Local Time 07:53 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - moon rise and set
cdeagle
Posted: 02:32am 18 Mar 2017
This post is an MMBASIC program for the MicroMite eXtreme that can be used to determine rise and set conditions of the moon relative to an observer anywhere on the Earth.
Here's a typical user interaction with the software and several rise/set conditions computed by this computer program.
rise and set of the moon
please input the calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 3,16,2017
please input the geographic latitude of the observer
(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])
(north latitudes are positive, south latitudes are negative)
? 39,40,36
please input the geographic longitude of the observer
(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])
(east longitude is positive, west longitude is negative)
? -104,57,12
please input the altitude of the observer (meters)
(positive above sea level, negative below sea level)
? 1644
please input the number of days to simulate
? 5
searching for rise and set conditions ...
rise conditions
calendar date March 16 2017
UTC time 4 hours 19 minutes 21.49 seconds
UTC julian day 2457828.68010985
topocentric coordinates
lunar azimuth angle 102 deg 12 min 34.83 sec
lunar elevation angle 0 deg -48 min 53.86 sec
maximum elevation conditions
UTC time 9 hours 55 minutes 26.99 seconds
UTC julian day 2457828.91350678
lunar azimuth angle 179 deg 17 min 23.36 sec
lunar elevation angle 39 deg 31 min 18.99 sec
set conditions
UTC time 15 hours 30 minutes 33.59 seconds
UTC julian day 2457829.14622216
lunar azimuth angle 255 deg 44 min 57.10 sec
lunar elevation angle 0 deg -48 min 51.34 sec
event duration 11 hours 11 minutes 12.10 seconds
rise conditions
calendar date March 17 2017
UTC time 5 hours 15 minutes 52.57 seconds
UTC julian day 2457829.71935847
lunar azimuth angle 106 deg 34 min 37.78 sec
lunar elevation angle 0 deg -48 min 48.84 sec
UTC time 10 hours 42 minutes 33.60 seconds
UTC julian day 2457829.94622218
lunar azimuth angle 180 deg 2 min 29.18 sec
lunar elevation angle 36 deg 19 min 12.40 sec
set conditions
UTC time 16 hours 4 minutes 21.57 seconds
UTC julian day 2457830.16969405
lunar azimuth angle 251 deg 45 min 14.96 sec
lunar elevation angle 0 deg -48 min 47.38 sec
event duration 10 hours 48 minutes 28.99 seconds
Here's the link to a zipped archive that contains both the MMBASIC source code and a PDF document.
2017-03-18_122718_moon_riseset.zip
isochronic
Posted: 07:31am 18 Mar 2017
Is that Colarado ??
cdeagle
Posted: 08:27am 18 Mar 2017
Yes.
It's the location of the Chamberlin Observatory on the University of Denver campus.
cdeagle
Posted: 12:42am 19 Mar 2017
My MMBASIC programs and documentation can be accessed via the following Google Drive link;
https://drive.google.com/drive/folders/0Bx2YPzS0EoweUFR6ZHZ0cVpFWjA?usp=sharing
cdeagle
Posted: 11:19am 16 Jun 2017
I have updated several MMBASIC programs for the Micromite eXtreme and Raspberry Pi (moon_riseset, npoe, sat_riseset, etc.) at my Google Drive site located at
David
Frank N. Furter
Posted: 07:04am 17 Jun 2017
Hi David,
thank you very much!!!
Frank
cdeagle
Posted: 05:28am 20 Jul 2017
I've added the calculation and display of the moon's phase to the moon_riseset.bas MMBASIC program.
Here's the link to the zipped archive with the new source code.
2017-07-20_152709_moon_riseset.zip
