Local Time 05:56 13 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DP math with the Micromite eXtreme
cdeagle
Posted: 07:18am 27 Feb 2017
In order to test the double precision feature of the MMX, I revisited a program that computes the geodesic between two locations on the earth.
The following is the user interaction and results from the MMX version of the code;
Micromite eXtreme results
program demo_geodesic
first location
please input the geographic latitude
(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])
(north latitudes are positive, south latitudes are negative)
? -37,57,3.7203
please input the geographic longitude
(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])
(east longitude is positive, west longitude is negative)
? 144,25,29.5244
second location
? -37,39,10.1561
? 143,55,35.3839
azimuth 1 to 2 306.86815923 degrees
azimuth 2 to 1 127.17363065 degrees
geodesic distance 54972.26931315 meters
For comparison I also ran the MATLAB version of the code. Like the MMX, MATLAB also performs all calculations in double precision. Here are the results produced by the MATLAB code using the same user inputs;
MATLAB results
geodesic distance and azimuths
azimuth from 1 to 2 306.86815923 degrees
azimuth from 2 to 1 127.17363065 degrees
The comparison is excellent.
The following is the source code listing of demo_geodesic.bas;
' demo_geodesic
' demonstrates how to interact with the geodesic.bas subroutine
' which computes the azimuths and geodesic distance between two
' locations on an oblate planet
' February 26, 2017
' conversion factor - radians to degrees
rtd = 57.295779513082323
' Earth equatorial radius (kilometers)
req = 6378.137
' Earth polar radius (kilometers)
rpolar = 6356.7523142
' Earth flattening factor (non-dimensional)
flat = 1.0 / 298.257223563
' request coordinates of first location
print
print "program demo_geodesic"
print
print "first location"
print
observer(obslat1, obslong1)
' request coordinates of second location
print
print "second location"
print
observer(obslat2, obslong2)
' compute azimuths and geodesic distance
geodesic(obslat1, obslat2, obslong1, obslong2, azim12, azim21, slen)
' display results
print
print
print
print "azimuth 1 to 2 ", str$(rtd * azim12, 0, 8), " degrees"
print "azimuth 2 to 1 ", str$(rtd * azim21, 0, 8), " degrees"
print
print "geodesic distance ", str$(1000.0 * slen, 0, 8), " meters"
print
end
sub geodesic(lat1, lat2, long1, long2, azim12, azim21, slen)
' relative azimuths and distance between two ground sites
' input
' lat1 = geodetic latitude of point 1 (radians)
' long1 = east longitude of point 1 (radians)
' lat2 = geodetic latitude of point 2 (radians)
' long2 = east longitude of point 2 (radians)
' output
' azim12 = azimuth from point 1 to 2 (radians)
' azim21 = azimuth from point 2 to 1 (radians)
' slen = geodesic distance from point 1 to 2
' (same units as req and rpolar)
' global
' flat = flattening factor (non-dimensional)
' req = equatorial radius
' rpolar = polar radius
' note
' azimuth is measured positive clockwise from north
l = long2 - long1
beta1 = atan3(rpolar * sin(lat1), req * cos(lat1))
beta2 = atan3(rpolar * sin(lat2), req * cos(lat2))
a = sin(beta1) * sin(beta2)
b = cos(beta1) * cos(beta2)
cosdelta = a + b * cos(l)
n = (req - rpolar) / (req + rpolar)
b2mb1 = (lat2 - lat1) + 2.0 * (a * (n + n ^ 2 + n ^ 3) - b * (n - n ^ 2 + n ^ 3)) * sin(lat2 - lat1)
tmp1 = sin(l) * cos(beta2)
tmp2 = sin(b2mb1) + 2.0 * cos(beta2) * sin(beta1) * sin(0.5 * l) ^ 2
sindelta = sqr(tmp1 ^ 2 + tmp2 ^ 2)
delta = atan3(sindelta, cosdelta)
if (delta > pi) then
delta = delta - pi
endif
if (delta = 0.0) then
slen = 0.0
return
endif
sdelta = sin(delta)
cdelta = cos(delta)
c = b * sin(l) / sdelta
m = 1.0 - c ^ 2
tmp3 = (flat + flat ^ 2) * delta - (0.5 * a * flat ^ 2) * (sdelta + 2.0 * delta ^ 2 / sdelta)
tmp4 = (0.25 * m * flat ^ 2) * (sdelta * cdelta - 5 * delta + 4 * delta ^ 2 / tan(delta))
lambda = l + c * (tmp3 + tmp4)
num = cos(beta2) * sin(lambda)
den = sin(b2mb1) + 2 * cos(beta2) * sin(beta1) * sin(0.5 * lambda) ^ 2
' azimuth from point 1 to point 2
azim12 = atan3(num, den)
num = -cos(beta1) * sin(lambda)
den = 2.0 * cos(beta1) * sin(beta2) * sin(lambda / 2.0) ^ 2 - sin(b2mb1)
' azimuth from point 2 to point 1
azim21 = atan3(num, den)
tmp1 = (1.0 + flat + flat ^ 2) * delta
tmp2 = a * ((flat + flat ^ 2) * sdelta - flat ^ 2 * delta ^ 2 / (2.0 * sdelta))
tmp3 = -(m / 2.0) * ((flat + flat ^ 2) * (delta + sdelta * cdelta) - flat ^ 2 * delta ^ 2 / tan(delta))
tmp4 = -(a ^ 2 * flat ^ 2 / 2.0) * sdelta * cdelta
tmp5 = (flat ^ 2 * m ^ 2 / 16.0) * (delta + sdelta * cdelta - 2 * sdelta * cdelta ^ 3 - 8.0 * delta ^ 2 / tan(delta))
tmp6 = (a * m * flat ^ 2 / 2.0) * (sdelta * cdelta ^ 2 + delta ^ 2 / sdelta)
' length of geodesic from point 1 to point 2
slen = rpolar * (tmp1 + tmp2 + tmp3 + tmp4 + tmp5 + tmp6)
end sub
sub observer(obslat, obslong)
' interactive request of latitude and longitude subroutine
' output
' obslat = latitude (radians)
' obslong = longitude (radians)
' conversion factor - degrees to radians
dtr = 0.017453292519943
do
print "please input the geographic latitude"
print "(degrees [-90 to +90], minutes [0 - 60], seconds [0 - 60])"
print "(north latitudes are positive, south latitudes are negative)"
input obslat.deg$, obslat.min, obslat.sec
loop until (abs(val(obslat.deg$)) <= 90.0 and (obslat.min >= 0.0 and obslat.min <= 60.0) and (obslat.sec >= 0.0 and obslat.sec <= 60.0))
if (left$(obslat.deg$, 2) = "-0") then
obslat = -dtr * (obslat.min / 60.0 + obslat.sec / 3600.0)
elseif (val(obslat.deg$) = 0.0) then
obslat = dtr * (obslat.min / 60.0 + obslat.sec / 3600.0)
else
obslat = dtr * (sgn(val(obslat.deg$)) * (abs(val(obslat.deg$)) + obslat.min / 60.0 + obslat.sec / 3600.0))
endif
do
print
print "please input the geographic longitude"
print "(degrees [0 - 360], minutes [0 - 60], seconds [0 - 60])"
print "(east longitude is positive, west longitude is negative)"
input obslong.deg$, obslong.min, obslong.sec
loop until (abs(val(obslong.deg$)) >= 0.0 and abs(val(obslong.deg$)) <= 360.0) and (obslong.min >= 0.0 and obslong.min <= 60.0) and (obslong.sec >= 0.0 and obslong.sec <= 60.0)
if (left$(obslong.deg$, 2) = "-0") then
obslong = -dtr * (obslong.min / 60 + obslong.sec / 3600)
elseif (val(obslong.deg$) = 0.0) then
obslong = dtr * (obslong.min / 60.0 + obslong.sec / 3600.0)
else
obslong = dtr * (sgn(val(obslong.deg$)) * (abs(val(obslong.deg$)) + obslong.min / 60.0 + obslong.sec / 3600.0))
endif
end sub
function atan3(a, b)
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' c = angle (0 =< c <= 2 * pi : radians)
pidiv2 = 1.570796326794897
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
Posted: 10:03am 27 Feb 2017
Great news - thanks for the feedback.
isochronic
Posted: 10:10am 27 Feb 2017
I guess the code above also runs on the single-precision versions?
What are the results like ?Edited by chronic 2017-02-28
Posted: 02:21pm 27 Feb 2017
I had to change the STR$() arguments to suit the standard micromites (8 decimal points are too much)
On an MM+64 running V5.3
azimuth 1 to 2 306.86795 degrees
azimuth 2 to 1 127.17343 degrees
geodesic distance 54971.98437 meters
isochronic
Posted: 04:21pm 27 Feb 2017
Not bad at all !!
I am speculating that the math routines in 5.3 are DP, from memory
the default is DP and separate routines are used for SP,
(maybe the early MM versions were different)
nice anyway !
[ed]
- an example given some time ago was
a=0
r=0.05
For t=0 To 100000
a=a+r
Next
Print a
So, I guess 5.3 now gives the correct answer ?Edited by chronic 2017-03-01
Posted: 04:58pm 27 Feb 2017
V5.3 still uses 32bit single precision FP so the result is:
  Quote  Micromite MKII MMBasic Ver 5.3 Beta 10
Copyright 2011-2017 Geoff Graham
> NEW
> AUTOSAVE
a=0
r=0.05
For t=0 To 100000
a=a+r
Next
Print a
Saved 62 bytes
> RUN
4999.33
I don't have an extreme to play with.
JimEdited by TassyJim 2017-03-01
Posted: 09:25pm 27 Feb 2017
  chronic said   Not bad at all !!
nice anyway !
[ed]
a=0
r=0.05
For t=0 To 100000
a=a+r
Next
Print a
You already get the "correct" answer. MMBasic like most languages uses floating point and the rounding etc is an inherent part of that.
what you should know
wiki
It is essentially the same problem that used to be easily shown on a pocket calculator, where you could take 1, divide by 3, multiply by 3 and not get 1.
In the example, 0.05 cannot be represented exactly, just as the 1 divided by 3 could not be.
JohnEdited by JohnS 2017-03-01
isochronic
Posted: 10:14pm 27 Feb 2017
The extreme gives 5000.00, right ? A good reason to get one.
  Quote  I don't have an extreme to play with
Considering your good contributions , you should be given one
as a complimentary thank-you !!Edited by chronic 2017-03-01
Posted: 10:36pm 27 Feb 2017
  Quote  The extreme gives 5000.00, right ?
5000.050000009477
  Quote  I am speculating that the math routines in 5.3 are DP, from memory
5.3 does explicitly use SP versions of all math routines - this hasn't changed in any of the versions
isochronic
Posted: 10:57pm 27 Feb 2017
Me :
  Quote   5000.00, right ?
Doh !!! I meant the 5000.05..how embarrassment..
kiiid
Posted: 12:24am 28 Feb 2017
MMZ will give you answer 5000 and 10% soonerEdited by kiiid 2017-03-01
http://rittle.org
