Local Time 00:53 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - apogee and perigee of the Moon
cdeagle
Posted: 10:02am 05 Apr 2017
This post describes a MicroMite eXtreme computer program that can be used to compute the circumstances of apogee and perigee of the Moon. Apogee corresponds to greatest distance from the Earth and perigee is the instant of closest approach to the Earth.
Here's a typical interaction with apmoon.bas and the computed results.
apogee and perigee of the moon
please input the calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 1,1,2017
please input the number of days to search
? 60
searching for apogee and perigee conditions ...
time and conditions at perigee
calendar date January 10 2017
UTC time 6 hours 0 minutes 53.82 seconds
UTC julian day 2457763.75062294
geocentric distance 363238.6560 kilometers
time and conditions at apogee
calendar date January 22 2017
UTC time 0 hours 13 minutes 47.68 seconds
UTC julian day 2457775.50957959
geocentric distance 404914.5482 kilometers
calendar date February 6 2017
UTC time 14 hours 2 minutes 8.54 seconds
UTC julian day 2457791.08482106
geocentric distance 368816.0306 kilometers
calendar date February 18 2017
UTC time 21 hours 13 minutes 47.53 seconds
UTC julian day 2457803.38457784
geocentric distance 404376.3116 kilometers
calendar date March 3 2017
UTC time 7 hours 33 minutes 5.70 seconds
UTC julian day 2457815.81464930
geocentric distance 369062.0120 kilometers
Here's the MMBASIC source code for this application.
' apmoon.bas April 5, 2017
' apogee and perigee of the moon
' Micromite eXtreme version
option default float
option base 1
' dimension global arrays and variables
dim jdleap(28), leapsec(28), xnut(11, 13)
dim month$(12) as string
dim trr, iap_flg%, jdtdbi
dim cmonth, cday, cyear, ndays
' global constants
const pi2 = 2.0 * pi, pidiv2 = 0.5 * pi, dtr = pi / 180.0, rtd = 180.0 / pi
const atr = pi / 648000.0, seccon = 206264.8062470964
' read subset of IAU2000 nutation data
for j% = 1 to 13
for i% = 1 to 11
read xnut(i%, j%)
next i%
next j%
data 0, 0, 0, 0, 1, -172064161, -174666, 92052331, 9086, 33386, 15377
data 0, 0, 2, -2, 2, -13170906, -1675, 5730336, -3015, -13696, -4587
data 0, 0, 2, 0, 2, -2276413, -234, 978459, -485, 2796, 1374
data 0, 0, 0, 0, 2, 2074554, 207, -897492, 470, -698, -291
data 0, 1, 0, 0, 0, 1475877, -3633, 73871, -184, 11817, -1924
data 0, 1, 2, -2, 2, -516821, 1226, 224386, -677, -524, -174
data 1, 0, 0, 0, 0, 711159, 73, -6750, 0, -872, 358
data 0, 0, 2, 0, 1, -387298, -367, 200728, 18, 380, 318
data 1, 0, 2, 0, 2, -301461, -36, 129025, -63, 816, 367
data 0, -1, 2, -2, 2, 215829, -494, -95929, 299, 111, 132
data 0, 0, 2, -2, 1, 128227, 137, -68982, -9, 181, 39
data -1, 0, 2, 0, 2, 123457, 11, -53311, 32, 19, -4
data -1, 0, 0, 2, 0, 156994, 10, -1235, 0, -168, 82
' read leap second data
for i% = 1 to 28
read jdleap(i%), leapsec(i%)
next i%
data 2441317.5, 10.0
data 2441499.5, 11.0
data 2441683.5, 12.0
data 2442048.5, 13.0
data 2442413.5, 14.0
data 2442778.5, 15.0
data 2443144.5, 16.0
data 2443509.5, 17.0
data 2443874.5, 18.0
data 2444239.5, 19.0
data 2444786.5, 20.0
data 2445151.5, 21.0
data 2445516.5, 22.0
data 2446247.5, 23.0
data 2447161.5, 24.0
data 2447892.5, 25.0
data 2448257.5, 26.0
data 2448804.5, 27.0
data 2449169.5, 28.0
data 2449534.5, 29.0
data 2450083.5, 30.0
data 2450630.5, 31.0
data 2451179.5, 32.0
data 2453736.5, 33.0
data 2454832.5, 34.0
DATA 2456109.5, 35.0
data 2457204.5, 36.0
data 2457754.5, 37.0
' calendar months
month$(1) = "January"
month$(2) = "February"
month$(3) = "March"
month$(4) = "April"
month$(5) = "May"
month$(6) = "June"
month$(7) = "July"
month$(8) = "August"
month$(9) = "September"
month$(10) = "October"
month$(11) = "November"
month$(12) = "December"
' begin simulation
print " "
print "apogee and perigee of the moon"
print "=============================="
' request initial calendar date (month, day, year)
getdate(cmonth, cday, cyear)
' initial utc julian day
julian(cmonth, cday, cyear, jdutc)
' compute initial tdb julian date
utc2tdb(jdutc, jdtdb)
jdtdbi = jdtdb
' request search duration (days)
print " "
print "please input the number of days to search"
input ndays
print " "
print "searching for apogee and perigee conditions ..."
print " "
' initialize apogee/perigee "flag"
iap_flg% = 1
' define search parameters
ti = 0.0
tf = ndays
tisaved = ti
dt = 1.0
dtsml = 0.1
' find moon rise/set conditions
ap_event(ti, tf, dt, dtsml)
end
sub ap_event (ti, tf, dt, dtsml)
' predict apogee/perigee events
' input
' ti = initial simulation time
' tf = final simulation time
' dt = step size used for bounding minima
' dtsml = small step size used to determine whether
' the function is increasing or decreasing
LOCAL tolm
local fmin1, tmin1
LOCAL ftemp, df, dflft
local el, er
LOCAL t, ft
local iter1%, iter2%, iter3%
' initialization
tolm = 1.0e-10
df = 1.0
for iter1% = 1 to 1000
' find where function first starts decreasing
for iter2% = 1 to 1000
if (df <= 0.0) then
exit for
end if
t = t + dt
ap_func(t, ft)
ap_func(t- dtsml, ftemp)
df = ft - ftemp
next iter2%
' function decreasing - find where function
' first starts increasing
for iter3% = 1 to 1000
el = t
dflft = df
t = t + dt
ap_func(t, ft)
ap_func(t - dtsml, ftemp)
df = ft - ftemp
if (df > 0.0) then exit for
next iter3%
er = t
' calculate minimum using Brent's method
minima(el, er, tolm, tmin1, fmin1)
el = er
' print current conditions
ap_print(tmin1)
if (t >= tf) then exit for
next iter1%
end sub
sub ap_func(x, fx)
' apogee/perigee objective function
local jdtdb, rmoon(3), srange
' current TDB julian day
jdtdb = jdtdbi + x
' compute eci position vector and distance of the moon
moon(jdtdb, rmoon())
srange = iap_flg% * vecmag(rmoon())
' current objective function
fx = srange
end sub
sub ap_print(topt)
' print apogee and perigee conditions
LOCAL jdutc, rmoon(3)
if (iap_flg% = 1) then
print " "
print "time and conditions at perigee"
print " "
else
print " "
print "time and conditions at apogee"
print "============================="
print " "
end if
' TDB julian day
jdtdb = jdtdbi + topt
' compute and display UTC julian date
tdb2utc(jdtdb, jdutc)
jd2str(jdutc)
PRINT " "
print "UTC julian day ", str$(jdutc, 0, 8)
PRINT " "
print "geocentric distance ", str$(vecmag(rmoon()), 0, 4), " kilometers"
print " "
' toggle type of event flag
iap_flg% = -iap_flg%
END sub
sub minima(a, b, tolm, xmin, fmin)
' one-dimensional minimization
' Brent's method
' input
' a = initial x search value
' b = final x search value
' tolm = convergence criterion
' output
' xmin = minimum x value
' note
' user-defined objective subroutine
' coded as ap_func(x, fx)
' remember: a maximum is simply a minimum
' with a negative attitude!
' machine epsilon
LOCAL epsm = 2.23e-16
' golden number
LOCAL c = 0.38196601125
LOCAL iter as integer, d, e
LOCAL t2, p, q
local r, u, fu
LOCAL x, xm, w
local v, fx, fw
LOCAL tol1, fv
x = a + c * (b - a)
w = x
v = w
e = 0.0
p = 0.0
q = 0.0
r = 0.0
ap_func(x, fx)
fw = fx
fv = fw
for iter = 1 to 100
if (iter > 50) then
print ("error in function minima!")
print ("(more than 50 iterations)")
end if
xm = 0.5 * (a + b)
tol1 = tolm * abs(x) + epsm
t2 = 2.0 * tol1
if (abs(x - xm) <= (t2 - 0.5 * (b - a))) then
xmin = x
fmin = fx
exit sub
end if
if (abs(e) > tol1) then
r = (x - w) * (fx - fv)
q = (x - v) * (fx - fw)
p = (x - v) * q - (x - w) * r
q = 2.0 * (q - r)
if (q > 0.0) then
p = -p
end if
q = abs(q)
r = e
e = d
end if
if ((abs(p) >= abs(0.5 * q * r)) or (p <= q * (a - x)) or (p >= q * (b - x))) then
if (x >= xm) then
e = a - x
else
e = b - x
end if
d = c * e
else
d = p / q
u = x + d
if ((u - a) < t2) or ((b - u) < t2) then
d = sgn(xm - x) * tol1
end if
end if
if (abs(d) >= tol1) then
u = x + d
else
u = x + sgn(d) * tol1
end if
ap_func(u, fu)
if (fu <= fx) then
if (u >= x) then
a = x
else
b = x
end if
v = w
fv = fw
w = x
fw = fx
x = u
fx = fu
else
if (u < x) then
a = u
else
b = u
end if
if ((fu <= fw) Or (w = x)) then
v = w
fv = fw
w = u
fw = fu
elseif ((fu <= fv) Or (v = x) Or (v = w)) then
v = u
fv = fu
end if
end if
next iter
end sub
sub tdb2utc (jdtdb, jdutc)
' convert TDB julian day to UTC julian day subroutine
' input
' jdtdb = TDB julian day
' output
' jdutc = UTC julian day
local x1, x2, xroot, froot
jdsaved = jdtdb
' set lower and upper bounds
x1 = jdsaved - 0.1
x2 = jdsaved + 0.1
' solve for UTC julian day using Brent's method
realroot(x1, x2, 1.0e-8, xroot, froot)
jdutc = xroot
end sub
sub jdfunc (jdin, fx)
' objective function for tdb2utc
' input
' jdin = current value for UTC julian day
' output
' fx = delta julian day
local jdwrk
utc2tdb(jdin, jdwrk)
fx = jdwrk - jdsaved
end sub
sub moon(jdate, rmoon())
' geocentric position of the moon subroutine
' input
' jdate = tdb julian day
' output
' rmoon = eci position vector of the moon (kilometers)
local t1, t2, t3
local t4, dpsi, deps
LOCAL ll, d, lp
local l, f, t
LOCAL ve, ma, ju
local rm, dv, pl
local plat, plon
LOCAL a, b
local rasc, decl, obliq
' get nutations and obliquity
obliq_lp(jdate, dpsi, deps, obliq)
' evaluate lunar ephemeris
t1 = (jdate - 2451545.0) / 36525.0
t2 = t1 * t1
t3 = t1 * t1 * t1
t4 = t1 * t1 * t1 * t1
' calculate fundamental arguments (radians)
ll = dtr * (218 + (18 * 60 + 59.95571) / 3600)
ll = modulo(ll + atr * (1732564372.83264 * t1 - 4.7763 * t2 + .006681 * t3 - 0.00005522 * t4))
d = dtr * (297 + (51 * 60 + .73512) / 3600)
d = modulo(d + atr * (1602961601.4603 * t1 - 5.8681 * t2 + .006595 * t3 - 0.00003184 * t4))
lp = dtr * (357 + (31 * 60 + 44.79306) / 3600)
lp = modulo(lp + atr * (129596581.0474 * t1 - .5529 * t2 + 0.000147 * t3))
l = dtr * (134 + (57 * 60 + 48.28096) / 3600)
l = modulo(l + atr * (1717915923.4728 * t1 + 32.3893 * t2 + .051651 * t3 - 0.0002447 * t4))
f = dtr * (93 + (16 * 60 + 19.55755) / 3600)
f = modulo(f + atr * (1739527263.0983 * t1 - 12.2505 * t2 - .001021 * t3 + 0.00000417 * t4))
t = dtr * (100 + (27 * 60 + 59.22059) / 3600)
t = modulo(t + atr * (129597742.2758 * t1 - .0202 * t2 + .000009 * t3 + 0.00000015 * t4))
ve = dtr * (181 + (58 * 60 + 47.28305) / 3600)
ve = modulo(ve + atr * 210664136.43355 * t1)
ma = dtr * (355 + (25 * 60 + 59.78866) / 3600)
ma = modulo(ma + atr * 68905077.59284 * t1)
ju = dtr * (34 + (21 * 60 + 5.34212) / 3600)
ju = modulo(ju + atr * 10925660.42861 * t1)
' compute geocentric distance (kilometers)
' a(c,0,r) series
rm = 385000.52899
rm = rm - 20905.35504 * sin(l + pidiv2)
rm = rm - 3699.11092 * sin(2 * d - l + pidiv2)
rm = rm - 2955.96756 * sin(2 * d + pidiv2)
rm = rm - 569.92512 * sin(2 * l + pidiv2)
rm = rm + 246.15848 * sin(2 * d - 2 * l + pidiv2)
rm = rm - 204.58598 * sin(2 * d - lp + pidiv2)
rm = rm - 170.73308 * sin(2 * d + l + pidiv2)
rm = rm - 152.13771 * sin(2 * d - lp - l + pidiv2)
rm = rm - 129.62014 * sin(lp - l + pidiv2)
rm = rm + 108.7427 * sin(d + pidiv2)
rm = rm + 104.75523 * sin(lp + l + pidiv2)
rm = rm + 79.66056 * sin(l - 2 * f + pidiv2)
rm = rm + 48.8883 * sin(lp + pidiv2)
rm = rm - 34.78252 * sin(4 * d - l + pidiv2)
rm = rm + 30.82384 * sin(2 * d + lp + pidiv2)
rm = rm + 24.20848 * sin(2 * d + lp - l + pidiv2)
rm = rm - 23.21043 * sin(3 * l + pidiv2)
rm = rm - 21.63634 * sin(4 * d - 2 * l + pidiv2)
rm = rm - 16.67471 * sin(d + lp + pidiv2)
rm = rm + 14.40269 * sin(2 * d - 3 * l + pidiv2)
rm = rm - 12.8314 * sin(2 * d - lp + l + pidiv2)
rm = rm - 11.64995 * sin(4 * d + pidiv2)
rm = rm - 10.44476 * sin(2 * d + 2 * l + pidiv2)
rm = rm + 10.32111 * sin(2 * d - 2 * f + pidiv2)
rm = rm + 10.0562 * sin(2 * d - lp - 2 * l + pidiv2)
rm = rm - 9.88445 * sin(2 * d - 2 * lp + pidiv2)
rm = rm + 8.75156 * sin(2 * d - l - 2 * f + pidiv2)
rm = rm - 8.37911 * sin(d - l + pidiv2)
rm = rm - 7.00269 * sin(lp - 2 * l + pidiv2)
rm = rm + 6.322 * sin(d + l + pidiv2)
rm = rm + 5.75085 * sin(lp + 2 * l + pidiv2)
rm = rm - 4.95013 * sin(2 * d - 2 * lp - l + pidiv2)
rm = rm - 4.42118 * sin(2 * l - 2 * f + pidiv2)
rm = rm + 4.13111 * sin(2 * d + l - 2 * f + pidiv2)
rm = rm - 3.95798 * sin(4 * d - lp - l + pidiv2)
rm = rm + 3.25824 * sin(3 * d - l + pidiv2)
rm = rm - 3.1483 * sin(2 * f + pidiv2)
rm = rm + 2.61641 * sin(2 * d + lp + l + pidiv2)
rm = rm + 2.35363 * sin(2 * d + 2 * lp - l + pidiv2)
rm = rm - 2.11713 * sin(2 * lp - l + pidiv2)
rm = rm - 1.89704 * sin(4 * d - lp - 2 * l + pidiv2)
rm = rm - 1.73853 * sin(d - 2 * l + pidiv2)
rm = rm - 1.57139 * sin(4 * d - lp + pidiv2)
rm = rm - 1.42255 * sin(4 * d + l + pidiv2)
rm = rm - 1.41893 * sin(3 * d + pidiv2)
rm = rm + 1.16553 * sin(2 * lp + l + pidiv2)
rm = rm - 1.11694 * sin(4 * l + pidiv2)
rm = rm + 1.06567 * sin(2 * lp + pidiv2)
rm = rm - .93332 * sin(d + lp + l + pidiv2)
rm = rm + .86243 * sin(3 * d - 2 * l + pidiv2)
rm = rm + .85124 * sin(d + lp - l + pidiv2)
rm = rm - .8488 * sin(2 * d - lp + 2 * l + pidiv2)
rm = rm - .79563 * sin(d - 2 * f + pidiv2)
rm = rm + .77854 * sin(2 * d - 4 * l + pidiv2)
rm = rm + .77404 * sin(2 * d - 2 * l + 2 * f + pidiv2)
rm = rm - .66968 * sin(2 * d + 3 * l + pidiv2)
rm = rm - .65753 * sin(2 * d - 2 * lp + l + pidiv2)
rm = rm + .65706 * sin(2 * d - lp - 2 * f + pidiv2)
rm = rm + .59632 * sin(2 * d - l + 2 * f + pidiv2)
rm = rm + .57879 * sin(4 * d + lp - l + pidiv2)
rm = rm - .51423 * sin(4 * d - 3 * l + pidiv2)
rm = rm - .50792 * sin(4 * d - 2 * f + pidiv2)
rm = rm + .49755 * sin(d - lp + pidiv2)
rm = rm + .49504 * sin(2 * d - lp - 3 * l + pidiv2)
rm = rm + .47262 * sin(2 * d - 2 * l - 2 * f + pidiv2)
rm = rm - .4225 * sin(6 * d - 2 * l + pidiv2)
rm = rm - .42241 * sin(lp - 3 * l + pidiv2)
rm = rm - .41071 * sin(2 * d - 3 * lp + pidiv2)
rm = rm + .37852 * sin(d + 2 * l + pidiv2)
rm = rm + .35508 * sin(lp + 3 * l + pidiv2)
rm = rm + .34302 * sin(2 * d - 2 * lp - 2 * l + pidiv2)
rm = rm + .33463 * sin(lp - l + 2 * f + pidiv2)
rm = rm + .33225 * sin(d + lp - 2 * l + pidiv2)
rm = rm + .32334 * sin(2 * d - lp - l - 2 * f + pidiv2)
rm = rm - .32176 * sin(4 * d - l - 2 * f + pidiv2)
rm = rm - .28663 * sin(6 * d - l + pidiv2)
rm = rm + .28399 * sin(2 * d + 2 * l - 2 * f + pidiv2)
rm = rm - .27904 * sin(4 * d - 2 * lp - l + pidiv2)
rm = rm + .2556 * sin(3 * d - lp - l + pidiv2)
rm = rm - .2481 * sin(lp + l - 2 * f + pidiv2)
rm = rm + .24452 * sin(4 * d + lp + pidiv2)
rm = rm + .23695 * sin(4 * d + lp - 2 * l + pidiv2)
rm = rm - .21258 * sin(3 * d + lp - l + pidiv2)
rm = rm + .21251 * sin(2 * d + lp + 2 * l + pidiv2)
rm = rm + .20941 * sin(2 * d - lp + l - 2 * f + pidiv2)
rm = rm - .20285 * sin(4 * d - lp + l + pidiv2)
rm = rm + .20099 * sin(3 * d - 2 * f + pidiv2)
rm = rm - .18567 * sin(lp - 2 * f + pidiv2)
rm = rm - .18316 * sin(6 * d - 3 * l + pidiv2)
rm = rm + .16857 * sin(2 * d + lp - 3 * l + pidiv2)
rm = rm - .15802 * sin(lp + 2 * f + pidiv2)
rm = rm - .15707 * sin(3 * d - lp + pidiv2)
rm = rm - .14806 * sin(2 * d - 3 * lp - l + pidiv2)
rm = rm + .14763 * sin(2 * d + 2 * lp + pidiv2)
rm = rm + .14368 * sin(2 * d + lp - 2 * l + pidiv2)
rm = rm - .13922 * sin(4 * d + 2 * l + pidiv2)
rm = rm - .13617 * sin(2 * lp - 2 * l + pidiv2)
rm = rm - .13571 * sin(2 * d + lp - 2 * f + pidiv2)
rm = rm - .12805 * sin(4 * d - 2 * lp + pidiv2)
rm = rm + .11411 * sin(d - lp - l + pidiv2)
rm = rm + .10998 * sin(d - lp + l + pidiv2)
rm = rm - .10887 * sin(2 * d + 2 * lp - 2 * l + pidiv2)
rm = rm - .10833 * sin(4 * d - 2 * lp - 2 * l + pidiv2)
rm = rm - .10766 * sin(3 * d + lp + pidiv2)
rm = rm - .10326 * sin(l + 2 * f + pidiv2)
rm = rm - .09938 * sin(d - 3 * l + pidiv2)
rm = rm - .08587 * sin(6 * d + pidiv2)
rm = rm - .07982 * sin(4 * d - 2 * l - 2 * f + pidiv2)
rm = rm - 6.678e-02 * sin(6 * d - lp - 2 * l + pidiv2)
rm = rm - 6.545e-02 * sin(3 * d + l + pidiv2)
rm = rm + .06055 * sin(d + l - 2 * f + pidiv2)
rm = rm - .05904 * sin(d + lp + 2 * l + pidiv2)
rm = rm - .05888 * sin(5 * l + pidiv2)
rm = rm - .0585 * sin(2 * d - lp + 3 * l + pidiv2)
rm = rm - .05789 * sin(4 * d - lp - 2 * f + pidiv2)
rm = rm - .05527 * sin(2 * d + lp + l - 2 * f + pidiv2)
rm = rm + .05293 * sin(3 * d - lp - 2 * l + pidiv2)
rm = rm - .05191 * sin(6 * d - lp - l + pidiv2)
rm = rm + .05072 * sin(2 * lp + 2 * l + pidiv2)
rm = rm - .0502 * sin(lp - 2 * l + 2 * f + pidiv2)
rm = rm - .04843 * sin(3 * d - 3 * l + pidiv2)
rm = rm + .0474 * sin(2 * d - 5 * l + pidiv2)
rm = rm - .04736 * sin(2 * d + lp - l - 2 * f + pidiv2)
rm = rm - .04608 * sin(2 * d - 2 * lp + 2 * l + pidiv2)
rm = rm + .04591 * sin(5 * d - 2 * l + pidiv2)
rm = rm - .04422 * sin(2 * d + 4 * l + pidiv2)
rm = rm - .04316 * sin(4 * d - lp - 3 * l + pidiv2)
rm = rm - .04232 * sin(d - l - 2 * f + pidiv2)
rm = rm - .03894 * sin(3 * lp - l + pidiv2)
rm = rm + .0381 * sin(3 * d + lp - 2 * l + pidiv2)
rm = rm + .03734 * sin(2 * d - lp - l + 2 * f + pidiv2)
rm = rm + .03729 * sin(d + 2 * lp + pidiv2)
rm = rm + .03682 * sin(4 * d + lp + l + pidiv2)
rm = rm + .03379 * sin(d + lp - 2 * f + pidiv2)
rm = rm + .03265 * sin(lp + 2 * l - 2 * f + pidiv2)
rm = rm + .03143 * sin(2 * d + 2 * f + pidiv2)
rm = rm + .03024 * sin(2 * d - lp - 2 * l + 2 * f + pidiv2)
rm = rm - .02948 * sin(d - 2 * lp + pidiv2)
rm = rm - .02939 * sin(4 * d - 4 * l + pidiv2)
rm = rm + .0291 * sin(2 * d - 3 * l - 2 * f + pidiv2)
rm = rm - .02855 * sin(2 * d - 3 * lp + l + pidiv2)
rm = rm + .02839 * sin(2 * d - 2 * lp - 2 * f + pidiv2)
rm = rm - .02698 * sin(4 * d - lp - l - 2 * f + pidiv2)
rm = rm - .02674 * sin(lp - 4 * l + pidiv2)
rm = rm + .02658 * sin(4 * d + 2 * lp - 2 * l + pidiv2)
rm = rm - .02471 * sin(d - l + 2 * f + pidiv2)
rm = rm - .02436 * sin(6 * d - lp - 3 * l + pidiv2)
rm = rm - .02399 * sin(4 * d + lp - 3 * l + pidiv2)
rm = rm + .02368 * sin(d + 3 * l + pidiv2)
rm = rm + .02334 * sin(2 * d - lp - 4 * l + pidiv2)
rm = rm + .02304 * sin(lp + 4 * l + pidiv2)
rm = rm + .02127 * sin(3 * lp + pidiv2)
rm = rm - .02079 * sin(4 * d - lp + 2 * l + pidiv2)
rm = rm - .02008 * sin(2 * d - 3 * l + 2 * f + pidiv2)
' a(p,0,r) series
rm = rm + 1.0587 * sin(2 * t - 2 * ju + 2 * d - l + 90.11969000000001 * dtr)
rm = rm + .72783 * sin(18 * ve - 16 * t - 2 * l + 116.54311 * dtr)
rm = rm + .68256 * sin(18 * ve - 16 * t + 296.54574 * dtr)
rm = rm + .59827 * sin(3 * ve - 3 * t + 2 * d - l + 89.98187 * dtr)
rm = rm + .45648 * sin(ll + l - f + 270.00126 * dtr)
rm = rm + .45276 * sin(ll - l - f + 90.00128 * dtr)
rm = rm + .41011 * sin(2 * t - 3 * ju + 2 * d - l + 280.06924 * dtr)
rm = rm + .20497 * sin(t - ju - 2 * d + 91.79862 * dtr)
rm = rm + .20473 * sin(18 * ve - 16 * t - 2 * d - l + 116.54222 * dtr)
rm = rm + .20367 * sin(18 * ve - 16 * t + 2 * d - l + 296.54299 * dtr)
rm = rm + .16644 * sin(2 * ve - 2 * t - 2 * d + 90.36386 * dtr)
rm = rm + .1578 * sin(4 * t - 8 * ma + 3 * ju + l + 194.98833 * dtr)
rm = rm + .1578 * sin(4 * t - 8 * ma + 3 * ju - l + 14.98841 * dtr)
rm = rm + .15751 * sin(t - ju - 2 * d + l + 91.74578 * dtr)
rm = rm + .1445 * sin(2 * t - 2 * ju - l + 89.97863 * dtr)
rm = rm + .13811 * sin(ve - t - l + 270.00993 * dtr)
rm = rm + .13477 * sin(18 * ve - 16 * t - 2 * d + 116.53978 * dtr)
rm = rm + .12671 * sin(18 * ve - 16 * t + 2 * d - 2 * l + 296.54238 * dtr)
rm = rm + .12666 * sin(t - ju - l + 91.22751 * dtr)
rm = rm + .12362 * sin(ve - t - 2 * d + 269.98523 * dtr)
rm = rm + .12047 * sin(2 * ve - 2 * t + 2 * d - l + 269.99692 * dtr)
rm = rm + .11998 * sin(ve - t + l + 90.01606 * dtr)
rm = rm + .11617 * sin(2 * ve - 2 * t - 2 * d + l + 90.31081 * dtr)
rm = rm + .11256 * sin(4 * t - 8 * ma + 3 * ju + 2 * d - l + 197.11421 * dtr)
rm = rm + .11251 * sin(4 * t - 8 * ma + 3 * ju - 2 * d + l + 17.11263 * dtr)
rm = rm + .11226 * sin(4 * t - 8 * ma + 3 * ju + 2 * d + 196.69224 * dtr)
rm = rm + .11216 * sin(4 * t - 8 * ma + 3 * ju - 2 * d + 16.68897 * dtr)
rm = rm + .10689 * sin(ll + 2 * d - f + 270.00092 * dtr)
rm = rm + .10504 * sin(t - ju + l + 271.06726 * dtr)
rm = rm + .1006 * sin(ve - t - 2 * d + l + 269.98452 * dtr)
rm = rm + 9.932e-02 * sin(3 * ve - 3 * t - l + 90.1054 * dtr)
rm = rm + .09554 * sin(ll - 2 * d - f + 90.00096 * dtr)
rm = rm + .08508 * sin(ll - f + 270.00061 * dtr)
rm = rm + 7.9450e-02 * sin(4 * ve - 4 * t + 2 * d - l + 89.99224 * dtr)
rm = rm + .07725 * sin(2 * t - 3 * ju - l + 280.16516 * dtr)
rm = rm + 7.054e-02 * sin(6 * ve - 8 * t + 2 * d - l + 77.22087 * dtr)
rm = rm + 6.313e-02 * sin(2 * ju - 5 * l + l + 256.56163 * dtr)
' a(p,1,r) series
rm = rm + .51395 * t1 * sin(2 * d - lp + pidiv2)
rm = rm + .38245 * t1 * sin(2 * d - lp - l + pidiv2)
rm = rm + .32654 * t1 * sin(lp - l + pidiv2)
rm = rm + .26396 * t1 * sin(lp + l + 270 * dtr)
rm = rm + .12302 * t1 * sin(lp + 270 * dtr)
rm = rm + .07754 * t1 * sin(2 * d + lp + 270 * dtr)
rm = rm + .06068 * t1 * sin(2 * d + lp - l + 270 * dtr)
rm = rm + .0497 * t1 * sin(2 * d - 2 * lp + pidiv2)
rm = rm + .04194 * t1 * sin(d + lp + pidiv2)
rm = rm + .03222 * t1 * sin(2 * d - lp + l + pidiv2)
rm = rm + .02529 * t1 * sin(2 * d - lp - 2 * l + 270 * dtr)
rm = rm + .0249 * t1 * sin(2 * d - 2 * lp - l + pidiv2)
rm = rm + .00149 * t2 * sin(2 * d - lp + pidiv2)
rm = rm + .00111 * t2 * sin(2 * d - lp - l + pidiv2)
rmm = rm
' compute geocentric ecliptic longitude (arc seconds)
' a(c,0,v) series
dv = 22639.58578 * sin(l)
dv = dv + 4586.4383 * sin(2 * d - l)
dv = dv + 2369.91394 * sin(2 * d)
dv = dv + 769.02571 * sin(2 * l)
dv = dv - 666.4171 * sin(lp)
dv = dv - 411.59567 * sin(2 * f)
dv = dv + 211.65555 * sin(2 * d - 2 * l)
dv = dv + 205.43582 * sin(2 * d - lp - l)
dv = dv + 191.9562 * sin(2 * d + l)
dv = dv + 164.72851 * sin(2 * d - lp)
dv = dv - 147.32129 * sin(lp - l)
dv = dv - 124.98812 * sin(d)
dv = dv - 109.38029 * sin(lp + l)
dv = dv + 55.17705 * sin(2 * d - 2 * f)
dv = dv - 45.0996 * sin(l + 2 * f)
dv = dv + 39.53329 * sin(l - 2 * f)
dv = dv + 38.42983 * sin(4 * d - l)
dv = dv + 36.12381 * sin(3 * l)
dv = dv + 30.77257 * sin(4 * d - 2 * l)
dv = dv - 28.39708 * sin(2 * d + lp - l)
dv = dv - 24.35821 * sin(2 * d + lp)
dv = dv - 18.58471 * sin(d - l)
dv = dv + 17.95446 * sin(d + lp)
dv = dv + 14.53027 * sin(2 * d - lp + l)
dv = dv + 14.3797 * sin(2 * d + 2 * l)
dv = dv + 13.89906 * sin(4 * d)
dv = dv + 13.19406 * sin(2 * d - 3 * l)
dv = dv - 9.67905 * sin(lp - 2 * l)
dv = dv - 9.36586 * sin(2 * d - l + 2 * f)
dv = dv + 8.60553 * sin(2 * d - lp - 2 * l)
dv = dv - 8.45310 * sin(d + l)
dv = dv + 8.05016 * sin(2 * d - 2 * lp)
dv = dv - 7.63015 * sin(lp + 2 * l)
dv = dv - 7.44749 * sin(2 * lp)
dv = dv + 7.37119 * sin(2 * d - 2 * lp - l)
dv = dv - 6.38315 * sin(2 * d + l - 2 * f)
dv = dv - 5.74161 * sin(2 * d + 2 * f)
dv = dv + 4.37401 * sin(4 * d - lp - l)
dv = dv - 3.99761 * sin(2 * l + 2 * f)
dv = dv - 3.20969 * sin(3 * d - l)
dv = dv - 2.91454 * sin(2 * d + lp + l)
dv = dv + 2.73189 * sin(4 * d - lp - 2 * l)
dv = dv - 2.56794 * sin(2 * lp - l)
dv = dv - 2.5212 * sin(2 * d + 2 * lp - l)
dv = dv + 2.48889 * sin(2 * d + lp - 2 * l)
dv = dv + 2.14607 * sin(2 * d - lp - 2 * f)
dv = dv + 1.97773 * sin(4 * d + l)
dv = dv + 1.93368 * sin(4 * l)
dv = dv + 1.87076 * sin(4 * d - lp)
dv = dv - 1.75297 * sin(d - 2 * l)
dv = dv - 1.43716 * sin(2 * d + lp - 2 * f)
dv = dv - 1.37257 * sin(2 * l - 2 * f)
dv = dv + 1.26182 * sin(d + lp + l)
dv = dv - 1.22412 * sin(3 * d - 2 * l)
dv = dv + 1.18683 * sin(4 * d - 3 * l)
dv = dv + 1.177 * sin(2 * d - lp + 2 * l)
dv = dv - 1.16169 * sin(2 * lp + l)
dv = dv + 1.07769 * sin(d + lp - l)
dv = dv + 1.0595 * sin(2 * d + 3 * l)
dv = dv - .99022 * sin(2 * d + l + 2 * f)
dv = dv + .94828 * sin(2 * d - 4 * l)
dv = dv + .75168 * sin(2 * d - 2 * lp + l)
dv = dv - .66938 * sin(lp - 3 * l)
dv = dv - .63521 * sin(4 * d + lp - l)
dv = dv - .58399 * sin(d + 2 * l)
dv = dv - .58331 * sin(d - 2 * f)
dv = dv + .57156 * sin(6 * d - 2 * l)
dv = dv - .56064 * sin(2 * d - 2 * l - 2 * f)
dv = dv - .55692 * sin(d - lp)
dv = dv - .54592 * sin(lp + 3 * l)
dv = dv - .53571 * sin(2 * d - 2 * l + 2 * f)
dv = dv + .4784 * sin(2 * d - lp - 3 * f)
dv = dv - .45379 * sin(2 * d + 2 * l - 2 * f)
dv = dv - .42622 * sin(2 * d - lp - l + 2 * f)
dv = dv + .42033 * sin(4 * f)
dv = dv + .4134 * sin(lp + 2 * f)
dv = dv + .40423 * sin(3 * d)
dv = dv + .39451 * sin(6 * d - l)
dv = dv - .38213 * sin(2 * d - lp + 2 * f)
dv = dv - .37451 * sin(2 * d - lp + l - 2 * f)
dv = dv - .35758 * sin(4 * d + lp - 2 * l)
dv = dv + .34965 * sin(d + lp - 2 * l)
dv = dv + .33979 * sin(2 * d - 3 * lp)
dv = dv - .32866 * sin(3 * l + 2 * f)
dv = dv + .30872 * sin(4 * d - 2 * lp - l)
dv = dv + .30155 * sin(lp - l - 2 * f)
dv = dv + .30086 * sin(4 * d - l - 2 * f)
dv = dv + .2942 * sin(2 * d - 2 * lp - 2 * l)
dv = dv + .29255 * sin(6 * d - 3 * l)
dv = dv - .29022 * sin(2 * d + lp + 2 * l)
' a(p,2,v) series
dv = dv + .00487 * t2 * sin(lp)
dv = dv - .0015 * t2 * sin(2 * d - lp - l + pi)
dv = dv - .0012 * t2 * sin(2 * d - lp + pi)
dv = dv + .00108 * t2 * sin(lp - l)
dv = dv + .0008 * t2 * sin(lp + l)
' a(p,0,v) series
dv = dv + 14.24883 * sin(18 * ve - 16 * t - l + dtr * 26.54261)
dv = dv + 7.06304 * sin(ll - f + dtr * .00094)
dv = dv + 1.14307 * sin(2 * t - 2 * ju + 2 * d - l + dtr * 180.11977)
dv = dv + .901140 * sin(4 * t - 8 * ma + 3 * ju + dtr * 285.98707)
dv = dv + .82155 * sin(ve - t + dtr * 180.00988)
dv = dv + .78811 * sin(18 * ve - 16 * t - 2 * l + dtr * 26.54324)
dv = dv + .7393 * sin(18 * ve - 16 * t + dtr * 26.5456)
dv = dv + .64371 * sin(3 * ve - 3 * t + 2 * d - l + dtr * 179.98144)
dv = dv + .6388 * sin(t - ju + dtr * 1.2289)
dv = dv + .56341 * sin(10 * ve - 3 * t - l + dtr * 333.30551)
dv = dv + .49331 * sin(ll + l - f + .00127 * dtr)
dv = dv + .49141 * sin(ll - l - f + .00127 * dtr)
dv = dv + .44532 * sin(2 * t - 3 * ju + 2 * d - l + 10.07001 * dtr)
dv = dv + .36061 * sin(ll + f + .00071 * dtr)
dv = dv + .34355 * sin(2 * ve - 3 * t + 269.95393 * dtr)
dv = dv + .32455 * sin(t - 2 * ma + 318.13776 * dtr)
dv = dv + .30155 * sin(2 * ve - 2 * t + .20448 * dtr)
dv = dv + .28938 * sin(t + d - f + 95.13523 * dtr)
dv = dv + .28281 * sin(2 * t - 3 * ju + 2 * d - 2 * l + 10.03835 * dtr)
dv = dv + .24515 * sin(2 * t - 2 * ju + 2 * d - 2 * l + .08642 * dtr)
' a(p,1,v) series
dv = dv + 1.6768 * t1 * sin(lp)
dv = dv + .51642 * t1 * sin(2 * d - lp - l + pi)
dv = dv + .41383 * t1 * sin(2 * d - lp + pi)
dv = dv + .37115 * t1 * sin(lp - l)
dv = dv + .2756 * t1 * sin(lp + l)
dv = dv + .25425 * t1 * sin(18 * ve - 16 * t - l + 114.5655 * dtr)
dv = dv + 7.1178e-02 * t1 * sin(2 * d + lp - l)
dv = dv + .06128 * t1 * sin(2 * d + lp)
dv = dv + .04516 * t1 * sin(d + lp + pi)
dv = dv + .04048 * t1 * sin(2 * d - 2 * lp + pi)
dv = dv + .03747 * t1 * sin(2 * lp)
dv = dv + .03707 * t1 * sin(2 * d - 2 * lp - l + pi)
dv = dv + .03649 * t1 * sin(2 * d - lp + l + pi)
dv = dv + .02438 * t1 * sin(lp - 2 * l)
dv = dv + .02165 * t1 * sin(2 * d - lp - 2 * l + pi)
dv = dv + .01923 * t1 * sin(lp + 2 * l)
plon = modulo(ll + atr * dv + dpsi)
' compute geocentric ecliptic latitude (arc seconds)
' a(c,0,u) series
pl = 18461.23868 * sin(f)
pl = pl + 1010.16707 * sin(l + f)
pl = pl + 999.69358 * sin(l - f)
pl = pl + 623.65243 * sin(2 * d - f)
pl = pl + 199.48374 * sin(2 * d - l + f)
pl = pl + 166.5741 * sin(2 * d - l - f)
pl = pl + 117.26069 * sin(2 * d + f)
pl = pl + 61.91195 * sin(2 * l + f)
pl = pl + 33.3572 * sin(2 * d + l - f)
pl = pl + 31.75967 * sin(2 * l - f)
pl = pl + 29.57658 * sin(2 * d - lp - f)
pl = pl + 15.56626 * sin(2 * d - 2 * l - f)
pl = pl + 15.12155 * sin(2 * d + l + f)
pl = pl - 12.09414 * sin(2 * d + lp - f)
pl = pl + 8.86814 * sin(2 * d - lp - l + f)
pl = pl + 7.95855 * sin(2 * d - lp + f)
pl = pl + 7.43455 * sin(2 * d - lp - l - f)
pl = pl - 6.73143 * sin(lp - l - f)
pl = pl + 6.57957 * sin(4 * d - l - f)
pl = pl - 6.46007 * sin(lp + f)
pl = pl - 6.29648 * sin(3 * f)
pl = pl - 5.63235 * sin(lp - l + f)
pl = pl - 5.3684 * sin(d + f)
pl = pl - 5.31127 * sin(lp + l + f)
pl = pl - 5.07591 * sin(lp + l - f)
pl = pl - 4.83961 * sin(lp - f)
pl = pl - 4.80574 * sin(d - f)
pl = pl + 3.98405 * sin(3 * l + f)
pl = pl + 3.67446 + sin(4 * d - f)
pl = pl + 2.99848 * sin(4 * d - l + f)
pl = pl + 2.79864 * sin(l - 3 * f)
pl = pl + 2.41388 * sin(4 * d - 2 * l + f)
pl = pl + 2.18631 * sin(2 * d - 3 * f)
pl = pl + 2.14617 * sin(2 * d + 2 * l - f)
pl = pl + 1.76598 * sin(2 * d - lp + l - f)
pl = pl - 1.62442 * sin(2 * d - 2 * l + f)
pl = pl + 1.5813 * sin(3 * l - f)
pl = pl + 1.51975 * sin(2 * d + 2 * l + f)
pl = pl - 1.51563 * sin(2 * d - 3 * l - f)
pl = pl - 1.31782 * sin(2 * d + lp - l + f)
pl = pl - 1.26427 * sin(2 * d + lp + f)
pl = pl + 1.19187 * sin(4 * d + f)
pl = pl + 1.13461 * sin(2 * d - lp + l + f)
pl = pl + 1.08578 * sin(2 * d - 2 * lp - f)
pl = pl - 1.01938 * sin(l + 3 * f)
pl = pl - .822710 * sin(2 * d + lp + l - f)
pl = pl + .80422 * sin(d + lp - f)
pl = pl + .80259 * sin(d + lp + f)
pl = pl - .79319 * sin(lp - 2 * l - f)
pl = pl - .79101 * sin(2 * d + lp - l - f)
pl = pl - .66741 * sin(d + l + f)
pl = pl + .65022 * sin(2 * d - lp - 2 * l - f)
pl = pl - .63881 * sin(lp + 2 * l + f)
pl = pl + .63371 * sin(4 * d - 2 * l - f)
pl = pl + .59577 * sin(4 * d - lp - l - f)
pl = pl - .58893 * sin(d + l - f)
pl = pl + .47338 * sin(4 * d + l - f)
pl = pl - .42989 * sin(d - l - f)
pl = pl + .41494 * sin(4 * d - lp - f)
pl = pl + .3835 * sin(2 * d - 2 * lp + f)
pl = pl - .35183 * sin(3 * d - f)
pl = pl + .33881 * sin(4 * d - lp - l + f)
pl = pl + .32906 * sin(2 * d - l - 3 * f)
' a(p,0,u) series
pl = pl + 8.04508 * sin(ll + 180.00071 * dtr)
pl = pl + 1.51021 * sin(t + d + 276.68007 * dtr)
pl = pl + .63037 * sin(18 * ve - 16 * t - l + f + 26.54287 * dtr)
pl = pl + .63014 * sin(18 * ve - 16 * t - l - f + 26.54272 * dtr)
pl = pl + .45586 * sin(ll - l + .00075 * dtr)
pl = pl + .41571 * sin(ll + l + 180.00069 * dtr)
pl = pl + .32622 * sin(ll - 2 * f + .00086 * dtr)
pl = pl + .29854 * sin(ll - 2 * d + .00072 * dtr)
' a(p,1,u) series
pl = pl + .0743 * t1 * sin(2 * d - lp - f + pi)
pl = pl + .03043 * t1 * sin(2 * d + lp - f)
pl = pl + .02229 * t1 * sin(2 * d - lp - l + f + pi)
pl = pl + .01999 * t1 * sin(2 * d - lp + f + pi)
pl = pl + .01869 * t1 * sin(2 * d - lp - l - f + pi)
pl = pl + .01696 * t1 * sin(lp - l - f)
pl = pl + .01623 * t1 * sin(lp + f)
plat = atr * pl
' compute geocentric right ascension and declination
a = sin(plon) * cos(obliq) - tan(plat) * sin(obliq)
b = cos(plon)
rasc = atan3(a, b)
decl = asin(sin(plat) * cos(obliq) + cos(plat) * sin(obliq) * sin(plon))
' compute the geocentric position vector of the moon (kilometers)
rmoon(1) = rmm * cos(rasc) * cos(decl)
rmoon(2) = rmm * sin(rasc) * cos(decl)
rmoon(3) = rmm * sin(decl)
end sub
sub realroot(x1, x2, tol, xroot, froot)
' real root of a single non-linear function subroutine
' input
' x1 = lower bound of search interval
' x2 = upper bound of search interval
' tol = convergence criter%ia
' output
' xroot = real root of f(x) = 0
' froot = function value
' note: requires sub jdfunc
local eps, a, b, c, d, e, fa, fb, fcc, tol1
local xm, p, q, r, s, xmin, tmp
eps = 2.23e-16
e = 0.0
a = x1
b = x2
jdfunc(a, fa)
jdfunc(b, fb)
fcc = fb
for iter% = 1 to 50
if (fb * fcc > 0.0) then
c = a
fcc = fa
d = b - a
e = d
end if
if (abs(fcc) < abs(fb)) then
a = b
b = c
c = a
fa = fb
fb = fcc
fcc = fa
end if
tol1 = 2.0 * eps * abs(b) + 0.5 * tol
xm = 0.5 * (c - b)
if (abs(xm) <= tol1 or fb = 0) then exit for
if (abs(e) >= tol1 and abs(fa) > abs(fb)) then
s = fb / fa
if (a = c) then
p = 2.0 * xm * s
q = 1.0 - s
else
q = fa / fcc
r = fb / fcc
p = s * (2.0 * xm * q * (q - r) - (b - a) * (r - 1.0))
q = (q - 1.0) * (r - 1.0) * (s - 1.0)
end if
if (p > 0) then q = -q
p = abs(p)
xmin = abs(e * q)
tmp = 3.0 * xm * q - abs(tol1 * q)
if (xmin < tmp) then xmin = tmp
if (2.0 * p < xmin) then
e = d
d = p / q
else
d = xm
e = d
end if
else
d = xm
e = d
end if
a = b
fa = fb
if (abs(d) > tol1) then
b = b + d
else
b = b + sgn(xm) * tol1
end if
jdfunc(b, fb)
next iter%
froot = fb
xroot = b
end sub
sub obliq_lp(jdate, dpsi, deps, obliq)
' nutations and true obliquity
' input
' jdate = julian date
' output
' dpsi = nutation in longitude in radians
' deps = nutation in obliquity in radians
' obliq = true obliquity of the ecliptic in radians
LOCAL t, t2, t3, eqeq
LOCAL th, tl, obm, obt, st
LOCAL tjdh, tjdl
' split the julian date
tjdh = int(jdate)
tjdl = jdate - tjdh
' fundamental time units
th = (tjdh - 2451545.0) / 36525.0
tl = tjdl / 36525.0
t = th + tl
t2 = t * t
t3 = t2 * t
' obtain equation of the equinoxes
eqeq = 0.0
' obtain nutations
nut2000_lp(jdate, dpsi, deps)
' compute mean obliquity of the ecliptic in seconds of arc
obm = 84381.4480 - 46.8150 * t - 0.00059 * t2 + 0.001813 * t3
' compute true obliquity of the ecliptic in seconds of arc
obt = obm + deps
' return elements in radians
deps = atr * deps
dpsi = atr * dpsi
obliq = atr * obt
END sub
sub nut2000_lp(jdate, dpsi, deps)
' low precison nutation based on iau 2000a
' this function evaluates a short nutation series and returns approximate
' values for nutation in longitude and nutation in obliquity for a given
' tdb julian date. in this mode, only the largest 13 terms of the iau 2000a
' nutation series are evaluated.
' input
' jdate = tdb julian date
' output
' dpsi = nutation in longitude in arcseconds
' deps = nutation in obliquity in arcseconds
LOCAL rev = 360.0 * 3600.0
LOCAL el, elp, f, d, omega
LOCAL i%, arg
LOCAL t = (jdate - 2451545.0) / 36525.0
' computation of fundamental (delaunay) arguments from simon et al. (1994)
' mean anomaly of the moon
el = (485868.249036 + t * (1717915923.2178 + t * (31.8792 + t * (0.051635 + t * (-0.00024470)))) mod rev) / seccon
' mean anomaly of the sun
elp = (1287104.79305 + t * (129596581.0481 + t * (-0.5532 + t * (0.000136 + t * (- 0.00001149)))) mod rev) / seccon
' mean argument of the latitude of the moon
f = (335779.526232 + t * (1739527262.8478 + t * (-12.7512 + t * (-0.001037 + t * (0.00000417)))) mod rev) / seccon
' mean elongation of the moon from the sun
d = (1072260.70369 + t * (1602961601.2090 + t * (- 6.3706 + t * (0.006593 + t * (- 0.00003169)))) mod rev) / seccon
' mean longitude of the ascending node of the moon (from simon section 3.4(b.3), precession = 5028.8200 arcsec/cy)
omega = (450160.398036 + t * (- 6962890.5431 + t * (7.4722 + t * (0.007702 + t * (- 0.00005939)))) mod rev) / seccon
dpsi = 0.0
deps = 0.0
' sum nutation series terms
for i% = 13 to 1 step -1
arg = xnut(1, i%) * el + xnut(2, i%) * elp + xnut(3, i%) * f + xnut(4, i%) * d + xnut(5, i%) * omega
dpsi = (xnut(6, i%) + xnut(7, i%) * t) * sin(arg) + xnut(10, i%) * cos(arg) + dpsi
deps = (xnut(8, i%) + xnut(9, i%) * t) * cos(arg) + xnut(11, i%) * sin(arg) + deps
next i%
dpsi = 1.0e-7 * dpsi
deps = 1.0e-7 * deps
' add in out-of-phase component of principal (18.6-year) term
' (to avoid small but long-term bias in results)
dpsi = dpsi + 0.0033 * cos(omega)
deps = deps + 0.0015 * sin(omega)
END sub
sub getdate (month, day, year)
' request calendar date subroutine
do
print " "
print "please input the calendar date"
print " "
print "(month [1 - 12], day [1 - 31], year [yyyy])"
print "< for example, october 21, 1986 is input as 10,21,1986 >"
print "< b.c. dates are negative, a.d. dates are positive >"
print "< the day of the month may also include a decimal part >"
print " "
input month, day, year
loop until (month >= 1 and month <= 12) and (day >= 1 and day <= 31)
end sub
sub julian(month, day, year, jday)
' Gregorian date to julian day subroutine
' input
' month = calendar month
' day = calendar day
' year = calendar year (all four digits)
' output
' jday = julian day
' special notes
' (1) calendar year must include all digits
' (2) will report October 5, 1582 to October 14, 1582
' as invalid calendar dates and exit
local a, b, c, m, y
y = year
m = month
b = 0.0
c = 0.0
if (m <= 2.0) then
y = y - 1.0
m = m + 12.0
end if
if (y < 0.0) then c = -0.75
if (year < 1582.0) then
' null
elseif (year > 1582.0) then
a = fix(y / 100.0)
b = 2.0 - a + fix(a / 4.0)
elseif (month < 10.0) then
' null
elseif (month > 10.0) then
a = fix(y / 100.0)
elseif (day <= 4.0) then
' null
elseif (day > 14.0) then
a = fix(y / 100.0)
else
print "this date does not exist!!"
exit
end if
jday = fix(365.25 * y + c) + fix(30.6001 * (m + 1.0)) + day + b + 1720994.5
end sub
sub gdate (jday, month, day, year)
' Julian day to Gregorian date subroutine
' input
' jday = julian day
' output
local a, b, c, d, e, f, z, alpha
z = fix(jday + 0.5)
f = jday + 0.5 - z
if (z < 2299161) then
a = z
else
alpha = fix((z - 1867216.25) / 36524.25)
a = z + 1.0 + alpha - fix(alpha / 4.0)
end if
b = a + 1524.0
c = fix((b - 122.1) / 365.25)
d = fix(365.25 * c)
e = fix((b - d) / 30.6001)
day = b - d - fix(30.6001 * e) + f
if (e < 13.5) then
month = e - 1.0
else
month = e - 13.0
end if
if (month > 2.5) then
year = c - 4716.0
else
year = c - 4715.0
end if
end sub
sub utc2tdb (jdutc, jdtdb)
' convert UTC julian date to TDB julian date
' input
' output
' Reference Frames in Astronomy and Geophysics
' J. Kovalevsky et al., 1989, pp. 439-442
local corr, jdtt, t, leapsecond
' find current number of leap seconds
findleap(jdutc, leapsecond)
' compute TDT julian date
corr = (leapsecond + 32.184) / 86400.0
jdtt = jdutc + corr
' time argument for correction
t = (jdtt - 2451545.0) / 36525.0
' compute correction in microseconds
corr = 1656.675 * sin(dtr * (35999.3729 * t + 357.5287))
corr = corr + 22.418 * sin(dtr * (32964.467 * t + 246.199))
corr = corr + 13.84 * sin(dtr * (71998.746 * t + 355.057))
corr = corr + 4.77 * sin(dtr * ( 3034.906 * t + 25.463))
corr = corr + 4.677 * sin(dtr * (34777.259 * t + 230.394))
corr = corr + 10.216 * t * sin(dtr * (35999.373 * t + 243.451))
corr = corr + 0.171 * t * sin(dtr * (71998.746 * t + 240.98 ))
corr = corr + 0.027 * t * sin(dtr * ( 1222.114 * t + 194.661))
corr = corr + 0.027 * t * sin(dtr * ( 3034.906 * t + 336.061))
corr = corr + 0.026 * t * sin(dtr * ( -20.186 * t + 9.382))
corr = corr + 0.007 * t * sin(dtr * (29929.562 * t + 264.911))
corr = corr + 0.006 * t * sin(dtr * ( 150.678 * t + 59.775))
corr = corr + 0.005 * t * sin(dtr * ( 9037.513 * t + 256.025))
corr = corr + 0.043 * t * sin(dtr * (35999.373 * t + 151.121))
' convert corrections to days
corr = 0.000001 * corr / 86400.0
' TDB julian date
jdtdb = jdtt + corr
end sub
sub findleap(jday, leapsecond)
' find number of leap seconds for utc julian day
' input
' jday = utc julian day
' input via global
' jdleap = array of utc julian dates
' leapsec = array of leap seconds
' output
' leapsecond = number of leap seconds
if (jday <= jdleap(1)) then
' date is <= 1972; set to first data element
leapsecond = leapsec(1)
exit sub
end if
if (jday >= jdleap(28)) then
' date is >= end of current data
' set to last data element
leapsecond = leapsec(28)
exit sub
end if
' find data within table
for i% = 1 to 27
if (jday >= jdleap(i%) and jday < jdleap(i% + 1)) then
leapsecond = leapsec(i%)
exit sub
end if
next i%
end sub
function modulo(x) as float
' modulo 2 pi function
local a
a = x - pi2 * fix(x / pi2)
if (a < 0.0) then
a = a + pi2
end if
modulo = a
end function
function atan3(a, b) as float
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' atan3 = angle (0 =< atan3 <= 2 * pi; radians)
local c
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
function vecmag(a())
' vector magnitude function
' input
' { a } = column vector ( 3 rows by 1 column )
' output
' vecmag = scalar magnitude of vector { a }
vecmag = sqr(a(1) * a(1) + a(2) * a(2) + a(3) * a(3))
end function
sub uvector (a(), b())
' unit vector subroutine
' input
' a = column vector (3 rows by 1 column)
' output
' b = unit vector (3 rows by 1 column)
local i as integer, amag
amag = vecmag(a())
for i = 1 to 3
if (amag <> 0.0) then
b(i) = a(i) / amag
else
b(i) = 0.0
end if
next i
end sub
function vdot(a(), b())
' vector dot product function
' c = { a } dot { b }
' input
' n% = number of rows
' { a } = column vector with n rows
' { b } = column vector with n rows
' output
' vdot = dot product of { a } and { b }
local c = 0.0
for i% = 1 to 3
c = c + a(i%) * b(i%)
next i%
vdot = c
end function
sub vcross(a(), b(), c())
' vector cross product subroutine
' { c } = { a } x { b }
' input
' { a } = vector a ( 3 rows by 1 column )
' { b } = vector b ( 3 rows by 1 column )
' output
' { c } = { a } x { b } ( 3 rows by 1 column )
c(1) = a(2) * b(3) - a(3) * b(2)
c(2) = a(3) * b(1) - a(1) * b(3)
c(3) = a(1) * b(2) - a(2) * b(2)
end sub
sub matxvec(a(), b(), c())
' matrix/vector multiplication subroutine
' { c } = [ a ] * { b }
' input
' a = matrix a ( 3 rows by 3 columns )
' b = vector b ( 3 rows )
' output
' c = vector c ( 3 rows )
local s, i%, j%
for i% = 1 to 3
s = 0.0
for j% = 1 to 3
s = s + a(i%, j%) * b(j%)
next j%
c(i%) = s
next i%
end sub
sub transpose (a(), b())
' matrix traspose subroutine
' input
' m = number of rows in matrix [ a ]
' n = number of columns in matrix [ a ]
' output
' b = matrix transpose ( 3 rows by 3 columns )
local i%, j%
for i% = 1 to 3
for j% = 1 to 3
b(i%, j%) = a(j%, i%)
next j%
next i%
end sub
sub jd2str(jdutc)
' convert julian day to calendar date and UTC time
gdate (jdutc, cmonth, day, year)
print "calendar date ", month$(cmonth), " ", STR$(int(day)), " ", str$(year)
print " "
thr0 = 24.0 * (day - int(day))
thr = int(thr0)
tmin0 = 60.0 * (thr0 - thr)
tmin = int(tmin0)
tsec = 60.0 * (tmin0 - tmin)
' fix seconds and minutes for rollover
if (tsec >= 60.0) then
tsec = 0.0
tmin = tmin + 1.0
end if
' fix minutes for rollover
if (tmin >= 60.0) then
tmin = 0.0
thr = thr + 1.0
end if
print "UTC time ", str$(thr) + " hours " + str$(tmin) + " minutes " + str$(tsec, 0, 2) + " seconds"
end sub
sub deg2str(dd, dms$)
' convert decimal degrees to degrees,
' minutes, seconds string
' input
' dd = angle in decimal degrees
' output
' dms$ = string equivalent
local d1, d, m, s
d1 = abs(dd)
d = fix(d1)
d1 = (d1 - d) * 60.0
m = fix(d1)
s = (d1 - m) * 60.0
if (dd < 0.0) then
if (d <> 0.0) then
d = -d
elseif (m <> 0.0) then
m = -m
else
s = -s
end if
end if
dms$ = str$(d) + " deg " + str$(m) + " min " + str$(s, 0, 2) + " sec"
end sub
sub hrs2str(hours)
' convert hours to equivalent string
local thr, tmin0, tmin, tsec
thr = fix(hours)
tmin0 = 60.0 * (hours - thr)
tmin = fix(tmin0)
tsec = 0.0
tmin = tmin + 1.0
end if
tmin = 0.0
thr = thr + 1
end if
print "event duration ", str$(thr) + " hours " + str$(tmin) + " minutes " + str$(tsec, 0, 2) + " seconds"
end sub
