Local Time 00:52 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - cubic spline interpolation
cdeagle
Posted: 04:33am 01 Apr 2017
This post describes an MMBASIC program that demonstrates how to perform cubic spline interpolation of one-dimensional tabular data provided by the user. The computational steps performed by the main program are as follow;
(1) read data of the form y = f(x)
(2) define the total number of x and y data points in this file
(3) sample and load data arrays for the spline operations (spdata.bas)
(4) generate the spline coefficient arrays (spcoef.bas)
(5) perform interpolation for one or more user-defined x data values (spval.bas)
The following is the output for this example.
1 1995.08 79.0637
2 1995.33 77.027
3 1995.58 75.097
4 1995.83 73.42
5 1996.08 72.3
6 1996.33 72.1059
7 1996.58 73.0494
8 1996.83 75.1141
9 1997.08 78.0324
10 1997.33 82
11 1997.58 87.3253
12 1997.83 93.5205
13 1998.08 100.477
14 1998.33 108.865
15 1998.58 118
16 1998.83 126.594
17 1999.08 134.627
18 1999.33 142.055
19 1999.58 148.339
20 1999.83 153.4
21 2000.08 157.012
22 2000.33 157.096
23 2000.58 153.207
24 2000.83 148.038
25 2001.08 143.1
26 2001.33 138.762
27 2001.58 134.597
28 2001.83 130.216
29 2002.08 125.583
30 2002.33 120.6
31 2002.58 115.222
32 2002.83 109.838
33 2003.08 104.941
34 2003.33 100.958
35 2003.58 97.6
36 2003.83 94.3199
37 2004.08 91.3883
38 2004.33 88.7572
39 2004.58 85.6656
40 2004.83 82.5
41 2005.08 80.1631
42 2005.33 78.4906
43 2005.58 77.0767
44 2005.83 75.6001
45 2006.08 74.2
46 2006.33 73.1772
47 2006.58 72.3095
48 2006.83 71.6035
49 2007.08 71.5961
50 2007.33 72.5
51 2007.58 74.297
52 2007.83 77.0057
53 2008.08 80.8123
54 2008.33 86.08
55 2008.58 92.4
56 2008.83 98.9
Here's a PDF document from the "Numerical Analysis with Numerit" software suite that helps explain how this technique works.
2017-04-01_141537_demo_sfit.pdf
Here's the source code for this MMBASIC computer program.
' demos_sfit.bas April 1, 2017
' this program demonstrates how to interact
' with the cubic spline subroutines which
' "fit" and interpolate one-dimensional
' tabular data of the form y = f(x)
' MMBASIC eXtreme version
option default float
option base 1
dim x(168), y(168), xk(168), yk(168)
dim xfit(168), yfit(168)
dim c1(168), c2(168), c3(168)
' read tabular data
readdata
' define number of x and y data pairs
ndata% = 168
' sample every fifth data value and load
' "working" data arrays for spline operations
nsp% = 5
spdata(x(), y(), ndata%, nsp%, xk(), yk(), npts%)
' generate cubic spline coefficient arrays
spcoef(xk(), yk(), npts%, c1(), c2(), c3())
' evaluate the cubic spline "fit" at every third
' data point and display the interpolated data
nspj% = 3
i% = 0
for jj% = 1 to ndata%
if ((jj% mod nspj%) <> 0) then
' null
else
ii% = ii% + 1
xval = x(jj%)
spval(xval, xk(), yk(), npts%, c1(), c2(), c3(), sx)
xfit(ii%) = xval
yfit(ii%) = sx
print ii%, xfit(ii%), yfit(ii%)
end if
next jj%
end
sub spdata (x(), y(), ndata%, nsp%, xk(), yk(), npts%)
' sample and load data arrays for spline operations subroutine
' input
' x() = x data array
' y() = y data array
' ndata% = number of data points in data arrays
' nsp% = data points sampling interval
' output
' xk() = sampled x data array
' yk() = sampled y data array
' npts% = number of data points in sampled arrays
xk(1) = x(1)
yk(1) = y(1)
npts% = 1
for i% = 1 to ndata%
if ((i% mod nsp%) <> 0)) then
' null
else
npts% = npts% + 1
xk(npts%) = x(i%)
yk(npts%) = y(i%)
j% = i%
end if
next i%
if (j% = ndata%) then
' null
else
npts% = npts% + 1
xk(npts%) = x(ndata%)
yk(npts%) = y(ndata%)
end if
end sub
sub spcoef (x(), y(), n%, c1(), c2(), c3())
' calculate spline coefficients subroutine
' input
' n% = number of data points in arrays
' output
' c1(), c2(), c3() = array of spline coefficients
if (n% < 2) then
print "not enough data points; n must be >= 2"
return
end if
if (n% = 2) then
c1(1) = (y(2) - y(1)) / (x(2) - x(1))
c2(1) = 0.0
c3(1) = 0.0
c1(2) = c1(1)
c2(2) = 0.0
c3(2) = 0.0
return
end if
nm1% = n% - 1
c3(1) = x(2) - x(1)
c2(2) = (y(2) - y(1)) / c3(1)
for i% = 2 to nm1%
c3(i%) = x(i% + 1) - x(i%)
c1(i%) = 2 * (c3(i% - 1) + c3(i%))
c2(i% + 1) = (y(i% + 1) - y(i%)) / c3(i%)
c2(i%) = c2(i% + 1) - c2(i%)
next i%
c1(1) = -c3(1)
c1(n%) = -c3(n% - 1)
if (n% <> 3) then
c2(1) = c2(3) / (x(4) - x(2)) - c2(2) / (x(3) - x(1))
c2(n%) = c2(n% - 1) / (x(n%) - x(n% - 2)) - c2(n% - 2) / (x(n% - 1) - x(n% - 3))
c2(1) = c2(1) * c3(1) ^ 2 / (x(4) - x(1))
c2(n%) = -c2(n%) * c3(n% - 1) ^ 2 / (x(n%) - x(n% - 3))
else
c2(1) = 0.0
c2(n%) = 0.0
end if
for i% = 2 to n%
t = c3(i% - 1) / c1(i% - 1)
c1(i%) = c1(i%) - t * c3(i% - 1)
c2(i%) = c2(i%) - t * c2(i% - 1)
next i%
c2(n%) = c2(n%) / c1(n%)
for j% = 1 to nm1%
i% = n% - j%
c2(i%) = (c2(i%) - c3(i%) * c2(i% + 1)) / c1(i%)
next j%
c1(n%) = (y(n%) - y(nm1%)) / c3(nm1%) + c3(nm1%) * (c2(nm1%) + 2 * c2(n%))
for i% = 1 to nm1%
c1(i%) = (y(i% + 1) - y(i%)) / c3(i%) - c3(i%) * (c2(i% + 1) + 2 * c2(i%))
c3(i%) = (c2(i% + 1) - c2(i%)) / c3(i%)
c2(i%) = 3.0 * c2(i%)
next i%
c2(n%) = 3.0 * c2(n%)
c3(n%) = c3(n% - 1)
end sub
sub spval (u, x(), y(), n%, c1(), c2(), c3(), sx)
' evaluate spline fit subroutine
' input
' u = x value to be "fit"
' c1(), c2(), c3() = spline fit coefficient arrays
' output
' sx = spline "fit" at u value
i% = 1
if ((n% < 2) or (u > x(n%)) or (u < x(1))) then
print " "
print "not enough data points or x value outside range"
return
end if
if (i% >= n%) then
i% = 1
end if
if (u <= x(i% + 1)) then
' null
else
i% = 1
j% = n% + 1
do
k% = int((i% + j%) / 2)
if (u < x(k%)) then
j% = k%
end if
if (u >= x(k%)) then
i% = k%
end if
if (j% > (i% + 1)) then
' null
else
exit do
end if
loop
end if
dx = u - x(i%)
c1i = c1(i%)
c2i = c2(i%)
c3i = c3(i%)
prod = dx * (c1i + dx * (c2i + dx * c3i))
sx = y(i%) + prod
end sub
sub readdata
' read tabular data subroutine
for i% = 1 to 168
read y(i%), x(i%)
next i%
data 80.4, 1994.9170
data 79.6, 1995.0004
data 78.8, 1995.0836
data 78.2, 1995.1670
data 77.7, 1995.2504
data 77.3, 1995.3336
data 76.7, 1995.4170
data 76.0, 1995.5004
data 75.3, 1995.5836
data 74.5, 1995.6670
data 73.7, 1995.7504
data 73.2, 1995.8336
data 72.9, 1995.9170
data 72.5, 1996.0004
data 72.3, 1996.0836
data 72.2, 1996.1670
data 72.1, 1996.2504
data 72.1, 1996.3336
data 72.3, 1996.4170
data 72.6, 1996.5004
data 72.9, 1996.5836
data 73.5, 1996.6670
data 74.1, 1996.7504
data 75.1, 1996.8336
data 76.0, 1996.9170
data 77.0, 1997.0004
data 78.0, 1997.0836
data 79.3, 1997.1670
data 80.6, 1997.2504
data 82.0, 1997.3336
data 83.7, 1997.4170
data 85.6, 1997.5004
data 87.4, 1997.5836
data 89.3, 1997.6670
data 91.4, 1997.7504
data 93.7, 1997.8336
data 95.9, 1997.9170
data 98.2, 1998.0004
data 100.6, 1998.0836
data 103.1, 1998.1670
data 105.9, 1998.2504
data 108.9, 1998.3336
data 111.8, 1998.4170
data 114.8, 1998.5004
data 118.0, 1998.5836
data 120.9, 1998.6670
data 123.7, 1998.7504
data 126.5, 1998.8336
data 129.2, 1998.9170
data 132.0, 1999.0004
data 134.6, 1999.0836
data 137.2, 1999.1670
data 139.6, 1999.2504
data 142.0, 1999.3336
data 144.3, 1999.4170
data 146.4, 1999.5004
data 148.4, 1999.5836
data 150.2, 1999.6670
data 151.9, 1999.7504
data 153.4, 1999.8336
data 154.7, 1999.9170
data 155.8, 2000.0004
data 156.6, 2000.0836
data 157.3, 2000.1670
data 157.6, 2000.2504
data 157.8, 2000.3336
data 155.9, 2000.4170
data 154.2, 2000.5004
data 152.8, 2000.5836
data 151.5, 2000.6670
data 150.0, 2000.7504
data 148.4, 2000.8336
data 146.4, 2000.9170
data 144.7, 2001.0004
data 143.1, 2001.0836
data 141.4, 2001.1670
data 139.5, 2001.2504
data 137.9, 2001.3336
data 137.0, 2001.4170
data 136.0, 2001.5004
data 134.2, 2001.5836
data 132.5, 2001.6670
data 131.3, 2001.7504
data 130.1, 2001.8336
data 128.7, 2001.9170
data 127.1, 2002.0004
data 125.3, 2002.0836
data 123.5, 2002.1670
data 122.0, 2002.2504
data 120.6, 2002.3336
data 118.7, 2002.4170
data 116.5, 2002.5004
data 114.5, 2002.5836
data 112.9, 2002.6670
data 111.6, 2002.7504
data 110.0, 2002.8336
data 108.1, 2002.9170
data 106.6, 2003.0004
data 105.1, 2003.0836
data 103.5, 2003.1670
data 102.1, 2003.2504
data 100.9, 2003.3336
data 99.7, 2003.4170
data 98.6, 2003.5004
data 97.6, 2003.5836
data 96.7, 2003.6670
data 95.8, 2003.7504
data 94.6, 2003.8336
data 93.5, 2003.9170
data 92.3, 2004.0004
data 91.4, 2004.0836
data 90.6, 2004.1670
data 89.7, 2004.2504
data 88.6, 2004.3336
data 87.8, 2004.4170
data 87.0, 2004.5004
data 86.0, 2004.5836
data 84.8, 2004.6670
data 83.6, 2004.7504
data 82.5, 2004.8336
data 81.9, 2004.9170
data 81.3, 2005.0004
data 80.4, 2005.0836
data 79.6, 2005.1670
data 79.0, 2005.2504
data 78.4, 2005.3336
data 77.8, 2005.4170
data 77.3, 2005.5004
data 77.0, 2005.5836
data 76.6, 2005.6670
data 76.1, 2005.7504
data 75.6, 2005.8336
data 75.1, 2005.9170
data 74.6, 2006.0004
data 74.2, 2006.0836
data 74.0, 2006.1670
data 73.7, 2006.2504
data 73.4, 2006.3336
data 73.1, 2006.4170
data 72.6, 2006.5004
data 72.3, 2006.5836
data 71.9, 2006.6670
data 71.7, 2006.7504
data 71.6, 2006.8336
data 71.5, 2006.9170
data 71.5, 2007.0004
data 71.7, 2007.0836
data 71.8, 2007.1670
data 72.1, 2007.2504
data 72.5, 2007.3336
data 73.0, 2007.4170
data 73.4, 2007.5004
data 74.1, 2007.5836
data 74.9, 2007.6670
data 76.0, 2007.7504
data 77.2, 2007.8336
data 78.3, 2007.9170
data 79.6, 2008.0004
data 80.9, 2008.0836
data 82.4, 2008.1670
data 84.1, 2008.2504
data 86.2, 2008.3336
data 88.2, 2008.4170
data 90.3, 2008.5004
data 92.4, 2008.5836
data 94.5, 2008.6670
data 96.7, 2008.7504
data 98.9, 2008.8336
end sub
https://drive.google.com/drive/folders/0Bx2YPzS0EoweUFR6ZHZ0cVpFWjA?usp=sharing
Frank N. Furter
Posted: 10:53pm 02 Apr 2017
Hi Cdeagle,
thanks a lot - that's very useful!!!
Frank
Tinine
Posted: 08:25pm 03 Apr 2017
  Frank N. Furter said   Hi Cdeagle,
Frank
+1
