Local Time 01:14 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Several 1 Wire Devices on one BUS
atmega8
Posted: 06:37am 03 Mar 2017
Hello,
i have several one wire devices on one bus.
One DS 18B20 and one DS 2438 on one printed circuit.
It is part of a home automation.
I will connect up to 10 of this printed circuits on the same bus.
Has anyone a stable working code/sample for reading and printing the values of the DS18B20 and the thre values of the DS2438 internal temperature and the two analog AD Inputs ?
Thank you very much for your support!
Atmega8 Edited by atmega8 2017-03-04
Phil23
Posted: 01:33pm 03 Mar 2017
I've got 2 different MM's with around 6? DS18B20's on the same bus.
It should be possible to modify the code to read the DS2438's as well.
There's a stack of post, but this one has most of the complete code.
Phil.
Zonker
Posted: 04:36pm 03 Mar 2017
With extra room in the MZ cores, is it possible to "add" the search function, (maybe as something you can store in the library) back in..? I'm not to sure if anyone wants it, but, could you then just plug the next device onto the bus and have it connect up "automagically" ..?
atmega8
Posted: 12:05pm 04 Mar 2017
I remember there was a discussion with Geoff, these functions did not fit anymore in the MX...
I think Geoff had the code already.
Now with the new MZ, no problem of space.
Since 1Wire in home automation and bus systems with dozen of different 1Wire devices it would open the home automation world also for Mmbasic.
Really a god argument for putting this back in the MM+ code.
What do you think?
Atmega8
Posted: 12:33pm 04 Mar 2017
  Quote  With extra room in the MZ cores, is it possible to "add" the search function
It is in the MZ code - no idea how to use it or if it works
Zonker
Posted: 03:02am 05 Mar 2017
Sweet Peter..!! I had no idea..!
When the MMX board get here, I will give this a try..
Thanks..!
atmega8
Posted: 05:37am 05 Mar 2017
What does it mean it's "in the code" ?
THX
Posted: 06:04am 05 Mar 2017
  Quote  What does it mean it's "in the code" ?
It means I've enabled the conditional compilation and the firmware responds to "onewire search" I assume the syntax is as per the colour maximite which is clunky as that version doesn't have 64-bit integers
atmega8
Posted: 11:16am 06 Mar 2017
Ok, waiting for Zonkers feed back ;-)...
atmega8
Posted: 10:59am 08 Mar 2017
did anyone try the search function?
Zonker
Posted: 12:55am 09 Mar 2017
My MMX boards have not arrived yet... Should be soon..!
atmega8
Posted: 08:06am 16 Mar 2017
news from zonker ??
Posted: 04:06am 19 Mar 2017
I've re-engineered and tested the onewire search facility for the MMX. Originally ONEWIRE SEARCH was a command and it returned the ID as 8 floating point variables. This was because of the limitation in the Maximite of all variables being 32-bit floating point numbers. In the Micromite we now have 64-bit integers - perfect for onewire IDs so search can now be a FUNCTION and, I hope it is agreed it much more logical.
The syntax is
id% = owsearch(pin, flag [,serial_number_mask)
Flags are:
0 - Continue an existing search
1 - start a new search
4 - Continue an existing search for devices in the requested family
5 - start a new search for devices in the requested family (the MSB of the serial_number_mask)
8 - skip the current device family and return the next device
16 - verify that the device with the serial number in serial_number_mask is available
The system variable MM.ONEWIRE is maintainted as expected (1=success, 0=failure/no result)
  Quote  Micromite eXtreme MMBasic Ver 5.03.15 @ 200MHz
Copyright 2011-2017 Geoff Graham
Copyright 2016-2017 Peter Mather
> ? hex$(owsearch(113,1))'start a new search
2861F7F504000073
> ? hex$(owsearch(113,0))'Continue the search
285D70BF030000F8
0
> ? hex$(owsearch(113,16,&H285D70BF030000F8))'Check for a specific device
2861F7F504000073
> ? hex$(owsearch(113,16,&H285D70BF030000F7))'Check for a specific device
0
> ? hex$(owsearch(113,5,&H2900000000000000))'Search for a particular family
0
> ? hex$(owsearch(113,5,&H2800000000000000))'Search for a particular family
2861F7F504000073
> ? hex$(owsearch(113,4,&H2800000000000000))'Continue the search for a particular family
285D70BF030000F8
2861F7F504000073
> ? hex$(owsearch(113,8))'Skip to the next family
0
The new function is included in MMX V5.3.15 Edited by matherp 2017-03-20
Phil23
Posted: 10:04am 19 Mar 2017
With regards to 1-Wire search on other MM's.
JMan wrote this a while back & initially it seemed to work.
But on further investigation I found it only found some of the devices on the bus, not all of them.
As if it was terminating early.
Seemed Ok with 3 particular DS18B20 but if I added more to the initial 3 things responded unpredictably.
Wondering if you might spot the issue while the search logic is fresh in you mind.
Phil.
Edit:-
It would really great @pmather is you could export you MMX function as an external function for the other MM's.
But I don't know how demanding a task that is.
[Code]'1-Wire Serial Number Search - Multiple Devices Attached.
'Code by Jman 04 April 2016
Option Explicit
Dim A%, PinNbr
Dim id_bit, cmp_id_bit, LastDeviceFlag, Last_zero
Dim search_direction, id_bit_number, LastDiscrepancy
Dim DeviceCount, ROM_NO(8)
Dim LastFamilyDiscrepancy, I, J
PinNbr = 16
Device_loop: 'Device loop: loop for all devices on the bus
OneWire Reset Pinnbr
If LastDeviceFlag = 1 Then Print "--Done--": End
id_bit_number = 1
last_zero = 0
OneWire Write PinNbr,1,1,&HF0 'Send the Search ROM command (FO)
Check_bit:
OneWire Read PinNbr, 4 , 2, id_bit, cmp_id_bit 'Get response from device
If (id_bit = 1 And cmp_id_bit = 1) Then GoTo No_device
If Not ((id_bit = 0) And (cmp_id_bit = 0)) Then
search_direction = id_bit
I=Fix(((id_bit_number)-1)/8)
Rom_NO(I) = Rom_NO(I) << 1
ROM_NO(I) = Rom_no(I)+search_direction
EndIf
If ((id_bit = 0) And (cmp_id_bit = 0)) Then GoSub conflict
OneWire Write PinNbr,4,1,search_direction ' send 1 or 0 as search direction
id_bit_number = id_bit_number+1 ' incredement id_bit_number
If id_bit_number <= 64 Then GoTo Check_bit 'Check for next bit
If id_bit_number > 64 Then LastDiscrepancy = last_zero
If LastDiscrepancy = 0 Then LastDeviceFlag = 1
For i= 0 To 7
A%=Rom_no(I)
Rom_No(I) = ((A% * &h202020202) And &h10884422010) Mod 1023 'Thanks Rob
Next I
Print "Family ";Hex$(ROM_NO(0),2);"H"
Print "ID:", Hex$(ROM_NO(1),2),Hex$(ROM_NO(2),2),Hex$(ROM_NO(3),2),Hex$(ROM_NO(4),2),Hex$(ROM_NO(5),2),Hex$(ROM_NO(6),2)
Print "CRC:", Hex$(ROM_NO(7),2)
Print
deviceCount = deviceCount + 1
For J=0 To 7
Rom_no(J)=0
Next J
If LastDeviceFlag = 0 Then GoTo Device_loop
Print "DeviceCount";deviceCount, " device(s)."
Print "--Done--":End
NO_device: 'Since both response bits are 11, there are no devices
Print " No devices present"
End
Conflict: 'id_bit_number = LastDiscrepancy then take "1" path
If (id_bit_number) = LastDiscrepancy Then
search_direction = 1
Rom_NO(I) = Rom_NO(I)+search_direction
EndIf
'id_bit_number > LastDiscrepancy then take the "0" path
If (id_bit_number > LastDiscrepancy) Then
search_direction = 0
ROM_NO(I) = ROM_NO(I)+search_direction
GoSub Family
EndIf
' id_bit_number < LastDiscrepancy then take same path as last time
If (id_bit_number < LastDiscrepancy) Then
search_direction = ROM_NO(I)
If search_direction = 0 Then GoSub Family
EndIf
Return
Family: 'LastFamilyDiscrepancy bit index set
Last_zero = id_bit_number
If last_zero <9 Then
LastFamilyDiscrepancy = last_zero
EndIf
Return
[/code]Edited by Phil23 2017-03-20
