Local Time 23:52 11 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - solar eclipses
cdeagle
Posted: 07:46am 14 Mar 2017
This post is an MMBASIC computer program for the MicroMite eXtreme which can be used to predict the local circumstances of solar eclipses. The software uses a combination of one-dimensional minimization and root-finding to calculate these conditions.
Here's a typical user interaction with the software. The program will take a minute or so to run to completion. Be patient, it's performing thousands of hardware-based, double precision calculations looking for the answer. The source code listing is 3200+ lines of comments, white space and actual code.
program solar_eclipse
please input the initial calendar date
(month [1 - 12], day [1 - 31], year [yyyy])
< for example, october 21, 1986 is input as 10,21,1986 >
< b.c. dates are negative, a.d. dates are positive >
< the day of the month may also include a decimal part >
? 12,1,2000
please input the geographic latitude of the observer
(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])
(north latitudes are positive, south latitudes are negative)
? 39,40,36
please input the geographic longitude of the observer
(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])
(east longitude is positive, west longitude is negative)
? -104,57,12
please input the altitude of the observer (meters)
(positive above sea level, negative below sea level)
? 1644
please input the search duration in days
? 30
searching for solar eclipse ...
Here's the program output for this example.
begin penumbral phase of solar eclipse
calendar date December 25 2000
UTC time 15 hours 29 minutes 23.91 seconds
UTC julian day 2451904.14541560
topocentric coordinates
lunar azimuth angle 132 deg 9 min 29.65 sec
lunar elevation angle 10 deg 35 min 42.02 sec
solar azimuth angle 132 deg 8 min 30.41 sec
solar elevation angle 10 deg 4 min 35.03 sec
greatest eclipse conditions
UTC time 16 hours 43 minutes 32.47 seconds
UTC julian day 2451904.19690359
lunar azimuth angle 146 deg 40 min 53.36 sec
lunar elevation angle 19 deg 34 min 59.64 sec
solar azimuth angle 146 deg 53 min 27.85 sec
solar elevation angle 19 deg 21 min 2.24 sec
end penumbral phase of solar eclipse
UTC time 18 hours 6 minutes 3.54 seconds
UTC julian day 2451904.25420764
lunar azimuth angle 165 deg 38 min 46.45 sec
lunar elevation angle 25 deg 48 min 46.82 sec
solar azimuth angle 166 deg 12 min 32.05 sec
solar elevation angle 25 deg 41 min 51.62 sec
event duration 2.61100903 hours
Here's a PDF document for the MATLAB version of the program.
2017-03-14_173057_solar_eclipse.pdf
Here's a zip archive of the MMBASIC source code for the solar eclipse computer program.
2017-03-14_173117_solar_eclipse.zip
Posted: 11:39am 14 Mar 2017
Just run it for my house in France for the next 10,000 days and it is matching exactly this site
August 12th 2026 we get 90% coverage
Fascinating - thanks for posting
Frank N. Furter
Posted: 11:46pm 14 Mar 2017
Hi Cdeagle,
very nice code, thank you very much!
Did you have some code for calculating the position of the planets?
Frank
cdeagle
Posted: 12:08am 15 Mar 2017
Yes I do have MMBASIC code for computing planetary positions.
I will post it in the near feature.
Posted: 03:44am 15 Mar 2017
My son recently got very interested in space related stuff. It happened after the CRS-10 launch of SpaceX. The day after the ISS was visible from my location and it was great to see it fly over.
Now he wants to see it more clear. The idea is to buy a small telescope and try to follow it. Here is where it gets interesting for me. :)
Adding a small motor that actually tracks it so that there are no jerky movements that will probably cause it to loose sight of it.
Controlling a motor with a micromite would be the plan.
Did any of you guys ever do something like that? What is the best place to get more info, my googling is not getting much info.
Posted: 02:43pm 13 Apr 2018
I've been using this program to test various MMBasic implementations as it is a very good test of both the resilience and the accuracy of any port.
Results so far:
Pi-cromite @ 1200MHz: 7.86 seconds - identical answer
STM32H7 @ 400MHz: 26.66 seconds - identical answer
MMX @ 200MHz 74.98 seconds - identical answer
MM+ @ 100MHz 121.75 seconds - small variations (NB software floating point)
This gives an interesting insight into the comparative strengths of the ARM core vs the MIPS and it is interesting to speculate where the differences arise.
The MMX result vs the MM+ is disappointing. The MMX has a double precision hardware FPU but is not that much quicker. We have always suspected that the limiting factor in MMBasic is the parsing rather than the times for the underlying calculations and that the flash memory access times may be critical in this.
The Pi-cromite and STM32H7 are pretty much in-line with their relative clock speeds but significantly faster than the PICs on a per MHz basis. This suggests to me that the cacheing on the ARM core is better than the PIC and to test this I turned cacheing off on the STM32. This then gave results of:
STM32H7 @ 400MHz (no cacheing): 95.49 seconds - identical answer
STM32H7 @ 400MHz (Instruction cacheing only): 53.29 seconds - identical answer
STM32H7 @ 400MHz (Data cacheing only): 86.48 seconds - identical answer
As can be seen both types of cacheing are important but instruction caching is essential before the availability of data becomes really relevant
So it is clear that the cacheing is absolutely critical to the chips performance.
isochronic
Posted: 01:57am 14 Apr 2018
I think the STM has a FPU - don't know if it is DP or not though.
I agree, at a guess the double-precision of the FPU is probably not going to speed up the parsed eclipse iterative minimisation/root-finding process a lot, at least until the iteration is very close to a solution (?).
Boppa
Posted: 04:12am 14 Apr 2018
  MicroBlocks said   My son recently got very interested in space related stuff. It happened after the CRS-10 launch of SpaceX. The day after the ISS was visible from my location and it was great to see it fly over.
Basically you are making a goto telescope...
GOTO telescope
plasma
Posted: 10:28am 15 Apr 2018
thanks for the code ! i like this kind of stuff.
cdeagle
Posted: 12:03pm 07 Apr 2019
Here's an updated version of the solar eclipse MMBASIC program. It should run on any MicroMite that supports double precision math. It now displays conditions during the total/annular phases of eclipses. The documentation includes the write-up that appeared in Volume 2, Number 2 of Celestial Computing.
2019-04-07_220307_solar_eclipse.zip
isochronic
Posted: 12:10am 21 Apr 2019
Apart from eclipses, could the earth/moon/sun system positions be used to calculate tide times and strengths ? I guess there would be a calculation assuming the ocean as a large blob of water modified by a local factor for individual locations eg a local phase delay and amplitude scale based on local measurement (?)
cdeagle
Posted: 12:17am 21 Apr 2019
For tide predictions check out
https://tidesandcurrents.noaa.gov/tide_predictions.htmlC
Posted: 03:54am 21 Apr 2019
I use wtides
http://www.wtides.com/
isochronic
Posted: 03:01am 22 Apr 2019
(!) more empirical than I thought
cdeagle
Posted: 04:58pm 09 Nov 2026
Here is a version of the solar eclipse program that uses a more efficient root-finding algorithm called bdqrf.bas. It has the same calling arguments as the brent subroutine.
sub bdqrf(x1, x2, tol, x, y)
 ' solve for a single real root of a nonlinear equation
 ' Bisected Direct Quadratic Regula Falsi (BDQRF)
 ' Applied Mathematical Sciences, Vol. 4, 2010, no. 15
 ' input
 '  x1  = lower bound of search interval
 '  x2  = upper bound of search interval
 '  tol = convergence criterion
 ' output
 '  x = real root of f(x) = 0
 '  y = function value
solar_eclipse.zip
Posted: 05:12pm 09 Nov 2026
Hi
Great to see you online again. Your solar eclipse program has served as my benchmark and accuracy test for much of the MMBasic enhancements recently. Fastest run currently is just over half a second on a CMM2 with the main function automatically converted to a csub by a python script. Running, without cheating on the cmm2, using the new JIT compilation function gives exactly a second. I'll be interested to see the impact of this new version but the old one will remain my goto test
cdeagle
Posted: 09:10pm 10 Nov 2026
Peter
I've been following your benchmark tests with keen interest.
PhenixRising
Posted: 09:26pm 10 Nov 2026
  matherp said  Hi
Great to see you online again.[/Quote]
Same here. Was surprised that you hadn't chimed-in before now.
