Local Time 01:24 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - hot air balloon performance
cdeagle
Posted: 03:16am 25 Mar 2017
BALLOON is a program which can be used to determine the performance capability
of hot air balloons. The payload weight lifting capability, gas temperature,
balloon volume and the maximum altitude capability can be determined
accurately with this program. BALLOON requires a combination of the following
user inputs;
(1) launch site altitude and temperature
(2) liftoff weight
(3) balloon volume
(4) gas temperature
(5) flight altitude
From any combination of three items (2, 3, 4 or 5), program BALLOON provides
the user with the fourth item. This program also computes the air temperature
at the balloon's altitude. The launch site altitude and temperature are
required in order to compensate for "non-sea level" conditions such as hot or
cold days and flying locations which may not be at sea level.
Here's a typical user interaction with the software.
program balloon
please input the launch site altitude (meters)
? 0
please input the launch site temperature (degrees f)
? 59
performance menu
< 1 > gross weight capability
< 2 > gas temperature required
< 3 > balloon volume required
< 4 > maximum altitude capability
selection
? 4
please input the gross weight (kilograms)
? 250
please input the balloon volume (cubic meters)
? 1500
please input the gas temperature (degrees f)
? 275
program balloon
gross weight 250.00 kilograms
balloon volume 1500.00 cubic meters
gas temperature 275.00 degrees f
altitude 11157.24 meters
ambient temperature -69.70 degrees f
Here's the same example except the balloon is launched on a "high altitude, hot day". For improved performance, hot air balloons in Colorado are launched early in the morning.
program balloon
? 1644
? 90
performance menu
selection
? 4
? 250
? 1500
? 275
program balloon
altitude 7718.56 meters
ambient temperature -5.70 degrees f
Here's the MMBASIC cource code for this program.
' program balloon.bas march 25, 2017
' determines performance capability of hot air balloons
' gross weight capability, kilograms
' gas temperature required, degrees fahrenheit
' balloon volume required, cubic meters
' maximum altitude capability, meters
' MicroMite eXtreme version
option default float
dim weight, volume, gastemp, altitude
dim rho, rhoamb, gtempabs, tambabs, tsiteabs
const altitude0 = 10999.9272
const rhosl = 1.22557
print " "
print "program balloon"
print "---------------"
print " "
print "please input the launch site altitude (meters)"
input altsite
print " "
print "please input the launch site temperature (degrees f)"
input tempsite
' determine launch site ambient density and absolute temperature
rho = rhosl * fnb(altsite) ^ 4.256116 / (1.0 + (tempsite - 59.0) / 518.67)
tsiteabs = fna(tempsite)
' print menu and prompt user for selection
do
print " "
print "performance menu"
print " "
print " "
print " < 1 > gross weight capability"
print " "
print " < 2 > gas temperature required"
print " "
print " < 3 > balloon volume required"
print " "
print " < 4 > maximum altitude capability"
print " "
print " "
print "selection"
input selection%
loop until (selection% >= 1 and selection% <= 4)
select case selection%
case 1
gweight
case 2
trequired
case 3
vrequired
case 4
maxalt
end select
' print results
print " "
print " "
print "gross weight ", str$(weight, 0, 2), " kilograms"
print " "
print "balloon volume ", str$(volume, 0, 2), " cubic meters"
print " "
print "gas temperature ", str$(gastemp, 0, 2), " degrees f"
print " "
print "altitude ", str$(altitude, 0, 2), " meters"
print " "
print "ambient temperature ", str$(fnc(tambabs), 0, 2), " degrees f"
print " "
end
function fna(x) as float
fna = 5.0 * (x + 459.67) / 9.0
end function
function fnb(x) as float
fnb = (1.0 - 0.000022556913 * x)
end function
function fnc(x) as float
fnc = 9.0 * x / 5.0 - 459.67
end function
sub atmos
' ambient density and absolute temperature subroutine
if (altitude < altitude0) then
a = fnb(altitude)
rhoamb = rho * a ^ 4.256116
tambabs = a * tsiteabs
else
rhoamb = 0.297122 * rho * exp(1.73454773 - 0.0001576872 * altitude)
tambabs = 216.65
end if
end sub
sub get_altitude
' request altitude subroutine
do
print " "
print "altitude (meters)"
input altitude
loop until (altitude > 0.0)
end sub
sub get_gastemp
' request gas temperature subroutine
do
print " "
print "please input the gas temperature (degrees f)"
input gastemp
loop until (gastemp > 0.0)
gtempabs = fna(gastemp)
end sub
sub get_volume
' request balloon volume subroutine
do
print " "
print "please input the balloon volume (cubic meters)"
input volume
loop until (volume > 0.0)
end sub
sub get_weight
' request gross weight subroutine
do
print " "
print "please input the gross weight (kilograms)"
input weight
loop until (weight > 0.0)
end sub
sub gweight
' gross weight capability subroutine
print " "
get_volume
get_gastemp
get_altitude
atmos
weight = volume * rhoamb * (1.0 - tambabs / gtempabs)
end sub
sub maxalt
' maximum altitude subroutine
print " "
get_weight
get_volume
get_gastemp
x0 = 0.0
x2 = 3.0 * altitude0
altitude = 0.0
wfunction(wf0)
if (wf0 <= 0.0) then
print " "
print "cannot lift this weight !!"
exit sub
end if
do
x1 = 0.5 * (x0 + x2)
altitude = x0
wfunction(f0)
altitude = x1
wfunction(f1)
altitude = x2
wfunction(f2)
a = x1 - x0
b = f1 / f0
c = b * b - f2 / f0
x3 = x1 + a * b / sqr(c)
altitude = x3
if (abs(x3 - x2) < 0.1) then exit do
wfunction(f3)
if (f3 * f1 < 0.0) then x0 = x1
if (f3 * f2 < 0.0) then x0 = x2
x2 = x3
loop
end sub
sub trequired
' gas temperature required subroutine
print " "
get_weight
get_volume
get_altitude
atmos
a = volume * rhoamb
gtempabs = a * tambabs / (a - weight)
gastemp = fnc(gtempabs)
end sub
sub vrequired
' balloon volume required subroutine
print " "
get_weight
get_gastemp
get_altitude
atmos
volume = weight / (rhoamb * (1.0 - tambabs / gtempabs))
end sub
sub wfunction (wf)
' weight function subroutine
atmos
wf = volume * rhoamb * (1.0 - tambabs / gtempabs) - weight
end sub
