Local Time 02:03 25 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Colour Composite Video
jman
Posted: 11:28pm 23 Feb 2017
Hi
Can anybody suggest a cost effective method of generating colour composite video. I have a project that requires composite video (ntsc or pal).
Ideally a serial to video interface would be perfect so I can drive it with a Micromite. Or even a Micromite that has video out in place of the LCD.
Something like this Colour Basic but with a serial input (Translated via Google)
Jman
Edited by jman 2017-02-25
panky
Posted: 11:36pm 23 Feb 2017
Hi jman,
Why not go with a Colour Maximite? See Circuit Gizmos site for CGCMM2
Circuit Gizmos
Doug.
Edited by panky 2017-02-25
Posted: 11:44pm 23 Feb 2017
  panky said  ....
1xDonT SM1, 1xDuinomite, 1xCGCMM1, 1xCGCMM2, 2xDimitech,
3xWW uMites, 1xMicks MuP, 2xGrogster 1A, 4xPeterM uM+, 1xZonker DIP-600, 3xCGuKits, 1xCGuBoard2, 1xSnadPic
... and loving it!
Blimey Doug, you've got more than me
panky
Posted: 11:52pm 23 Feb 2017
Hey Phil,
I need to update my list and add a Silicon Chip Backpack 64 and an Explore 100 plus the MMX Explore 144 you just sent! ...... and I will have an MMX 64 as soon as you get around to it
Doug.
Posted: 11:56pm 23 Feb 2017
  panky said   and I will have an MMX 64 as soon as you get around to it
Coming VERY soon
Posted: 12:12am 24 Feb 2017
  panky said   Hi jman,
Circuit Gizmos
Doug.
Following on from the above from Panky:
See CG's webpage explaining mono Composite from VGA
Is monochrome any use for you?
Posted: 01:17am 24 Feb 2017
The MaxiMite does not output COLOUR composite video, only black-and-white.
I seem to recall asking about this possibility a while ago, and I seem to also recall the members here in the know saying it was much more difficult then you think to generate colour composite. This MIGHT be possible with Peter's MicroMite eXtreme concept, but only he would be able to tell you that.
I used the Propeller Backpack AV thing, which was able to generate NTSC composite video from easy serial commands. This was a few years ago now - not sure if it is still available, but I should have a couple of those sitting around from my days tinkering. If you want me to look, flick me a PM and I could send them to you - no charge.
EDIT: Here is the thread where I asked about colour composite.Edited by Grogster 2017-02-25
jman
Posted: 10:37am 24 Feb 2017
@ Grogster email sent
Yip I am looking to do the video in colour, B/W just wont cut it for this one.
Did anybody take a look at the translated page? That would fit bill perfectly with a few mods the source is available but I don't do C :(
The module Grogster has will do it with a UMite behind it so that way I will go
Jman
Posted: 02:54pm 24 Feb 2017
Email received, module found, will be sent to you with Monday's mail.
I had a quick look at your link - interesting. It may just be something not possible to do inside the MM2 interpreter - not enough speed, perhaps. Maybe matherp could write a colour composite Cfunction? Edited by Grogster 2017-02-26
Posted: 03:57pm 25 Feb 2017
Lads,
While we are on the subject of video..
What would be required to add HDMI video (even in a basic form).
That could open up a new world for MM.
Kind Regards,
