Local Time 01:00 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI restore
palcal
Posted: 07:51pm 04 Apr 2017
In the Micromite Plus Manual under EXAMPLES / EXAMPLE PROGRAM / Sub Touchdown, Geoff
has used the command "GUI Restore c_fname". I can't find any reference to GUI restore in the manual. Any one know what it does and when it is used.
Paul.
Posted: 08:20pm 04 Apr 2017
I think it's the same as GUI SHOW
Posted: 10:08pm 04 Apr 2017
GUI HIDE x will hide GUI control x.
GUI SHOW x will restore GUI control x so you can see it(and use it).
I think GUI SHOW replaced GUI DISABLE and GUI RESTORE in an earlier version of MMBASIC.
Geoff or Peter will know.
This may well be something that needs changing in the manual.......
Posted: 12:40am 05 Apr 2017
Yes, a bug in the documentation. Thanks for pointing it out Paul.
The command should be GUI ENABLE which will "un disable" a control. GUI RESTORE was in the early betas. It will still work in the current version but it is undocumented and I need to remove it from the code at some point.
palcal
Posted: 10:39am 05 Apr 2017
Thanks all.
Paul.
