Local Time 06:26 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LoRa modules
akashh
Posted: 03:44pm 31 Mar 2017
I have been doing quite a bit of research on Lora and there is some amazing stuff going on with it, for those of you who aren't following it yet. There are relatively low cost modules of 7-12 usd which have a lot of the low level stuff already built in. Microchip has a module with a serial interface that even takes care of encryption (RN2483).
These modules can be used in point to point or WAN type setups with a gateway. Using raspberry PI one can even develop a small single channel gateway to communicate with nodes over long ranges, some claim over 5km and 2 km in built up areas.
I was wondering if anyone else messed with this technology and if there is any feedback so far. I have order three of the microchip ones and thee semtech sx1276 to see what can be done.
Ideas are for remote metering of water, electricity, remote control of irrigation, remote motion sensing, you name it.
Edit: here is a link to an open source gateway: http://cpham.perso.univ-pau.fr/LORA/RPIgateway.htmlEdited by akashh 2017-04-02
Posted: 09:48pm 31 Mar 2017
Hi Akash.
there has been some stuff posted here about balloon tracking i.e. long distance via relay stations. I think that use(s|d) LoRa.
FORUM LINK 1
FORUM LINK 2
TassyJim did some work with it too I believe:
FORUM LINK 3
but the dropbox link doesn't work anymore - Jim?
cheersEdited by CaptainBoing 2017-04-02
