Local Time 06:06 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Noob trying to get started with E-100
Tinine
Posted: 08:44am 11 Mar 2017
Hey guys,
So I have the module connected via USB but I can't seem to make it work.
I am on XP and in Device Manager under Other Devices, I have "Micromite Plus" but with a question mark over the icon. Am I missing a driver or something?
Cheers!
Tinine
Phil23
Posted: 10:39am 11 Mar 2017
Yes you are missing the USB Driver.
You can get it at the bottom of this page.
Tinine
Posted: 11:00am 11 Mar 2017
DOH!!! You would think it would be in the other downloads section
Many thanks for pointing me in the right direction...it's alive!
Posted: 11:07am 11 Mar 2017
  Tinine said   DOH!!! You would think it would be in the other downloads section
Good point, I will fix that.
Tinine
Posted: 08:59am 14 Mar 2017
  Geoffg said
Good point, I will fix that.Geoff
Hi Geoff,
Unless I missed it, I'd also like to suggest mention of the links required in order to use the COM3 Rx and Tx on the Mikrobus. That one had me scratching my head until I searched the forum.
Absolutely loving the E-100 and MM+, by the way. My project is a machine control system that is for one of my customers so I had to pick something that I had confidence in. This fits the bill perfectly.
Many thanks to you and all other developers and supporters.
MM Edit is also very, very nice!
Tinine.
