Forum Index : Microcontroller and PC projects : SC DDS signal generator,
palcal![]() Guru Joined: 12/10/2011 Location: AustraliaPosts: 2052 |
This months SC has a signal generator based on the Micromite Backpack. I went straight to the ali express web site nominated in the srticle to buy one (about US$11) but they were sold out. However SC are selling them for $25 plus about $10 postage. I must say the rest of the mag was a bit of a bore as usual, bring on the new mag DIYODE it can't be any worse. I will search the web for the module and see what I can find. Paul. Edit. I can't find any on the web maybe someone else may have some luck. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
| Bill7300 Senior Member Joined: 05/08/2014 Location: AustraliaPosts: 159 |
My Silicon Chip issue has yet to arrive but what exactly are you looking for on the web? Bill Bill |
| damos Regular Member Joined: 15/04/2016 Location: AustraliaPosts: 81 |
I uploaded an article last year using this module, which is really cheap and easy to get: AD9833 Module on eBay There is discussion here The SC article uses a module that has a gain stage and a built in level control. My design uses and incremental encoder for set the frequency and level, which I prefer by far. I put a lot of work into the code for the encoder so it behaves like a good analog instrument - no matter what frequency you are on, it adjusts the step to allow you to quickly sweep a band with a flick of the wrist. For example, at 1kHz going counter clockwise will subtract 100Hz for each step, while above a couple of kHz it will switch to a larger step. Dan |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6608 |
I was caught out when I went looking for the module too. But Geoff assured me they were still available. I just had to set my EBay search to world-wide and there they were. This is the one I ordered: http://www.ebay.com.au/itm/331851695524?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Or search ebay for "AD9833 DDS Signal Generator Module 0-12.5MHz Square / Triangle / Sine Wave" Having the gain available makes using it much easier. Jim VK7JH MMedit |
Thanks Jim, I have ordered one. Paul. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
For people who do not get Silicon Chip the Signal Generator is described on my website at http://geoffg.net/SignalGenerator.html Geoff Geoff Graham - http://geoffg.net |
| RonnS Senior Member Joined: 16/07/2015 Location: GermanyPosts: 123 |
thank you Geoff, that project looks very professional regards Ron |
jman![]() Guru Joined: 12/06/2011 Location: New ZealandPosts: 711 |
Hi I have been playing with Geoff's software and found a small issue. If you select sweep mode then tap the sweep time +- 5 times in row fairly quickly the following error occurs then the watchdog reboots and all is well again Could somebody else confirm this is the case or is it just me. Regards Jman |
That is an obscure bug. I'm tempted to say that the cure is "don't do it" but I will have a look when I get back. Geoff Geoff Graham - http://geoffg.net |
