Local Time 01:16 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Memory Game
flip
Posted: 01:15am 12 Mar 2017
Hi all!
Hope its OK to put a game here.
Memory game I developed for uM Backpack Feb last year and tried it on MX470 with different resolution and it worked straight away (I surprised myself) so I thought it must be robust enough to share.
I got idea of using MM.VRES and MM.HRES (and probably much more than I remember) from some of Geoff's snippets. It is a bit 'sledgehammer' in places and grossly lacking in comments but I hope it has some useful ideas!
It kept my 7yo niece amused for a whole 7 minutes (no mean feat these days)
Enjoy.
option base 1
CONST LANDSCAPE = MM.HRes > MM.VRes
const MAX_LEVEL = 10
dim pairs( MAX_LEVEL + LANDSCAPE, MAX_LEVEL + not(LANDSCAPE) ) as integer
dim integer lvl = 1
dim lvlColour as integer
dim lvlTextScale as integer
dim as integer cf=rgb(yellow),ck=RGB(BLUE),cb=RGB(WHITE),ci=rgb(0,128,228),xo=10,yo=10
const gap=4
do 'Forever loop
lvl=lvl + 1
GetLevel
restore LevelConfigData
for i=1 to lvl
read lvlColour,lvlTextScale
next i
if LANDSCAPE then
ny=lvl
nx=ny+1
ELSE
nx=lvl
ny=nx+1
endif
xstep=MM.HRes\nx
ystep=MM.VRes\ny
success%=0
'Populate values array
v$=""
for i=1 to nx*ny/2
v$=v$ + chr$(i) + chr$(i) '11223344....
next i
'Draw boxes and assign values
CLS
for x=1 to nx
for y=1 to ny
rbox gap+(x-1)*xstep,gap+(y-1)*ystep,xstep-gap,ystep-gap,,rgb(white),lvlColour
'Assign random value
p%=int(rnd(1) * len(v$)) + 1
pairs(x,y)= ASC(mid$(v$, p%,1))
' and remove it from list
v$ = left$(v$,p%-1) + mid$(v$,p%+1)
next y
next x
' Game Loop
do
'Get first selection
do
GetTouch
xa=xp\xstep + 1
ya=yp\ystep + 1
loop while pairs(xa,ya)=0 'if 0, already matched
Text gap\2+(xa-.5)*xstep,gap\2+(ya-.5)*ystep,str$(pairs(xa,ya)),cm,1,lvlTextScale,RGB(BLACK),lvlColour
GetTouch
xb=xp\xstep + 1
yb=yp\ystep + 1
if pairs(xb,yb) > 0 then
Text gap\2+(xb-.5)*xstep,gap\2+(yb-.5)*ystep,str$(pairs(xb,yb)),cm,1,lvlTextScale,RGB(BLACK),lvlColour
endif
if pairs(xa,ya) = pairs(xb,yb) and (xa<>xb or ya<>yb) then
success%=success%+1
' register success for this pair
pairs(xa,ya)=0
pairs(xb,yb)=0
ELSE
' show it for half a second
pause 500
'incorrect choice - redraw background for both
rbox gap+(xa-1)*xstep,gap+(ya-1)*ystep,xstep-gap,ystep-gap,,rgb(white),lvlColour
if pairs(xb,yb)>0 then
rbox gap+(xb-1)*xstep,gap+(yb-1)*ystep,xstep-gap,ystep-gap,,rgb(white),lvlColour
endif
endif
loop while success% < nx*ny/2
kup%=0:e%=0
do
if e% then
RBOX 20,150,280,70,14,cb,cb:RBOX 23,153,274,64,11,ck,ck:text 35,160,"YIPPEE!",,1,4,cf,ck
else
RBOX 20,150,280,70,14,cb,cb:RBOX 23,153,274,64,11,cf,cf:text 35,160,"YIPPEE!",,1,4,ck,cf
endif
for i=1 to 30
pause 10
if Touch(x) = -1 then
kup%=1
else
if kup%=1 then
exit do
endif
endif
next i
e%=not(e%)
loop
loop
' ********** SUBROUTINES ************
' Wait for screen touch and Get Touch position into xp and yp
sub GetTouch
xp=0
yp=0
a=Touch(x)
b=Touch(y)
If (a>-1 And (a>xp+10) Or a<xp-10)) Or (b>-1 And (b>yp+10 Or b<yp-10)) Then
If a>-1 And b>-1 Then
'Print a,b
xp=a
yp=b
EndIf
EndIf
Loop while xp=0 or yp=0 or a>-1 or b>-1
end sub
sub GetLevel()
' Returns 0 to exit or 1-MAX_LEVEL as chosen level
cls
local Msg as string
'Foreground, BacKground, Border and Inactive colours,xoffset,yoffset
CLS
'Show level as separate box
'RBOX 55,20,232,70,14,cb,cb:RBOX 58,23,226,64,11,ci,ci:text 60,30," 5 x 6",,1,4,cf,ci
'or show as grouping box
RBOX xo,yo,285,105,14,cb,cb:RBOX xo+3,yo+3,279,99,11,ci,ci
' Up Arrow
RBOX xo+7,yo+7,42,42,12,cb,cb:RBOX xo+9,yo+9,38,38,10,ck,ck
circle xo+28,yo+29,10,1,1,cf,cf:circle xo+23,yo+32,7,1,1,cf,cf:circle xo+33,yo+32,7,1,1,cf,cf:circle xo+28,yo+23,7,1,1,cf,cf:circle xo+18,yo+35,4,1,1,cf,cf:circle xo+38,yo+35,4,1,1,cf,cf:circle xo+28,yo+17,4,1,1,cf,cf
PIXEL xo+20,yo+39,cf:pixel xo+36,yo+39,cf:pixel xo+20,yo+24,cf:pixel xo+36,yo+24,cf:pixel xo+23,yo+19,cf:pixel xo+33,yo+19,cf
'Down arrow
RBOX xo+7,yo+55,42,42,12,cb,cb:RBOX xo+9,yo+57,38,38,10,ck,ck
circle xo+28,yo+75,10,1,1,cf,cf:circle xo+23,yo+72,7,1,1,cf,cf:circle xo+33,yo+72,7,1,1,cf,cf:circle xo+28,yo+81,7,1,1,cf,cf:circle xo+18,yo+69,4,1,1,cf,cf:circle xo+38,yo+69,4,1,1,cf,cf:circle xo+28,yo+87,4,1,1,cf,cf
PIXEL xo+20,yo+65,cf:pixel xo+36,yo+65,cf:pixel xo+20,yo+80,cf:pixel xo+36,yo+80,cf:pixel xo+23,yo+85,cf:pixel xo+33,yo+85,cf
'Go
RBOX 100,150,120,70,14,cb,cb:RBOX 103,153,114,64,11,ck,ck:text 115,160,"GO!",,1,4,cf,ck
do
Msg=" "+str$(lvl)+" x "+str$(lvl+1)
text xo+58,yo+24,Msg,,1,4,cb,ci
GetTouch
if xp>=xo and xp<=50+xo and yp>=yo and yp<=yo+100 then
' this is up or down
if yp<yo+50 then
lvl=lvl-1
if lvl<1 then lvl=1
else
lvl=lvl+1
if lvl>8 then lvl=8
endif
elseif xp>=100 and xp<=220 and yp>=150 and yp<=220 then
' this is GO button
exit do
endif
loop
end sub
'CLS:RBOX 2,6,285,105,14,cb,cb:RBOX 5,9,279,99,11,ck,ck:text 60,30,"Level 5",,1,4,cf,ci:RBOX 9,13,42,42,14,cb,cb:RBOX 11,15,38,38,12,ck,ck:RBOX 9,61,42,42,14,cb,cb:RBOX 11,63,38,38,12,ck,ck
LevelConfigData:
DATA 65535,15 'Cyan (full blue + green
DAta 16711680,8 '9 causes artefacts Red
data 16776960,5 '6 causes artefacts Yellow (Full Red + Green)
data 16711935,3 '4 causes artefacts Magenta (Pink = full red and blue)
data 65280,3 'Green
data 16777215,2 'White
data 255,2 'Blue
' data 16744448,1 'Burnt red
data 8388479,1 ' Bright Green (full Green + 50% red and blue)
' data 8355711,1 ' Grey (50%)
' data 16777087,1 ' Light Brown/orange? (Full Red and Green + 50% blue
Requires touch, and the only way to exit is reset button or break key (if enabled)
Please let me know if you have any problems with it.
If anyone is really interested, I will tidy up a lot more (e.g. better scalable fonts related to resolution, more detailed comments and exit-ability) and re-post
PhilEdited by flip 2017-03-13
panky
Posted: 05:16pm 13 Mar 2017
Phil,
Works a treat on a MMExtreme 144 running 5.03.12 into a 7" LCD display.
Well done!
Cheers,
Doug.
davematt
Posted: 02:31pm 17 Mar 2017
Hi Phil, many thanks for this, ran first time on 7in screen using E64.
I have very poor short term memory, so something easy was a great place to start. Would really like some way to measure my performance and (hopefully) progress. I will have a go myself, but if you have some ideas, that would be great...
Cheers, Dave
