 , 2131.89 , 38, 4.90 , -7962.27
data 36, 0.02 , 17514.95 , 33, 2.37 , 167026.02
data 31, 4.65 , 25443.27 , 31, 2.57 , 66776.76
data 30, 1.19 , -66844.78 , 30, 6.06 , 35321.38
data 30, 4.35 , 62546.28 , 29, 5.79 , 207.81
data 28, 1.17 , 13501.91 , 28, 2.09 , -31489.48
data 32962, 1.67255 , 1.77247 , 9705, 3.5531 , 0.9198
data 367, 0.353 , 133623.307 , 101, 4.74 , 133624.11
data 44, 0.94 , 33373.21 , 44, 2.83 , -33441.23
data 40, 0.42 , 167028.67
data 27946, 4.8846 , 0.4677 , 5147, 4.5968 , 100216.0535
data 2196, 2.568 , 100216.663 , 811, 5.560 , 28109.218
data 749, 1.772 , 56218.430 , 559, 5.112 , 133621.486
data 503, 1.272 , 22813.139 , 332, 2.701 , 133621.941
data 258, 4.56 , 33371.35 , 248, 4.93 , 29424.63
data 236, 0.92 , -33439.37 , 231, 0.09 , 25443.93
data 186, 0.56 , 33370.81 , 138, 3.09 , -33440.09
data 117, 2.11 , 50921.57 , 110, 1.27 , -3980.70
data 99, 5.84 , 61514.59 , 90, 4.41 , 5296.11
data 90, 5.64 , 167026.95 , 81, 2.10 , 10592.24
data 80, 2.83 , -7961.39 , 74, 1.50 , 21463.25
data 73, 1.25 , 84327.62 , 71, 2.86 , 167027.21
data 69, 2.10 , 22812.70 , 69, 2.13 , 89623.77
data 63, 1.29 , 17516.40 , 57, 0.83 , 29140.97
data 53, 0.90 , -37386.04
' calendar months
month$(1) = "January"
month$(2) = "February"
month$(3) = "March"
month$(4) = "April"
month$(5) = "May"
month$(6) = "June"
month$(7) = "July"
month$(8) = "August"
month$(9) = "September"
month$(10) = "October"
month$(11) = "November"
month$(12) = "December"
' read leap second data
for i% = 1 to 28
read jdleap(i%), leapsec(i%)
next i%
data 2441317.5, 10.0
data 2441499.5, 11.0
data 2441683.5, 12.0
data 2442048.5, 13.0
data 2442413.5, 14.0
data 2442778.5, 15.0
data 2443144.5, 16.0
data 2443509.5, 17.0
data 2443874.5, 18.0
data 2444239.5, 19.0
data 2444786.5, 20.0
data 2445151.5, 21.0
data 2445516.5, 22.0
data 2446247.5, 23.0
data 2447161.5, 24.0
data 2447892.5, 25.0
data 2448257.5, 26.0
data 2448804.5, 27.0
data 2449169.5, 28.0
data 2449534.5, 29.0
data 2450083.5, 30.0
data 2450630.5, 31.0
data 2451179.5, 32.0
data 2453736.5, 33.0
data 2454832.5, 34.0
DATA 2456109.5, 35.0
data 2457204.5, 36.0
data 2457754.5, 37.0
end sub
function vecmag(a())
' vector magnitude function
' input
' { a } = column vector ( 3 rows by 1 column )
' output
' vecmag = scalar magnitude of vector { a }
vecmag = sqr(a(1) * a(1) + a(2) * a(2) + a(3) * a(3))
end function
sub getdate (month, day, year)
' request calendar date subroutine
do
print " "
print "please input the calendar date"
print " "
print "(month [1 - 12], day [1 - 31], year [yyyy])"
print "< for example, october 21, 1986 is input as 10,21,1986 >"
print "< b.c. dates are negative, a.d. dates are positive >"
print "< the day of the month may also include a decimal part >"
print " "
input month, day, year
loop until (month >= 1 and month <= 12) and (day >= 1 and day <= 31)
end sub
sub getutc (thr, tmin, tsec)
' request time subroutine
do
print " "
print "please input the UTC time"
print " "
print "(hours [0 - 24], minutes [0 - 60], seconds [0 - 60])"
print " "
input thr, tmin, tsec
loop until ((thr >= 0.0 and thr <= 24.0) and (tmin >= 0.0 and tmin <= 60.0) and (tsec >= 0.0 and tsec <= 60.0))
end sub
https://drive.google.com/drive/folders/0Bx2YPzS0EoweUFR6ZHZ0cVpFWjA?usp=sharing
Frank N. Furter
Posted: 05:28am 12 Apr 2017
YEAH, THAT'S IT!!!!
Thank you very lot for sharing!!!
(...and now the outer Planets! )
Can you help me? How can I convert the heliocentric position vector to heliocentric coordinates???
THANKS!!!
Frank
cdeagle
Posted: 06:11am 12 Apr 2017
What type of heliocentric coordinates do you need to calculate?
Frank N. Furter
Posted: 08:51am 12 Apr 2017
Hi David,
thanks for your fast reply!
I need the coordinates as ecliptic coordinates, calculated from sun as midpoint with λ – ecliptic longitude from vernal equinox and β – ecliptic latitude...
Did you have a explanation (link) for your heliocentric position vector?
Thanks!
Frank
cdeagle
Posted: 02:37am 13 Apr 2017
Frank,
Each planet subroutine provides the ecliptic coordinates you need. For example
In the argument list, jdtdb is the barycentric dynamical time (TDB) Julian day, pl is the heliocentric ecliptic longitude in radians, pb is the heliocentric ecliptic latitude in radians and pr is the heliocentric distance in astronomical units.
The following subroutine computes the different position vectors. Note that the heliocentric rectangular position vector of the sun and planet are computed from the polar coordinates of the sun (sl, sr) and planet (pl, pb, pr).
xs = sr * cos(sl)
ys = sr * sin(sl)
zp = pr * sin(pb)
x = xp + xs
y = yp + ys
z = zp
gl = atan3(y, x)
end sub
Frank N. Furter
Posted: 08:11am 14 Apr 2017
Hi David,
thank you very much! I hope I get the Pi-cromite running on my Raspberry and will try your code!
Frank
zeitfest
Posted: 02:21am 18 Dec 2019
Just looked at the background of this ... amazing to see massive ephemerides etc crunchwork concisely condensed to fit to a picMX and basic ...   .
I am wondering, roughly what year does the epoch used range to ?
Plasmamac
Posted: 05:24pm 21 Dec 2019
i feel its great but i understand nothing.
Bahnhof Kofferklauen ?
Plasma
zeitfest
Posted: 09:13pm 28 Jan 2020
This is a quick coordinate
Converter   and a bit of intro I found useful
(I confess, to get more into astronomy I bought a mirror making kit a long time ago...and it is still in the carton..  )
Edited 2020-01-29 07:15 by zeitfest
Posted: 09:21pm 28 Jan 2020
And I have a 10 inch mirror gathering dust in the shed.
Last time I looked at it, it was a sad sight.
retepsnikrep
Posted: 05:07am 29 Jan 2020
  Plasmamac said  i feel its great but i understand nothing.
I agree brilliantly done but beyond normal mortals comprehension.
Does this give accurate enough results to get a probe to one of the planets??
Or would we whizz by a few miles off course?
Gen1 Honda Insights.
Posted: 09:52am 29 Jan 2020
Don't think I trust single precision on a micromite enough to find out   however the idea of taking great strides with tiny compute does appeal. I followed a couple of threads a few years back about autonomous boats (like model size) crossing the Atlantic to win a prize - don't think it has been collected yet but it is great to see these little micro-controllers with GPS and satellite trackers drifting off hundreds of miles all on their own - actually navigating with sails... tacking and everything.
h
Edited 2020-01-29 19:55 by CaptainBoing
Posted: 02:36pm 29 Jan 2020
  CaptainBoing said  I followed a couple of threads a few years back about autonomous boats (like model size) crossing the Atlantic to win a prize - don't think it has been collected yet
Microtransit  "The ninth transatlantic race was open during 2018 and early 2019. Four boats competed from: Sailbuoy, Epsom College, Dalhousie University and Gortobot. It saw the first successful completition of the competition by SB Met."
My wife and I followed with interest, since her son was in engineering at Dalhousie. Sadly, that one didn't make it. I had earlier followed Snoopy's efforts, as linked from the picaxe forum.
Edited 2020-01-30 00:37 by lizby
Posted: 05:16am 30 Jan 2020
yay! genuinely happy about that.
I think it was snoopy that got me into it - I think the "processor" was changed to a micromite from a picaxe and the posts here were really interesting. It is a major feat as unpowered boats of that size will really feel the wind and tides. It amazes me what people can do... even the "failures" are amazing - days at sea navigitaing and having to tac into the prevailing westerleys. Neither crossing is easy but the east-west attempt has got the odds stacked against it from the start. Sadly the Microtransat  challenge seems to have petered out (the registration page for 2019 is still open)... maybe contestants had the wind taken out of their sails   by it having been won.
I really appreciate the update coz I was interested but it sort of dropped of my radar. There was a similar thread about balloons doing a similar thing with LoRA modules for comms.
Edited 2020-01-30 15:36 by CaptainBoing
zeitfest
Posted: 11:42am 30 Jan 2020
Voyager  was the way to go...
I am still amazed, such exactitude that a remote spacecraft path can be set up to skim past Pluto for photos, or settle into precise orbit around Saturn, by using careful math.
