Local Time 01:36 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM, + and X - bilinear interpolation
cdeagle
Posted: 07:04am 08 Mar 2017
This post describes a MMBASIC subroutine that can be used to linearly interpolate user-provided tabular data of the form z = f(x, y). Although the program was written and debugged on the MMX 144 board, it should work on any MicroMite CPU.
Here's a typical example that illustrates how to interact with the subroutine and the results provide by the software. The interpolation error is the difference between the interpolated function value and the analytic solution evaluated at the user provided and x- and y interpolation values.
program demo_lint2
this program demonstrates the procedure for calling the
the subroutine interp2 which performs a bilinear
interpolation of tabular data of the form z = f(x,y)
input by the user.
note: the data must be ordered as follows:
x(1) < x(2) < x(3) < .... < x(n)
y(1) < y(2) < y(3) < .... < y(n)
this program demonstrates the use of interp2 for the
interpolation of the function defined by
z = f(x,y) = sin(x + y)
please input the number of x data points
(a minimum of two x data points must be input)
? 50
please input the number of y data points
(a minimum of two y data points must be input)
? 50
please input a value for delta-x
? .25
please input a value for delta-y
? .25
please wait, computing data points ...
please input the x value to interpolate
(this must be a value between 0.25 and 12.5
? 9.67845
please input the y value to interpolate
? 5.555
program demo_lint2
<linear interpolation of z = f(x,y)>
number of x data points = 50
number of y data points = 50
x interpolated value = 9.67845
y interpolated value = 5.555
function value = 0.451586
interpolation error = 0.00531957
Here's the MMBASIC source code for the demo program and bilinear subroutine.
' demo_lint2.bas March 8, 2017
' this program demonstrates the procedure for calling
' the subroutines interp2 which performs a bilinear
' interpolation of tabular data of the form z = f(x,y)
' input by the user.
' note: the data must be ordered as follows:
' x(1) < x(2) < x(3) < .... < x(n)
' y(1) < y(2) < y(3) < .... < y(n)
' this program demonstrates the use of interp2 for the
' interpolation of the function defined by
' z = f(x,y) = sin(x + y)
print " "
print "program demo_lint2"
print " "
print "this program demonstrates the procedure for calling the"
print "the subroutine interp2 which performs a bilinear"
print "interpolation of tabular data of the form z = f(x,y)"
print "input by the user."
print " "
print "note: the data must be ordered as follows:"
print " "
print "x(1) < x(2) < x(3) < .... < x(n)"
print "y(1) < y(2) < y(3) < .... < y(n)"
print " "
print "this program demonstrates the use of interp2 for the"
print "interpolation of the function defined by"
print " "
print " z = f(x,y) = sin(x + y)"
do
print " "
print "please input the number of x data points"
print "(a minimum of two x data points must be input)"
input nx%
loop until (nx% >= 2)
do
print " "
print "please input the number of y data points"
print "(a minimum of two y data points must be input)"
input ny%
loop until (ny% >= 2)
do
print " "
print "please input a value for delta-x"
input dx
loop until (dx > 0.0)
do
print
print "please input a value for delta-y"
input dy
loop until (dy > 0.0)
' dimension arrays
dim x(nx%) as float, y(ny%) as float, z(nx%, ny%) as float
print " "
print "please wait, computing data points ..."
' compute data points for the function defined by
' z = f(x, y) = sin(x + y)
' where x = dx * i and y = dy * j
' for i = 1, 2, ... nx and j = 1, 2, ... ny
for i% = 1 to nx%
x(i%) = i% * dx
for j% = 1 to ny%
y(j%) = j% * dy
z(i%, j%) = sin(x(i%) + y(j%))
next j%
next i%
do
print " "
print "please input the x value to interpolate"
print "(this must be a value between ", x(1), " and ", x(nx%)
input xval
loop until (xval >= x(1) and xval <= x(nx%))
do
print " "
print "please input the y value to interpolate"
print "(this must be a value between ", y(1), " and ", y(ny%)
input yval
loop until (yval >= y(1) and yval <= y(ny%))
' perform bilinear interpolation
interp2(nx%, ny%, xval, yval, fval)
print " "
print " "
print "<linear interpolation of z = f(x,y)>"
print " "
print "number of x data points = ", nx%
print " "
print "number of y data points = ", ny%
print " "
print "x interpolated value = ", xval
print " "
print "y interpolated value = ", yval
print " "
print "function value = ", fval
print " "
print "interpolation error = ", abs(fval - sin(xval + yval))
print " "
end
sub interp2 (nx%, ny%, xval, yval, zval)
' bilinear interpolation subroutine
' z = f(x, y)
' input
' nx% = number of x data points (nx% >= 2)
' ny% = number of y data points (ny% >= 2)
' x() = vector of x data (nx% rows)
' y() = vector of y data (ny% rows)
' z() = array of z data (nx% rows by ny% columns)
' xval = x interpolation argument
' yval = y interpolation argument
' output
' zval = z function value at xval, yval
local g1, g2, xinfac, yinfac
' compute x index and interpolation factor
for i% = 1 to nx%
if (xval <= x(i%)) then
if (i% = 1) then
xinfac = 0.0
indexx% = 1
else
j% = i% - 1
xinfac = (xval - x(j%)) / (x(i%) - x(j%))
indexx% = j%
end if
exit for
end if
next i%
' compute y index and interpolation factor
for i% = 1 to ny%
if (yval <= y(i%)) then
if (i% = 1) then
yinfac = 0.0
indexy% = 1
else
j% = i% - 1
yinfac = (yval - y(j%)) / (y(i%) - y(j%))
indexy% = j%
end if
exit for
end if
next i%
g1 = z(indexx%, indexy%) + xinfac * (z(indexx% + 1, indexy%) - z(indexx%, indexy%))
g2 = z(indexx%, indexy% + 1) + xinfac * (z(indexx% + 1, indexy% + 1) - z(indexx%, indexy% + 1))
zval = g1 + yinfac * (g2 - g1)
end sub
Tinine
Posted: 12:38pm 10 Mar 2017
Very cool!
Many thanks
