Local Time 05:56 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : E100 Max Program Line Length
ion507
Posted: 11:19pm 27 Feb 2017
I'm getting into my first E100 project and I'm using single dimension arrays to hold data that gets loaded, depending on which menu selection is made. I want to be able to display a descriptive banner that will be unique for each value of X as I step through each timer sequence. The problem I have found is that I get "ERROR - line is too long" if I load from MMEdit with more than about 16 elements. I can abbreviate the banners to make it fit but longer, more descriptive banners are better. Is there a way of splitting this over several lines? I'm running V5.3B
DIM Series(X) AS STRING = ("BANNER_0", "BANNER_1", "BANNER_2", ....) ' Could be up to 20 elements
disco4now
Posted: 11:30pm 27 Feb 2017
Try this. Dimension the array but load the values individually.
Series(0)="BANNER_0"
Series(1)="BANNER_1"
etc
Gerry
F4 H7FotSF4xGT
ion507
Posted: 11:45pm 27 Feb 2017
At the moment X will be between 8 and 14. I did think of trying of trying to load half and half (the first 8 then the remaining elements on another line) but I can see that this won't work. I will have a look at data statements to see if I can use them in a FOR - NEXT loop.
Posted: 12:50am 28 Feb 2017
Gerry has coded the same 'outcome. as your OP, but you just need to use different index values. Unless there is other unknown information, this will overcome your issue.
Series(8)="BANNER_0"
Series(9)="BANNER_1"
etc
WWEdited by WhiteWizzard 2017-03-01
ion507
Posted: 01:33am 28 Feb 2017
Data statements didn't work as I expected so I will work with WW's solution to enter the elements of my Series() array. Thanks for your help.
Posted: 02:19am 28 Feb 2017
  ion507 said   Data statements didn't work as I expected so I will work with WW's solution to enter the elements of my Series() array. Thanks for your help.
you tried something like the below?
X=6
Dim S$(X) length 32
Data "first label", "second label", "this is the third"
Data "fourth one here", "number five is alive", "last label in list"
For I=1 To X
Read S$(I)
Next I
For I=1 To X
Print S$(I)
Next I
Print
Memory
End
> run
first label
second label
this is the third
fourth one here
last label in list
Flash:
1K ( 1%) Program (38 lines)
59K (99%) Free
RAM:
1K ( 1%) 3 Variables
0K ( 0%) General
49K (99%) Free
when defining arrays of strings it is wise to specify the maximum length of the strings in order to avoid chewing through all your free RAM. without specifying the maximum length, each string will default to consuming 255 bytes (plus overheads). so a 100 element array of strings will take up some 25k or RAM. with the maximum string length set to 16, this comes down to 1.6k or thereabouts.
note: there does seem to be something odd in the way arrays of strings are dimensioned. dim A$(6) as STRING LENGTH 32 seems to ignore the length specified (instead using the default of 255), and the "$" sign at the end is not mandatory.
rob :-)Edited by robert.rozee 2017-03-01
