Local Time 01:22 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : autorun.bas ? on micromite
sagt3k
Posted: 11:44pm 24 Mar 2017
Hi to everybody
I don't remember .. but with micromite MX or MZ with uSD ..is it possibile to load a file .bas as "autorun.bas" at power on?
Sagt3k
Posted: 12:15am 25 Mar 2017
You could write a simple code along the lines of:
CHDIR "\"
LOAD "AUTORUN.SYS",R
...and save that as your "Code" in the main memory.
Now, set that to AUTORUN ON from the command prompt.
When you power up, this two-line code will execute, and load and run AUTORUN.SYS - or whatever filename you nominate.
EDIT: Actually, that will only work once. Your best bet would be to put that code in the library area rather then the main-memory area.
IE: Save those two lines of code above via the LIBRARY SAVE command. Then no matter what program is in the code memory, when you restart the Micromite, it will execute the library code area first, which instructs the system to load the autorun program.
Not tested, but that should work.Edited by Grogster 2017-03-26
sagt3k
Posted: 12:29am 25 Mar 2017
Hi Grogster
I follow your suggestion (in AUTORUN.SYS I have already saved two lines..):
> load "AUTORUN.SYS"
> library SAVE
> list
> run
[LIBRARY] Load "AUTORUN.SYS",R
Error: Expression is too complex
> list
Chdir "\"
> library list
Chdir "\"
sagt3k
Posted: 01:45am 25 Mar 2017
The LIBRARY contains the two lines, but the main code MUST NOT.
If you have the two lines saved in the library as above, AND also a file called AUTORUN.SYS with the same two lines in it, you will have created something of a crazy loop as far as MMBASIC is concerned, whereby at startup, the library calls AUTORUN.SYS, which is the same code, runs that, which calls AUTORUN.SYS, which calls AUTORUN.SYS, which calls AUTORUN.SYS, which calls AUTORUN.SYS..........
The library code calls the program called AUTORUN.SYS.
AUTORUN.SYS needs to be the program you want to run - NOT the two lines of code.
Hopefully I am making some kind of sense!
sagt3k
Posted: 02:20am 25 Mar 2017
Hi Grogster
Thanks, I have solved so:
I created a code that recall the file "autorun.sys" with a infinite loop. I need test stability of uSD recall always the file "autorun.sys". With mm.startup it's a good solution. Now I need another solution. I have variable X ..I know that with NEW and LOAD all variable are cleaned. OK .. but if I want to store in RAM a variable ..
I can use VAR SAVE, It is limited to the flash with few written.
Now if possibile to create a command for example DIM RAM X which allows to not reset the variable in the case of commands such as NEW and LOAD ...
Could be possible ?
'FILE:AUTORUN.SYS -------------
Option autorun on
Print "--AUTORUN.SYS--"
SetPin 2,dout
SetTick 1000,ReLoad
Pin(2)=Not Pin(2)
Print "X="X, "Timer="Timer
Pause 100
X=X+1
Loop
Sub mm.startup
Load "autorun.sys",r
End Sub
Sub ReLoad
mm.startup
End Sub
'END:AUTORUN.SYS -------------
