Local Time 06:06 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : EGT.BAS problems
oldtimer
Posted: 04:25pm 08 Mar 2017
Hi Peter
Im trying to get your EGT gauge working on a 28 pin MM - running Ver 5.2 but am having no success so far-
when I load the egt.bas file - the following error is returned
" CPU exception #6 at address 0xA0001458
Processor restarted"
>Im assuming that's because there is no MCP342 ADC or DS 18B20 attached or the code is not usable on an ILI 9341 LCD panel
Would it be possible to provide a wiring diagram of how you connected the ADC and Temp sensor and the I/O pin numbers you used to get the gauge operating - my end plan is to use the gauge and associated code to indicate OAT in an aircraft
Could you also tell me what that error actually means - I seem to get it a lot when attempting to run codes with c functions attached
many thanks
palcal
Posted: 06:52pm 09 Mar 2017
Don't know that file but I think you probably need an SSD1963 display and MM+.
see this thread. Gauges
Paul.
Posted: 11:26pm 09 Mar 2017
  Quote  I'm trying to get your EGT gauge working
Please provide a link to the thread/code you are talking about
oldtimer
Posted: 02:11am 10 Mar 2017
Hi Peter
Many thanks for your reply
The post I refer to is on page 3 of a set of poste relating to " searching for the perfect gauge" - your last post is dated 04 June 15 @1115
in that post you described an EGT gauge and an attached zip file - named 2015-06-04-111036 -EGT.ZIP and mentioned it was a fully functioning EGT
I note it also requires the addition of an MCP342x and a DS18B20 temp sensor
when I ran the unzipped file - I got the "cpu execption" error I mentioned in my first post
could you tell me if its possible to use a 28 pin MM - VER 5.2 with ILI9341 backpack to run the code and achieve a functioning EGT gauge and also what the" cpu execption - processor restarted " errors mean
Ive attached the code for your info
many thanks
Bill Winefield
' K-type thermocouple conversion using MCP342x ADC and DS18B20 for coldjunction compensation
cpu 48
option explicit
option default integer
Const stepsize=1
const maxgauges=1
const maxtemp=1000
const mintemp=550
dim integer x(maxgauges), y(maxgauges), radius(maxgauges), fontsize(maxgauges)
dim integer lastx1(maxgauges), lastx2(maxgauges), lastx3(maxgauges), lasty1(maxgauges), lasty2(maxgauges), lasty3(maxgauges)
dim integer whitesec(maxgauges),greensec(maxgauges),yellowsec(maxgauges),redsec(maxgauges),blacksec(maxgauges)
dim s$
const ADCBits16=&B10001000
const ADCbits16timeout= 15
'max voltages gain 8 = +/- 0.256V
const signed=1
const unsigned=0
const zeroOffset=90 'the thermocouple table starts at -90 degrees C so we offset the table lookup by this
' Pin assignment
const DS18B20pin=43
const ADCi2c = &B1101000 ' set to match your hardware, NB base address is same as DS1307
dim i as integer,coldjunction as integer,adccount as integer, coldjunctionequiv as integer,temperature as integer
dim ktype(1090) as integer
dim testvoltage as float
INIT:
i2c open 400,1000
i=ktable() 'read in the therocouple lookup table
if i<>1 then end 'must be something wrong with the data table
initgauge(0,mm.hres\2,mm.vres\2,mm.hres\2-5,1,-150,-150,105,105,150,"EGT",15)
MAIN:
do
temperature=gettemp(0,DS18B20pin) 'ADC input pins shorted so should record cold junction temperature
s$=str$(temperature,4)
needle(0,max((temperature-550)*2\3-150,-150),rgb(white),s$)
pause 500
loop
end
function max(a as integer, b as integer) AS INTEGER
IF a> b then
max= a
else
max=b
endif
END FUNCTION
function gettemp(ADCchannel as integer, coldjunctionpin as integer)
coldjunction=cint(ds18b20(coldjunctionpin))
coldjunctionequiv=ktype(coldjunction+zeroOffset)'get the number of ADC counts that the cold junction temperature would represent
' print "Coldjunction temperature is ",coldjunction," ADC equivalent is ",coldjunctionequiv
adccount=readadcraw16x8(ADCchannel) 'Measure thermocouple voltage with gain of 8 and 16 bits to give adequate resolution
adccount=adccount+coldjunctionequiv 'add in the cold junction temperature equivalent
temperature=findadc(adccount)
gettemp=temperature
end function
function findadc(adcnum as integer) 'just does a simple binary chop of the ADC count table to find the nearest entry
local top as integer, bottom as integer, work as integer, test as integer
top=1089
bottom=0 'set up search limits
if ktype(1089)<adcnum then
findadc=2000 'above range
exit function
endif
if ktype(0)>adcnum then
findadc=-2000 'below range
exit function
endif
do while top>bottom+1
work=(top+bottom)\2
test=ktype(work)
if test=adcnum then
findadc=work-zerooffset
end function
endif
if test> adcnum then
top=work
else
bottom=work
endif
loop
if (ktype(top)-adcnum)>=(adcnum-ktype(bottom)) then
findadc=bottom-zerooffset
else
findadc=top-zerooffset
endif
end function
function readadcraw16x8(channel as integer)
' config byte for chip is:
' bits 0 and 1 - Gain = 8
' bits 2 and 3 - # of bits = 16; 15 samples per second respectively
' bit 4 - 0=one-shot conversion ; we will always use 0 to allow changes to config e.g. which channel
' bits 5 and 6 - channel number 0-3
' bit 7 - set to start conversion, wait for clear to indicate conversion end
' max voltage for gain 8 = +/- 0.256V
local channelmask as integer,gainmask as integer, scratch as integer, timeout as integer
local configbyte as integer
local ADCret$ length 4
if channel<0 or channel>3 then
readadcraw16x8=100000000 'impossible value
exit function
endif
gainmask=3 'Gain of 8
timeout=ADCbits16timeout
configbyte=ADCbits16 or gainmask
channelmask=channel << 5
configbyte=configbyte or channelmask
i2c write ADCi2c, 0,1,configbyte
do
pause 5
i2c read ADCi2c, 0,4,ADCret$
scratch =asc(right$(ADCret$,1)) AND &B10000000
timeout=timeout-1
loop until (scratch=0) or (timeout=0)
if timeout <>0 then
readadcraw16x8=intconv(left$(ADCret$,2),signed)
else
readadcraw16x8=200000000 'impossible value
endif'
end function
function ktable()
' This table gives the ADC counts at 16 bits resolution and gain of 8 for every temperature from -90 to 1000 degrees C
data 65121,65125,65129,65133,65137,65141,65146,65150,65154,65158, 65162,65166,65171,65175,65179,65183,65188,65192,65196,65201, 65205,65209,65214,65218,65222,65227,65231,65236,65240
data 65244,65249,65253,65258,65262,65267,65271,65276,65281,65285, 65290,65294,65299,65303,65308,65313,65317,65322,65326,65331, 65336,65341,65345,65350,65355,65359,65364,65369,65374
data 65378,65383,65388,65393,65398,65402,65407,65412,65417,65422, 65427,65432,65436,65441,65446,65451,65456,65461,65466,65471, 65476,65481,65486,65491,65496,65501,65506,65511,65516,65521, 65526,65531
data 0,5,10,15,20,25,30,35,41,46,51,56,61,66,71,76,82,87,92,97,102,107,113,118,123,128,133,138,144,149,154,159,164,170
data 175,180,185,191,196,201,206,212,217,222,227,233,238,243,248, 254,259,264,270,275,280,285,291,296,301,307,312,317,322,328, 333,338,344,349,354,360
data 365,370,376,381,386,392,397,402,408,413,418,423,429,434,439, 445,450,455,461,466,471,477,482,487,493,498,503,508,514,519, 524,530,535,540,546,551,556,561,567,572
data 577,582,588,593,598,604,609,614,619,625,630,635,640,646,651, 656,661,666,672,677,682,687,692,698,703,708,713,718,724,729, 734,739,744,750,755,760,765,770,775,781
data 786,791,796,801,806,811,817,822,827,832,837,842,847,852,858, 863,868,873,878,883,888,894,899,904,909,914,919,924,929,934, 940,945,950,955,960,965,970,975,980,985
data 991,996,1001,1006,1011,1016,1021,1026,1032,1037,1042,1047,1052,1057,1062,1067,1072,1078,1083,1088,1093,1098,1103,1108,11 13,1119,1124,1129,1134,1139,1144,1149,1155,1160,1165,1170,1175,1180,1186
data 1191,1196,1201,1206,1211,1217,1222,1227,1232
data 1237,1242,1248,1253,1258,1263,1268,1274,1279,1284,1289,1294
data 1300,1305,1310,1315,1320,1326,1331,1336,1341,1347,1352,1357, 1362,1368,1373,1378,1383,1389,1394,1399,1404,1410,1415,1420, 1425,1431,1436,1441,1446,1452,1457,1462,1468,1473,1478,1483, 1489,1494,1499,1504
data 1510,1515,1520,1526,1531,1536,1542,1547,1552,1557,1563,1568, 1573,1579,1584,1589,1594,1600,1605,1610,1616,1621,1626,1632, 1637,1642,1648,1653,1658,1664,1669,1674,1680,1685,1690,1696, 1701,1706,1712,1717
data 1722,1728,1733,1738,1744,1749,1754,1760,1765,1771,1776,1781, 1787,1792,1797,1803,1808,1813,1819,1824,1830,1835,1840,1846, 1851,1856,1862,1867,1873,1878,1883,1889,1894,1899,1905,1910, 1916,1921,1926,1932
data 1937,1942,1948,1953,1959,1964,1969,1975,1980,1985,1991,1996, 2002,2007,2012,2018,2023,2029,2034,2039,2045,2050,2056,2061, 2066,2072,2077,2083,2088,2093,2099,2104,2110,2115,2120,2126, 2131,2137,2142,2148
data 2153,2158,2164,2169,2175,2180,2185,2191,2196,2202,2207,2212, 2218,2223,2229,2234,2240,2245,2250,2256,2261,2267,2272,2278, 2283,2289,2294,2299,2305,2310,2316,2321,2327,2332,2337,2343, 2348,2354,2359,2365
data 2370,2375,2381,2386,2392,2397,2403,2408,2414,2419,2424,2430, 2435,2441,2446,2452,2457,2463,2468,2473,2479,2484,2490,2495, 2501,2506,2512,2517,2522,2528,2533,2539,2544,2550,2555,2561, 2566,2572,2577,2582
data 2588,2593,2599,2604,2610,2615,2621,2626,2632,2637,2642,2648, 2653,2659,2664,2670,2675,2681,2686,2692,2697,2702,2708,2713, 2719,2724,2730,2735,2741,2746,2752,2757,2762,2768,2774,2779, 2784,2790,2795,2801
data 2806,2812,2817,2823,2828,2834,2839,2844,2850,2855,2861,2866, 2872,2877,2883,2888,2894,2899,2904,2910,2915,2921,2926,2932, 2937,2943,2948,2954,2959,2964,2970,2975,2981,2986,2992,2997, 3003,3008,3014,3019
data 3025,3030,3035,3041,3046,3052,3057,3063,3068,3074,3079,3084, 3090,3095,3101,3106,3112,3117,3123,3128,3133,3139,3144,3150, 3155,3161,3166,3172,3177,3182,3188,3193,3199,3204,3210,3215, 3220,3226,3231,3237
data 3242,3248,3253,3259,3264,3270,3275,3280,3286,3291,3297,3302, 3308,3313,3318,3324,3329,3335,3340,3345,3351,3356,3362,3367, 3373,3378,3383,3389,3394,3400,3405,3410,3416,3421,3427,3432, 3438,3443,3448,3454
data 3459,3465,3470,3475,3481,3486,3492,3497,3502,3508,3513,3519, 3524,3529,3535,3540,3546,3551,3556,3562,3567,3573,3578,3583, 3589,3594,3599,3605,3610,3616,3621,3626,3632,3637,3643,3648, 3653,3659,3664,3670
data 3675,3680,3686,3691,3696,3702,3707,3712,3718,3723,3729,3734, 3739,3745,3750,3755,3761,3766,3771,3777,3782,3787,3793,3798, 3804,3809,3814,3820,3825,3830,3836,3841,3846,3852,3857,3862, 3868,3873,3878,3884
data 3889,3894,3900,3905,3910,3916,3921,3926,3932,3937,3942,3948, 3953,3958,3963,3969,3974,3979,3985,3990,3995,4001,4006,4011, 4017,4022,4027,4033,4038,4043,4048,4054,4059,4064,4070,4075, 4080,4085,4091,4096
data 4101,4106,4112,4117,4122,4128,4133,4138,4143,4149,4154,4159, 4165,4170,4175,4180,4186,4191,4196,4201,4207,4212,4217,4222, 4228,4233,4238,4243,4249,4254,4259,4264,4270,4275,4280,4285, 4291,4296,4301,4306
data 4312,4317,4322,4327,4333,4338,4343,4348,4354,4359,4364,4369, 4374,4380,4385,4390,4395,4401,4406,4411,4416,4421,4426,4432, 4437,4442,4447,4453,4458,4463,4468,4473,4479,4484,4489,4494, 4499,4505,4510,4515
data 4520,4525,4530,4536,4541,4546,4551,4556,4562,4567,4572,4577, 4582,4587,4593,4598,4603,4608,4613,4618,4623,4629,4634,4639, 4644,4649,4654,4660,4665,4670,4675,4680,4685,4690,4696,4701, 4706,4711,4716,4721
data 4726,4732,4737,4742,4747,4752,4757,4762,4767,4773,4778,4783, 4788,4793,4798,4803,4808,4814,4819,4824,4829,4834,4839,4844, 4849,4854,4860,4865,4870,4875,4880,4885,4890,4895,4900,4905, 4910,4915,4921,4926
data 4931,4936,4941,4946,4951,4956,4961,4966,4971,4976,4982,4987, 4992,4997,5002,5007,5012,5017,5022,5027,5032,5037,5042,5047, 5052,5057,5062,5068,5073,5078,5083,5088,5093,5098,5103,5108, 5113,5118,5123,5128
data 5133,5138,5143,5148,5153,5158,5163,5168,5173,5178,5183,5188, 5193,5198,5203,5208,5213,5218,5223,5228,5233,5238,5243,5248, 5253,5258,5263,5268,5273,5278
Local i,j
j=-420 ' 5 less than lowest value in the table
ktable=1
for i= 0 to 1089
read ktype(i)
if ktype(i)>32767 then ktype(i)=ktype(i)-65536
if (ktype(i)-j) <4 or (ktype(i)-j) >7 then ktable=0 'check no errors in table
j=ktype(i)
next i
end function
Sub segment(x As integer, y As integer, outsize As integer, startradial As integer, endradial As integer, col As integer, insize as integer )
Local integer i,j,x1,x2,y1,y2,sr,er,xx0(1),yy0(1),xx1(1),yy1(1),xx2(1),yy2(1),tcol(1)
If startradial=endradial Then
x2=Sin(Rad(startradial))*outsize + x
y2=-Cos(Rad(startradial))*outsize + y
x1=Sin(Rad(startradial))*insize + x 'insize is 0 if not specified so a complete line from the centre is drawn
y1=-Cos(Rad(startradial))*insize + y
Line x1,y1,x2,y2,,col
Else
If startradial<endradial Then
sr=startradial
er=endradial
Else
er=startradial
sr=endradial
EndIf
For i=sr+stepsize To er Step stepsize
x2=Sin(Rad(i))*outsize + x
y2=-Cos(Rad(i))*outsize + y
x1=Sin(Rad(i-stepsize))*outsize + x
y1=-Cos(Rad(i-stepsize))*outsize + y
xx0(0)=x
yy0(0)=y
xx1(0)=x1
yy1(0)=y1
xx2(0)=x2
yy2(0)=y2
tcol(0)=col
j=triangles(1,xx0(),yy0(),xx1(),yy1(),xx2(),yy2(),tcol())
Next i
EndIf
End Sub
sub initgauge(gaugeindex% , xpos%, ypos%, gsize%, fontmult%, whitestart%, greenstart%, yellowstart%, redstart%, blackstart%, displaystring$, tickspace%)
local ticks%
Circle xpos%,ypos%,gsize%+3,0,,RGB(210,210,210),RGB(210,210,210) 'background to create the bezel
segment(xpos%,ypos%,gsize%,whitestart%,greenstart%, RGB(white),0)
segment(xpos%,ypos%,gsize%,greenstart%,yellowstart%, RGB(green),0)
segment(xpos%,ypos%,gsize%,yellowstart%,redstart%, RGB(yellow),0)
segment(xpos%,ypos%,gsize%,redstart%,blackstart%, RGB(red),0)
segment(xpos%,ypos%,gsize%,blackstart%,whitestart%+360, 0)
segment(xpos%,ypos%,gsize%,greenstart%,greenstart%, 0)
segment(xpos%,ypos%,gsize%,yellowstart%,yellowstart%, 0)
segment(xpos%,ypos%,gsize%,redstart%,redstart%, 0)
if tickspace% then
for ticks%=whitestart% to blackstart% step tickspace%
segment(xpos%,ypos%,gsize%,ticks%,ticks%, 0, (gsize%*19)\20)
next ticks%
endif
Circle xpos%,ypos%, (gsize%*4)\5,0,,0,0
text xpos%-len(displaystring$)*4*fontmult%,ypos%+gsize%-fontmult%*28,displaystring$ ' string centred in black segment
x(gaugeindex%)=xpos%
y(gaugeindex%)=ypos%
radius(gaugeindex%)=gsize%
fontsize(gaugeindex%)=fontmult%
lastx1(gaugeindex%)=xpos%
lastx2(gaugeindex%)=xpos%+2
lastx3(gaugeindex%)=xpos%+2
lasty1(gaugeindex%)=ypos%
lasty2(gaugeindex%)=ypos%+2
lasty3(gaugeindex%)=ypos%
whitesec(gaugeindex%)=whitestart%
greensec(gaugeindex%)=greenstart%
yellowsec(gaugeindex%)=yellowstart%
redsec(gaugeindex%)=redstart%
blacksec(gaugeindex%)=blackstart%
end sub
' Routine to draw a pointer
' Parameters are:
' gaugeindex
' radial of pointer to be drawn (0-360 degrees)
' colour to draw pointer
Sub needle(gaugeindex as integer, angle As integer, col As integer, value$ as string)
Local integer x1,y1,x2,y2,x3,y3,x4,y4,j, xx1(1),yy1(1),xx2(1),yy2(1),xx3(1),yy3(1), tcol(1), size
size= (radius(gaugeindex)*4)\5-1
x1=Sin(Rad(angle-90))*size/10 + x(gaugeindex)
y1=-Cos(Rad(angle-90))*size/10 + y(gaugeindex)
x2=Sin(Rad(angle))*size + x(gaugeindex)
y2=-Cos(Rad(angle))*size + y(gaugeindex)
x3=Sin(Rad(angle+90))*size/10 + x(gaugeindex)
y3=-Cos(Rad(angle+90))*size/10 + y(gaugeindex)
xx1(0)=lastx1(gaugeindex)
yy1(0)=lasty1(gaugeindex)
xx2(0)=lastx2(gaugeindex)
yy2(0)=lasty2(gaugeindex)
xx3(0)=lastx3(gaugeindex)
yy3(0)=lasty3(gaugeindex)
xx1(1)=x1
yy1(1)=y1
xx2(1)=x2
yy2(1)=y2
xx3(1)=x3
yy3(1)=y3
tcol(0)=0
tcol(1)=col
j=triangles(2,xx1(),yy1(),xx2(),yy2(),xx3(),yy3(),tcol())
Circle x(gaugeindex),y(gaugeindex),size\10,0,,col,col)
Circle x(gaugeindex),y(gaugeindex),size\15,0,,0,0
Circle x(gaugeindex),y(gaugeindex),size\20,0,,RGB(240,240,240),RGB(240,240,240)
lastx1(gaugeindex)=x1
lastx2(gaugeindex)=x2
lastx3(gaugeindex)=x3
lasty1(gaugeindex)=y1
lasty2(gaugeindex)=y2
lasty3(gaugeindex)=y3
text x(gaugeindex)-len(value$)*4*fontsize(gaugeindex)-3*fontsize(gaugeindex),y(gaugeindex)+radius(gaugeindex)-fontsize(gaugei ndex)*16,value$ ' string centred in black segment
End Sub
CFunction intconv 'convert data read from i2c to integer including extending sign bit across the 64 bit integer
00000000
27bdfff8 00001021 00001821 afa20000 afa30004 90880000 1900000b 01003821
2503ffff 03a31821 24020001 00823021 90c60000 a0660000 24420001 00e2302a
10c0fffa 2463ffff 8ca20000 1040000d 03a81021 9042ffff 30420080 10400009
29020008 10400007 03a81021 27a40008 2403ffff a0430000 24420001 5444fffe
a0430000 8fa20000 8fa30004 03e00008 27bd0008
End CFunction
CFunction triangles
00000000
8c820004 27bdffa0 afbf005c afbe0058 afb70054 afb60050 afb5004c afb40048
afb30044 afb20040 afb1003c afb00038 afa40060 afa50064 afa60068 184000e7
afa7006c afa00030 3c179d00 8fa30030 8fa50068 8fa80070 000310c0 00a22021
01021821 8c840000 8c630000 8fa90064 afa40018 01223821 afa3001c 8fa40074
8fa3006c 8fa80078 8fa9007c 00623021 00822821 01022021 01221021 8fa80018
8fa9001c 8cc60000 8ca50000 0128182a 8cf30000 8c9e0000 afa60028 afa5002c
10600006 8c540000 02601021 afa90018 00c09821 afa8001c afa20028 8fa5001c
03c5102a 10400008 8fa90018 8fa20028 8fa8002c afbe001c afa80028 00a0f021
afa2002c 8fa90018 8fa3001c 0069102a 10400008 8fa50018 8fa4001c 02601021
afa40018 8fb30028 afa9001c afa20028 8fa50018 10be007f 8fa3001c 107e009e
8fa40018 2463ffff 0064102a 1440002d 8fb00018 8fa80028 8fa9002c 8fa5001c
01134023 01334823 03c4a823 afbe0034 00a4b023 0280f021 afa80020 afa90024
00808021 00009021 00008821 0060a021 0236001a 02c001f4 8fa30024 8fa20020
02002821 02003821 02228821 26100001 00002012 0255001a 02a001f4 00932021
02439021 00003012 00d33021 00c4182a 10600003 00801021 00c02021 00403021
afbe0010 8ee20048 0040f809 00000000 0290102a 1040ffe6 00000000 03c0a021
8fbe0034 03d0102a 1440002f 8fa8001c 8fa90018 8fa4002c 8fa50028 0093a823
0085b023 02089023 02098823 03c91823 03c81023 72569002 72358802 afb40018
afb5001c afb60020 0260a821 00a0b021 00609821 0040a021 0254001a 028001f4
8fa3001c 8fa20020 02002821 02003821 02429021 26100001 00002012 0233001a
026001f4 00962021 02238821 00003012 00d53021 00c4182a 10600003 00801021
00c02021 00403021 8fa80018 afa80010 8ee20048 0040f809 00000000 03d0102a
1040ffe5 00000000 8fa90030 8fa20060 25290001 8c430004 000917c3 0043202a
1480ff5a afa90030 14620007 8fbf005c 8fa30060 8c620000 0122102b 5440ff54
8fa30030 8fbf005c 8fbe0058 8fb70054 8fb60050 8fb5004c 8fb40048 8fb30044
8fb20040 8fb1003c 8fb00038 03e00008 27bd0060 8fa80028 0113102a 14400023
02603821 0268102a 14400022 8fa70028 02603821 02602021 8fa9002c 0124102a
54400003 8fa4002c 00e9102a 0122380b 8fa20018 afb40010 00e23821 8fa50018
8ee20048 00803021 0040f809 00e43823 8fa90030 8fa20060 25290001 8c430004
000917c3 0043202a 1480ff28 afa90030 1000ffcd 00000000 0064102a 1040ff66
8fa80028 1000ff8f 8fb00018 1000ffe2 8fa40028 1000ffe0 02602021 1440ffca
8fbf005c 8c820000 5440ff17 afa00030 1000ffc6 8fbe0058
End CFunction 'MIPS32 M4Krom the code that it required the addition of
Posted: 02:25am 10 Mar 2017
This thread I think here
Posted: 04:33am 10 Mar 2017
It should run fine on a 28-pin and ILI9341 but you must either have the various peripherals connected or spoof vaguely valid data. Otherwise you are calling C routines with data that is probably completely inappropriate that they can't deal with.
Here is a Basic version of intconv that you can substitute that may make it easier to see what is happening. I suspect it is intconv causing the problem but you can check that with print statements and then pauses (to allow the text to output) before and after
Function intconv(s$, p%) as integer
local integer l,k,j,i=len(s$)
k=peek(varaddr j)
for l=1 to i
poke byte k+i-l,asc(mid$(s$,l,1))
next l
if p% then
if (asc(left$(s$,1)) and &H80) then
for l=i to 7
poke byte k+l,&HFF
next l
endif
endif
intconv=j
End Function
The various exception codes are given here but in general won't help you.
Edited by matherp 2017-03-11
