Local Time 01:28 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM170 and ILI9341 Button Test...
Zonker
Posted: 05:59pm 12 Mar 2017
Evening Gents..
I was wanting to get to work on getting a Welder controller spun up for Ed Hase, a buddy of mine, and since I don't need a lot of I/O pins, decided to try out using the 28 pinner with a 2.4" SPI display.. I have worked with the 470 and the awesome built in controls but didn't have any serious play time with this type of setup...
So, I just read the PDF manual, and started with Geoff's suggested test program. Unlike the 470 firmware, there isn't any "Pen_up/Pen_down" stuff, there is only the fact that you can assign an inturpt routine to call when the T_IRQ pin goes "low" on the touch controller. Ok, I get it, In a 170 there is no room for any of the "fancy" stuff like the 470, so, you just have to handle all the GUI stuff yourself, and this includes creating simple "buttons" and other objects you will need in your program.
So, I started out by expanding on Geoff's to include a simple "button" object and wanted to create a "touch detector" for it. Along the way, I found out that the INT routine was trapping the touch data and reporting that sometimes either TOUCH(X) or TOUCH(Y) or both were showing as -1 in the captured data. Some simple software "filtering" removed the errors, but this test program keeps count of them. I also trap the touches that are within bounds of the "Button" drawn on the screen and count them also. Overall, it seems to be working OK... Will keep going as play time permits..
Anyway, I wanted to post it here in case anyone else might have an interest...
' test program ili9341 LCD touch display
SetPin 18,intl,user_touch ' T_IRQ pin on touch controller
CLS
Box 0,0,MM.HRes-1,MM.VRes/2,3,RGB(red),RGB(blue)
RBox 160,150,150,50,10,RGB(yellow),RGB(brown)
Text 190,172,"Button",lm,1,2,RGB(yellow),RGB(brown)
Text MM.HRes/2,MM.VRes/4,Time$,cm,1,4,RGB(cyan),RGB(blue)
If A Then
Circle 300,100,10,3,1,RGB(yellow),RGB(yellow)
a=0
Else
Circle 300,100,10,3,1,RGB(blue),RGB(blue)
a=1
EndIf
Pause 100
Loop
Sub user_touch
tx=Touch(x)
ty=Touch(y)
If tx>0 And ty>0 Then
Text 12,140," ",lm,1,2,RGB(black),RGB(black)
Text 12,140,"X "+Str$(tx,3)+" Y "+Str$(ty,3),lm,1,1,RGB(cyan),RGB(black)
If tx>160 And tx<310 Then
If ty>150 And ty<200 Then
tc=tc+1
Text 12,160,"Button Count "+Str$(tc,3),lm,1,1,RGB(cyan),RGB(black)
EndIf
EndIf
Else
ec=ec+1
Text 12,180,"Errors Count "+Str$(ec,3),lm,1,1,RGB(cyan),RGB(black)
EndIf
End Sub
OA47
Posted: 03:09pm 13 Mar 2017
Zonker, I too prefer the 28 pinners for small projects and would like to say how grateful I am that you are sharing your code as I am sure I will be referring to it in future exploits.
Graeme
panky
Posted: 05:02pm 13 Mar 2017
Zonker,
There is a post from Mike O (Font scaling bug in 5.0302) here that demos using buttons on an ILI LCD.
This might give you some ideas. It works fine - you just have to be careful not to have any part of your button character extend outside the bounds of the button or it will crash the system.
Cheers,
Doug.
Zonker
Posted: 11:41pm 13 Mar 2017
Thank's Doug..!
I will take a peek at it when I get back from work today...
I hope doing GUI stuff on a 170 won't be to much of a pain..
